Go Back   Focus Fanatics > Ford Focus Tech Discussions > General Forced Induction
General Forced Induction The place to chat about turbochargers, superchargers and Nitrous systems.
Old 09-28-2008, 01:50 AM   #1
07FocusST
07FocusST's Avatar
Fan#: 49661
What I Drive: 2007 Focus ST
FF Reputation: 2 07FocusST Good Standing Member
07FocusST Home Turbo Build
If it hasn't been known by now that there only a few companies that market turbo systems for the Duratec Focus. A few members here and myself aren't willing to pay $3,000-$4,000 + S&H for a pre-fabbed kit. Some of us just want to liberty to say "yea... I built it myself".
Thankfully FF has some people with a great amount of knowledge (or balls) to make their own systems. I personally want to give a BIG shout-out to Sporadic for taking the time to post all of his information and pictures here on FF for all of us to study. Without his inspiration I probably wouldn't even consider attemping to build my own system.
With that out of the way I will list all the parts I will be using during my build:
- IHI RHB52 from 1987-1988 T-Bird Turbocoupe
- 60lb/hr Siemen Fuel Injectors w/ C-F-M Adapter Harness
- 2.5" Universal Front Mount Intercooler 24" x 7" x 3"
- 2.5" Intercooler Piping & Silicone Couplers (Turbo-to-Intercooler)
- 3.0" Intercooler Piping & Silicone Couplers (Intercooler-to-Throttle Body)
- Pre-Fabbed 2.5" Intercooler Pipe w/ HKS SSQV BOV mount
- 3.0" Blow-Thru MAF house w/ 2005+ Mustang GT MAF sensor
- JGS Turbo Manifold
- SCT Flash Tuner
- Oil Supply Line w/ Adapters & .06 Restrictor
- Oil Drain Line w/ Adapters & Oil Pan Weld-on Bung
- 2.5" Home made Downpipe Assembly w/ 2-O2 Sensor Bungs
- Oil Catch Can
** Equipment for Later **
- A Pillar Gauge Pod
- Boost/Vac Gauge
- Electric Oil Pressure Gauge
- Electric Water Temperature Gauge
- Wideband O2 Sensor
The plan is to run my Turbo System at a low PSI to keep things safe. I am running my setup to utilize a Blow Off Valve. Heck, if you have a turbo system then you probably would like to hear it. I know I would.
I am using the HKS SSQV because of their high reputation. The RHB52 turbo can be hard to find replacement parts for so I would suggest to everyone who considers building your own project to look for the T3 turbo used in the later years of the Ford SVO/TurboCoupe or even the Merkur XR4TI. This will save you a big headache if you run into the same problems I have.
Some of you reading this are probably wondering about a few things, so I will answer a few before I post some pictures:
"If the IHI RHB5 is hard to get parts for, then why didn't you purchase the T3 Instead?"
Simple, the T3 is even harder to find used because they are universal. There are a million places that carry parts for it. The T3 may be bigger in size but I feel safer starting with a smaller turbo.
"I have been told that running a BOV on a car with a MAF style computer system can cause engine damage."
This is absolutly correct! Running a BOV after a MAF sensor will make your engine stumble & stutter because all the air that has just been "metered" has now been released into the atmosphere. The computer doesn't recognize this and will continue to allow a high amount of fuel to enter the engine while there isn't an adequate amount of air to compensate for the extra fuel. In other words your engine will be extremely rich. If a BOV is placed before the MAF sensor then there won't be a problem because the MAF sensor hasn't metered the air yet. That also goes to say that if your engine's computer system relies on a MAP sensor then you can run a BOV regardless because the MAP sensor reads the Vacuum/Pressure inside the Intake Manifold. So there isn't any problem this way. The other way to run a system is by doing what most Manufacturers do. They run a Diverter valve that recirculates the air back to the turbo inlet. This is typically the safest way to run any turbo system.
