Under $30 mods here! - Page 19 - Focus Fanatics
Go Back   Focus Fanatics > Ford Focus Discussions > Ford Focus & General Car Chat
Old 12-06-2008, 01:05 PM   #181
yunii
yunii's Avatar
Fan#: 60348
What I Drive: FOCUS 2.0 ZETEC ESP,panther black
FF Reputation: 2 yunii Good Standing Member
£18 it cost me to buy this cover& painted it myself .you can get ffoc,focus,st17o
, zetec,or back off logo in chrome
yunii is offline
Old 12-06-2008, 01:10 PM   #182
yunii
yunii's Avatar
Fan#: 60348
sunvisor switched lamps from scrap mondeo ghia
rear centre dome courtesay light. all lights work on dimming with door open/close
ghia map reading lamp
ghia wood effect surround & chrome gear knob /handbrake lever
st170 speedo & oil gauges/chrome vent surround & footwell lamps
yunii is offline
Old 01-29-2009, 07:55 AM   #183
02ztsian
02ztsian's Avatar
Fan#: 14466
What I Drive: V6Mistake, Volvo S70
FF Reputation: 8 02ztsian Good Standing Member
Buy-Sell-Trade Rating: (14)
OK since my NYE Resolution was to get wrenching and spend less time clicking, I went back to a stalled project I started last summer. And by started I mean bought something and stuck it on a shelf.
So I made up my mind to finish this one. It's adding a rear interior light, something I thought Ford should have done from the start. I trolled the Pick n Pull lanes like I love to do, looking for a suitable swap candidate. Th Focus light was too bulky; I wanted something slimline, with an overhead light and two map lights. I found a suitable candidate in an 80's Escort. The color is darker than I wanted but I can fix that if it bothers me too much.
I grabbed the connectors and some extra wire but ended up not using it.
The inside.
The first thing I had to do was to make it as slim as possible to fit between the headliner and the roof.
Some parts protruded too much and needed to be tweeked. The metal shields needed to be modded.
First-the dome light.
A little bending...from this...
To this...
Then, for the map lights. It started out as one piece, but I had to trim it down so I ended up with two pieces.
Before.
After.
I cut down all the protruding plastic as flush as possible.
A little re-wiring. The Escort grounded to the chassis (only two wires)-the Focus runs three wires. One power, two grounds. (one is not hooked up yet in this pic.)
A brace I made up from something I had kicking around. Two bolts for mounting added. The two big holes at each end mate up to the two holes in the headliner where there are retainers to hold the headliner up.
A metal brace for the front of the light. You can see how it will retain the front of the light. I cut the hole much smaller than the light.
No going back now-a hole in the headliner!
I ran wiring from the front dome light that I tapped into and hid under the headliner and ran to the back of the car.
Finished! It only looks crooked due to the photo angles. And you can see the two retainers in the headliner I used to hold the brace.
And the best part is that everything works as it should! The dome light fades in and out like the front light, and is door operated in the "DOOR" position.
Total cost: about $6 in total. The wiring I grabbed on a previous trip (it's a wagon interior light harness) and they didn't charge me for it. The other bits I had lying around, like scrap sheet metal and heat shrink tubing. The light was like $3.
Points to ponder:
When you are dead, you do not know you are dead.
It's only painful for others.
Same applies to stupid.
02ztsian is offline
Old 02-06-2009, 11:37 AM   #184
tonkpilsmaggot666
tonkpilsmaggot666's Avatar
Fan#: 62430
What I Drive: 2005 Blue Ford Focus ZX4 SE Manual
FF Reputation: 1 tonkpilsmaggot666 Good Standing Member
I'm new here. 1st post, YAY! since I'm a poor highschooler I'll probably be trying some of these mods. Here's my first contribution/concept.
you ever use the squeegee thing at the gas station to get rid of dust and end up with unsightly squeegee marks left on your windows? I'm curious. Would it be possible to replace the rubber stuff that keeps cold/warm air/water in/out of inside/outside of windows with squeegees. that way all you'd have to do is wash the windows, roll 'em down, then roll 'em up to squeegee off the excess water. Just a thought.
