SPI Timing Belt Change How to - Page 4 - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 11-19-2013, 09:29 PM   #31
tryingtofixthis
Fan#: 118287
What I Drive: 00 blue FF, 91 black Volks Jetta
FF Reputation: 1 tryingtofixthis Good Standing Member
Also there is a thread on here for sc you could probably post there a and someone local may be able to help you.
Gasoline, Better burn it while we still can!
tryingtofixthis is offline
Old 11-19-2013, 09:37 PM   #32
JeepFoci
Fan#: 123113
What I Drive: 2003 Silver Ford Focus 2.0 SOHC
FF Reputation: 1 JeepFoci Good Standing Member
Interesting...my question was retarded..ok maybe you should re-read your posts. Takes one to know one i suppose.
JeepFoci is offline
Old 11-19-2013, 09:45 PM   #33
tryingtofixthis
Fan#: 118287
Lol true that. Phones really suck to type on. But seriously I didn't mean to come off rude. I'm trying to help so you don't time your.shit wrong and drop a valve or bend them or blow a head gasket, or crack or warp your head. Thus costing you more time and money. But seriously I am retarded my first engine swap I tried.to.pull the engine with the torque converter bolts still. I've made my retarded mistakes don't get me wrong luckily trans.was fine. But it could have been a bad for me.
Old 11-19-2013, 09:50 PM   #34
JeepFoci
Fan#: 123113
Its all good. I've done everything from engine & transmission pulls & installs, internal fuel pumps, manifold gaskets etc and the list goes on. Surprisingly I've never done a timing belt. So this will be the first one. I now realize that if the cam is on TDC then the crank should be as well as long as it hasn't jumped. I plan on tackling this job soon. The key is like with everything double check, triple check, quadruple check.
JeepFoci is offline
Old 11-19-2013, 10:07 PM   #35
tryingtofixthis
Fan#: 118287
Right on im with you there! Check check again. An Yeah your right if you didn't jump time cam will line up crank.
Old 11-23-2013, 12:47 PM   #36
yarryman
Fan#: 124409
What I Drive: 2000 Ford Focus SE RED
FF Reputation: 1 yarryman Good Standing Member
2000 Ford Focus SE Split Port
[ATTACH][ATTACH][ATTACH][ATTACH]Name:  .jpg
Size:  95.9 KB[/ATTACH][/ATTACH][/ATTACH][/ATTACH]Thanks for the post on the timing belt. I just changed mine as well but didnt have great luck. Before I changed my timing belt it ran great. After I changed the belt it ran good but had a small miss. Prior to taking the old belt off I tried to align the cam and crank at top with both notches. It didnt matter how many rotations I could not get them to both hit at the 12 o clock position. I had all the spark plugs out and could tell the number one piston was not at TDC. When I had the number one piston at TDC both the Cam and Crank shaft where at 5 minutes to the right of 12 oclock.
So I proceeded to change the belt with the number one piston at TDC and both the crank and cam at 12 o clock. I put the belt on and tried to rotate the engine 2 times but it the piston would hit the valves. Prior to removing the belt I painted the alignment of both the cam and crank. Next I took the belt off again and put it back the way it was prior to me removing. I checked the rotations of the engine and it rotated all the way through 2 rotations. I put everything back together and it ran good but had a couple of misses. I ran it for about two weeks and yesterday when starting my engine I heard a loud knock coming from my engine and it was idling bad. I immediately turned it off and had it towed home.
Next I removed my head and found out that the number one piston was hitting something. It may have been my valve but there are bits and pieces all in the number one cylinder. I believe my belt jumped a tooth and the piston and valve hit each other.
My question would be is if I have the head reconditioned can i still use the engine with the number one piston having cuts divots in the top of the cylinder. The engine still has good compression.
See picture below:
yarryman is offline
Old 12-01-2013, 08:16 AM   #37
2003focusowner
Fan#: 51939
What I Drive: 2003 Focus SE SPI
Points 5,246, Level 46
Points: 5,246, Level: 46 Points: 5,246, Level: 46 Points: 5,246, Level: 46
Level Up 48% Completed
Level up: 48% Level up: 48% Level up: 48%
FF Reputation: 2 2003focusowner Good Standing Member
I thought the SPI was a non-interference engine? If the timing belt were to break it would not ruin the engine?
2003focusowner is offline
Old 12-01-2013, 03:11 PM   #38
poppop
poppop's Avatar
Fan#: 59702
What I Drive: 2001,Red,LX
Points 278, Level 5
Points: 278, Level: 5 Points: 278, Level: 5 Points: 278, Level: 5
Level Up 56% Completed
Forum Activity 2%
FF Reputation: 2 poppop Good Standing Member
They are non- interface.have built a dozen or so and can spin the crank all day and not hit a valve.
poppop is offline
Old 12-01-2013, 05:41 PM   #39
tryingtofixthis
Fan#: 118287
Looks like your.missing a valve seat.
Old 12-02-2013, 06:19 PM   #40
poppop
poppop's Avatar
Fan#: 59702
Points 278, Level 5
Forum Activity 2%
Looks that way for sure.
poppop is offline
Similar Threads
ZETEC Timing Belt Replacement lhc_focus General Technical Chat 238 01-30-2015 02:54 AM
Timing Belt Info Spanky6935 General Technical Chat 13 09-30-2011 11:54 PM
"How To" VCT Trouble-TSB 03-6-07 Springbuck SVT Performance (2002-2004) 26 08-18-2009 02:21 PM
When should you get a timing belt changed? Jebus SVT Performance (2002-2004) 13 05-25-2009 04:00 AM
Timing Belt jac0b ZETEC Performance (2000-2004) 2 11-25-2003 05:52 PM