"If you are running a BOV before the MAF sensor then that would mean you are placing the MAF sensor in the compressor's outlet side?"
This is also correct. This setup requires a particular type of MAF sensor housing known as a "Blow-Thru MAF Housing" which isn't what most vehicles use as OEM. Most cars would use a "Suck-Thru" MAF housing like a factory MAF would be on a Focus. The only difference is the suck-thru has air being sucked thru and the Blow-thru has air pressure inside of it and usually is secure to a pipe with a strong clamp unlike a suck-thru.
"Why don't you use the DiabloSport MAFia instead of a Custom MAF housing and Mustang GT MAF sensor?"
Well... that is because I plan on using the BOV like I mentioned before and this requires me to put the housing in the pressurized side (blow-thru). So I would need a new housing regradless. I suppose I could use my factory MAF sensor with the MAFia, but the Mustang GT MAF is good to around 400HP. If I even come close to pegging out the Mustang MAF sensor then I still have the option of using a MAFia.
So here is what I have so far. There are alot of parts on order and I am lucky enough to have a good friend to let me use his MIG welder that has Argon purge. Please keep in mind that this is a work in progress!!! Thanks, enjoy the pictures!
The good:
ID:	16405   Click image for larger version
ID:	16406   Click image for larger version
ID:	16407   Click image for larger version
ID:	16408   Click image for larger version
ID:	16409   Click image for larger version
Turbo ST (Soon Again)
Boosted Crew Member #115
SAP Crew Member #17
Originally Posted by hypnoticracing View Post
foci's came without rear brakes? i guess mine is special with its drums
07FocusST is offline
Fan#: 1
Old 09-28-2008, 01:52 AM   #2
07FocusST
07FocusST's Avatar
Fan#: 49661
The Bad: The Impellar looks like it had contact, the bearings are shot! Bottom pictures are a few random picture I took of painting the compressor housing, the paint I used, and my Focus!!!
ID:	16411   Click image for larger version
ID:	16412   Click image for larger version
ID:	16413   Click image for larger version
ID:	16414   Click image for larger version
ID:	16415   Click image for larger version
SAP Crew Member #17
Old 09-28-2008, 08:18 AM   #3
y2kc0wb0y
y2kc0wb0y's Avatar
Fan#: 28314
What I Drive: 2010 Colnago CX-1
FF Reputation: 2 y2kc0wb0y Good Standing Member
Buy-Sell-Trade Rating: (7)
How much money did you save?
I don't care what you drive as long as you take care of it. As for me, I have no car so I'm only worried about taking care of myself.
y2kc0wb0y is offline
Old 09-28-2008, 09:02 AM   #4
1turbofocus
FF Affiliate
1turbofocus's Avatar
Fan#: 1123
What I Drive: 2000 ZX3 / 2002 SVT , Turbocharged
FF Reputation: 146 1turbofocus Excellent Standing Member1turbofocus Excellent Standing Member
Buy-Sell-Trade Rating: (28)
Originally Posted by 07FocusST View Post
The RHB52 turbo can be hard to find replacement parts for so I would suggest to everyone who considers building your own project to look for the T3 turbo used in the later years of the Ford SVO/TurboCoupe or even the Merkur XR4TI. This will save you a big headache if you run into the same problems I have.]
I dont agree, These turbos on the Focus engines dont work well and in most cases are wore slap out when you take them off the car , I think with the low prices of new turbos now with 1 year warranties at less then 600.00 you should allways buy a new turbo
This is absolutly correct! .]