~maggot
tonkpilsmaggot666 is offline
Old 02-07-2009, 10:03 PM   #185
Ryeno
Fan#: 61784
What I Drive: Lexus SC300
FF Reputation: 1 Ryeno Good Standing Member
You should replace the light bulbs with led bulbs. White light looks really fancy, not to mention a few leds will be a LOT brighter then 2 bulbs.
Ryeno is offline
Old 03-26-2009, 06:10 PM   #186
shane_c
Fan#: 53658
What I Drive: 2004 Light Tundra SE Wagon (SPI)
FF Reputation: 1 shane_c Good Standing Member
Cheap sound deadening
I was tired of the road noise in my wagon so I took a few of the drop ceiling tiles I had in the basement (those ones that are white on one side and have about 3/4" of insulation attached to it) and cut them to the size of the rear cargo mat then put them in garbage bags and put them under the mat. I also put some in the side panels of the cargo area. They really quieted down the road noise and best of all since I had them around it didn't cost me anything.
2.0L SPI, automatic
shane_c is offline
Old 03-26-2009, 09:07 PM   #187
JJEHUD
JJEHUD's Avatar
Fan#: 53834
What I Drive: 2005 Red ZX4 ST
FF Reputation: 2 JJEHUD Good Standing Member
Rain-x anyone?
Team Focus Cleveland #1 sedan revolution #178
JJEHUD is offline
Old 03-27-2009, 07:23 AM   #188
Toolman
Toolman's Avatar
Fan#: 27202
What I Drive: 2005 Ford Focus ZX3,Egg Yolk Yellow
FF Reputation: 1 Toolman Good Standing Member
great dome light mod
If I may take the liberty - TaylorinAlaska had a great dome light mod that also belongs in THIS thread. He shows how to use an inexpensive string of LED's in the domelight. With a string of 9 lights, even a color as dim as red or blue would be nice and bright! He links to a site selling such for a whopping $5.99, most worthy of this under-$30 thread.
http://www.focusfanatics.com/forum/showthread.php?t=193036
Team Duratec #20, ATX Faction #11
Enkei wheels,HPS Intake, Ported TB, Tein S Tech springs,SVT shocks,Billet Grills,Debadged,Custom Exhaust,Black Headlights,tinted tails & markers,12" Polk GNX124 Sub, Polk db571 front speakers, Panasonic HU.
Toolman is offline
Old 03-28-2009, 03:18 PM   #189
daveyboy
daveyboy's Avatar
Fan#: 61480
What I Drive: 06 Mustang GT, 09 Focus SE
FF Reputation: 7 daveyboy Good Standing Member
bluefront, I like the Idea about the cabin Air filter. I know what Im doing at work next week
Hard work never hurt anyone, but why take a chance
Originally Posted by ranger_mclaren View Post
Wheel gap is like a vagina the more fingers you can fit in the worse it is.
daveyboy is offline
Old 03-28-2009, 03:55 PM   #190
norcalfocus01
Fan#: 55603
FF Reputation: 132 norcalfocus01 Excellent Standing Membernorcalfocus01 Excellent Standing Member
Buy-Sell-Trade Rating: (12)
Wow Cant Belive I Havent Seen This Thread!
Custom Painted Valve Cover:
Cost: $30 Primer, Paint, Clear Coat
Time: One Afternoon
Complete How To: http://www.focusfanatics.com/forum/s...ighlight=valve
Cluster Ring Mod:
Cost: $1.00 For Paint Pen
Time: 1 Hour
Complete How To: http://www.focusfanatics.com/forum/s...hlight=cluster
Painted Door Pannels:
Time: One Afternoon
norcalfocus01 is offline
Similar Threads
MPG after mods ouikikazz ZETEC Performance (2000-2004) 18 04-23-2012 09:13 AM
new mods project2point ZETEC Performance (2000-2004) 6 07-07-2005 06:36 AM
Mods and Questions (long) ferraristyle SPI Performance (2000-2004) 7 05-18-2004 12:46 PM
Just bought some new mods Sublime ZETEC Performance (2000-2004) 24 04-12-2004 04:47 AM
Performance mods for ATX poisonivory ZETEC Performance (2000-2004) 27 01-16-2004 12:33 PM
