SPI Timing Belt Change How to - Page 2 - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 03-17-2010, 03:36 PM   #11
Captain Planet
Fan#: 49317
What I Drive: Blue 2001 SE
FF Reputation: 1 Captain Planet Good Standing Member
Originally Posted by Focusnewb View Post
Yes, it's the pulley on the crankshaft.
You need to find a way to keep the pulley from turning while you try to wrestle the bolt loose. On slotted pulleys I have braced metal bars (screwdriver shafts) through the pulley and caught them on something solid on the backside. A good strap/chain wrench may grab with enough grip to do it, I used a strap wrench when I put the pulley back on (100k miles ago so it's held) but haven't tried it for removal.
On the Focus, I used the starter to turn the motor with a breaker bar/socket on the pulley and braced on the garage floor.....this is the not-so-safe-way I think he is mentioning. VERY IMPORTANT, you must have the plug wires or coil unplugged or the motor will fire.....this is bad with a loose pulley bolt ! Also the breaker bar will probably go flying across the garage (mine did) so it's important not to have any body standing around or anything breakable nearby. If I would have thought about it more, I would have draped a towel over the breaker bar handle or something.
I'll bet that added some excitment to the job!!!!
Sounds like a strap wrench is the way to go. Is it completely necessary to take off the pulley? Can't the timing belt be taken off around the pulley after it is loose from the engine? Also, is there a torque spec for these bolts? I didn't see them on the general torque specs that were included in another thread.
Also, I saw a picture in a thread for the DOHC engine and using marks on the cam shaft pulley, drive shaft pulley, and the belt. Are there not top dead center marks on the pulleys to go by anymore?
Captain Planet is offline
Old 03-18-2010, 02:08 PM   #12
Focusnewb
Focusnewb's Avatar
Fan#: 27975
What I Drive: 2001 Sangria Red 4dr SE
Points 1,817, Level 25
Points: 1,817, Level: 25 Points: 1,817, Level: 25 Points: 1,817, Level: 25
Level Up 17% Completed
FF Reputation: 11 Focusnewb Great Standing Member
Buy-Sell-Trade Rating: (4)
Not too exciting, it hit the plastic trashcan so no damage. I believe it's necessary for the timing belt (not the job I was doing at the time combined with fuzzy memory may make me wrong) Most of the time there's a cover behind the pulley that covers the lower timing pulley.....if not that, there may be a flange around the bottom of the bottom timing gear which would also keep the belt from coming out around the pulley.
I've done a few timing belts on other cars and all needed the crank pulley removed for the above reasons. If only he would have snapped a picture through the wheelwell....sigh.
Our SOHC (SPI) has timing marks I believe but IIRC the DOHC does not (at least not on the cam gears)
I betcha can't get it off with a strap wrench though....I think I tried that before doing the other thing.
Panties aren't the best thing in the world but they are next to it.
I would rather drive the slow car Rusty built than the slow car I built.
Do your own repairs, it's not rocket surgery !!
Focusnewb is offline
Old 03-19-2010, 05:18 PM   #13
Captain Planet
Fan#: 49317
I was under the impression that the 2.0 SPI was a clearance engine. I bought a timing belt tensioner yesterday and the paperwork in the package says it is an interference engine. Is this true?
Old 03-22-2010, 08:11 AM   #14
Focusnewb
Focusnewb's Avatar
Fan#: 27975
No, it's not but I noticed that that seems to be how everyone selling belts has them listed.....not sure why.
Old 03-29-2010, 12:31 PM   #15
Captain Planet
Fan#: 49317
I would like to tip my hat to untenops for this great tutorial. I did my belt last week and my success was in great part to this thread.
I read MANY threads on this forum and I applied some of what I read elsewhere to my project.
Here are a couple tips to doing this job.
First, before you take the belt off, mark the old belt, both pullies, and where the pullies are in relation to the block. Then when you take the tensioner loose and remove the belt, you have your engine positions marked.
I would like to add a couple pictures, but I don't see where.
Old 04-06-2010, 03:40 PM   #16
Matts50
Fan#: 74189
What I Drive: 94 Mustang GT, 00 Focus SPI
FF Reputation: 1 Matts50 Good Standing Member
Just to confirm on #10, The timing marks are to be BOTH pointing at 12 o'clock? I thought they were suppose to be facing each other?
Matts50 is offline
Old 04-07-2010, 10:31 AM   #17
Captain Planet
Fan#: 49317
It doesn't really matter where the postion of the crank and the cam crank are. If you mark your timing belt and pulleys BEFORE you remove the timing belt, you can simply mark the new belt in the same places as the old belt and install the new belt at the marks. That is what I did a couple weeks ago and it worked perfectly. If I could find how to add pictures I would post them for you to see.
Old 07-10-2010, 04:45 PM   #18
P2Hitman
Fan#: 76609
What I Drive: 2000 Blue Focus LX
FF Reputation: 1 P2Hitman Good Standing Member
What is my best bet if my timing belt has gone bad and snapped or fallen off? I have been told that this has happened to my car, and unfortunately I tried to start it a multitude of times... I have never done it before, but clever in figuring out how to do things right the first time around. Are there marks on the splines of a 2000 Focus LX SOHC that can help me align it?
P2Hitman is offline
Old 07-18-2010, 02:33 PM   #19
fordtec
Fan#: 76186
What I Drive: 2000 SE SEDAN,03 SVT,03 ZX-3
Points 2,593, Level 30
Points: 2,593, Level: 30 Points: 2,593, Level: 30 Points: 2,593, Level: 30
Level Up 96% Completed
FF Reputation: 2 fordtec Good Standing Member
Buy-Sell-Trade Rating: (63)
location of timing marks .Your cylinder head has a mark on it that is dead center.you can see it from the window in the cam sprocket timing pointer, also the oil pump has a timing mark that is also dead center. Line up the crank sprocket timing pointer on that mark. Crankshaft at T.D.C(crank sprocket timing pointer aligned with oil pump. Timing mark and camshaft sprockret timing pointer aligned with cyn head timing mark. good luck. fordtec out!
fordtec is offline
Old 07-18-2010, 11:48 PM   #20
moon111
Fan#: 75163
What I Drive: 2000 Black Ford Focus
FF Reputation: 1 moon111 Good Standing Member
About how much does the belt and tensioner run?
moon111 is offline
Similar Threads
ZETEC Timing Belt Replacement lhc_focus General Technical Chat 238 Yesterday 02:54 AM
Timing Belt Info Spanky6935 General Technical Chat 13 09-30-2011 11:54 PM
"How To" VCT Trouble-TSB 03-6-07 Springbuck SVT Performance (2002-2004) 26 08-18-2009 02:21 PM
When should you get a timing belt changed? Jebus SVT Performance (2002-2004) 13 05-25-2009 04:00 AM
Timing Belt jac0b ZETEC Performance (2000-2004) 2 11-25-2003 05:52 PM