This is incorrect , you WILL NOT damage your engine
Running a BOV after a MAF sensor will make you engine stumble & stutter because all the air that has just been "metered" has now been released into the atmosphere. The computer doesn't recognize this and will continue to allow a high amount of fuel to enter the engine while there isn't an adequate amount of air to compensate for the extra fuel. In other words your engine will be extremely rich. If a BOV is placed before the MAF sensor then there won't be a problem because the MAF sensor hasn't metered the air yet. That also goes to say that if your engine's computer system relies on a MAP sensor then you can run a BOV regardless because the MAP sensor reads the Vacuum/Pressure inside the Intake Manifold. So there isn't any problem this way. The other way to run a system is by doing what most Manufacturers do. They run a Diverter valve that recirculates the air back to the turbo inlet. This is typically the safest way to run any turbo system.]
This is correct to a point there is a way to adjust the ECU so that you get a slight rich condition but dont notice a thing from the drivers seat , A blowthrough is the ideal way of doing this and all Focus kits now should be blowthrough
This is also correct. This setup requires a particular type of MAF sensor housing known as a "Blow-Thru MAF Housing" which isn't what most vehicles use as OEM. Most cars would use a "Suck-Thru" MAF housing like a factory MAF would be on a Focus. The only difference is the suck-thru has air being sucked thru and the Blow-thru has air pressure inside of it and usually is secure to a pipe with a strong clamp unlike a suck-thru.]
Incorrect any MAF can be used as a blowthrough the MAF does not know or care if the air moving through it is being pulled or pushed
Well... that is because I plan on using the BOV like I mentioned before and this requires me to put the housing in the pressurized side (blow-thru). So I would need a new housing regradless. I suppose I could use my factory MAF sensor with the MAFia, but the Mustang GT MAF is good to around 400HP. If I even come close to pegging out the Mustang MAF sensor then I still have the option of using a MAFia.]
The GT Mustang MAF is odd size and hard to get hoses for and looks like crap installed on top of that it is to big and you dont get as good a signal in part throttle , you would be better off making you or buying a 3 inch MAF tube and using your stock Focus MAF electronics
Customer Support
AIM: hpdyno
Email: tom@focus-power.com
Phone: 704-249-3745
Site: focus-power.com
Elder 1turbofocus
1turbofocus is offline
Old 09-28-2008, 10:37 AM   #5
Power Surge
Fan#: 55878
What I Drive: 2012 Race Red SE 5-door
FF Reputation: 1 Power Surge Good Standing Member
Wow, I have to admit, everything you said is right on the money. You've really done your homework. I am impressed.
The only thing I would change is your choice of turbo. I would really start with an internally gated T3 based unit, not that IHI deal. I've deal with the IHI units for a long time on Turbo Coupes and such and they are just a waste of money and energy IMO.
Great choice on the MAF setup. The 05-up cartridge sensors are very blow through friendly. Mounted in a 3" tube, will be a nice clean setup, and you won't need to recirc the vented air if your bypass is before the MAF. Just make sure you've got a few inches af straight tube before and after the sensor for a cleaner signal. I did the 05-up in the blow through tube on my turbo SHO. I intergrated mine as part of the actual ducting. You can see it here pointing towards the strut tower:
I still needed a MAFia for my setup, but you probably won't on the Focus. Either way, it can be added if needed.
Also, you don't need injector adapters, they make 60s with the EV1 connector on them. Get the Motortron ones, plug and play.
I will be watching your build to see how you progress with it. Good luck!
Sal
2012 Race Red 5-door SE, 18" Ti wheels, Ti headlights/fog bezels, 20% tint, debadged trunk
2002 Sonic Blue SVT - supercharged (sold)
2008 Vista Blue SE (gone)
Power Surge is offline
Old 09-28-2008, 04:21 PM   #6
07FocusST
07FocusST's Avatar
Fan#: 49661
y2kc0wb0y
I am in the process of collect all the parts, so far I am guessing a total amount of around $1000-$1200 total spending depending on what I buy.
1TurboFocus
As I stated earlier, The point for my home build is to save alot more money than buying a kit. So with that in mind I definitally would stick with the IHI IMO.... Granted you are absolutely correct about a new turbo. It should always be considered when making your own kit. It is personal preference and probably going to rely on how much $$$$ you have at the time.
As for a BOV damaging your car, I have seen more Subaru's & Mustangs with blown engines because their engine was not properly setup for a BOV. When the engine goes rich and the driver hits the gas there is alot of mayhem going on inside the engine because now it is trying to clear the excess fuel, then goes lean and right back to a stoich/rich amount. This is why you see a lot of lightning drivers blow their engines is because the roots style blower can surge and cause this situation to occur.
I agree, blow thru should be the way regardless
you are correct about any MAF being used for a Blow-Thru setup, but keep in mind that a 3" MAF house will give the best reading in any vehicle. Running my stock 2.5" plastic MAF housing will scramble the signal a little and the fact that it is plastic with pressure behind it doesn't thrill me at all.
Again, you are correct. The stock MAF housing would not fit. Maybe I didn't state this but I am going to be using a 3" Blow Thru MAF with a Mustang GT Sensor that is good to 400HP.
PowerSurge
Your setup looks awesome. I like how you integrated the housing into the piping. I have already bought thr Siemens 60lb/hr. I took a look at my injector harness last night and it looks like the will plug in without an adapter from CFM.
SAP Crew Member #17
Old 09-28-2008, 04:44 PM   #7
1turbofocus
FF Affiliate
Fan#: 1123
What ever , I was just passing on what I have found that works on the Focus , It is a Focus we are talking about here not a Suburu or Mustang and in no way can you damage an engine from venting metered air
No I dont agree that " a 3" MAF house will give the best reading in any vehicle" There are many I tune that the 3.5 is much better and 4 inch on some of the higher HP V8 cars , you need to choose the smallest tube to get the job done with the range needed , Its your car and you have to choose but the Mustang GT sensor in a 3 inch tube I doubt will get you to 400 on the Focus
Customer Support
AIM: hpdyno
Phone: 704-249-3745
Elder 1turbofocus
Old 09-28-2008, 04:45 PM   #8
mbx5brian
mbx5brian's Avatar
Fan#: 31419
What I Drive: 2006 ZX4 TURBO
FF Reputation: 3 mbx5brian Good Standing Member
good luck
FOCUS SPORT STAGE 2
UPGRADE ATX BY LENTECH
DURATEC 38 TEAM
mbx5brian is offline
Old 09-28-2008, 04:46 PM   #9
1turbofocus
FF Affiliate
Fan#: 1123
Originally Posted by Power Surge View Post
Great choice on the MAF setup. The 05-up cartridge sensors are very blow through friendly. Mounted in a 3" tube, !
I havent found the Cartridge sensor to be any better the the old style with doing back to back testing , the signal wasent any cleaner or smoother , I am getting some calls to change over to that sensor and just wanted to add that in here
Customer Support
AIM: hpdyno
Phone: 704-249-3745
Elder 1turbofocus
Old 09-28-2008, 04:50 PM   #10
1turbofocus
FF Affiliate
Fan#: 1123
y2kc0wb0y
I was just trying to correct what you said earlier "This setup requires a particular type of MAF sensor housing known as a "Blow-Thru MAF Housing" which isn't what most vehicles use as OEM"
Customer Support
AIM: hpdyno
Phone: 704-249-3745
Elder 1turbofocus
Similar Threads
(AVL. Turbo Kits) XIOS vs. Top Speed vs. CFM vs. FocusPower jstrunk General Forced Induction 70 05-10-2009 07:30 PM
For Sale: Garrett GT3076R Turbo *SOLD* 03OrangeSVT Archive 34 01-20-2008 11:54 AM
New Thrust Turbo Build CatMostFeared General Forced Induction 91 08-09-2007 01:21 PM
soon to be turbo build and i would like suggestions and input besthaticouldo General Forced Induction 0 06-21-2007 02:45 PM
Build a turbo! (hurry up) 03_SPI_sedan SPI Performance (2000-2004) 6 06-14-2007 03:56 PM
