Go Back   Focus Fanatics > Ford Focus Racing Discussions > Drag Racing
Drag Racing The place to discuss information about drag racing stats, tips and events. Track sanctioned events only.
Old 09-28-2008, 01:29 AM   #1
ZtsFocus
Fan#: 878
FF Reputation: 1 ZtsFocus Good Standing Member
13.6 @ 103.7 on street tires :)
so went to the track last friday and pulled off a 13.6 really happy about it. 60ft was horrible. high 2.2. just bought some slicks but now having any luck with them. anyone have any tips or hints for me, for a better 60?
thanks mike
ZtsFocus is offline
Fan#: 1
Old 09-28-2008, 07:54 AM   #2
Insane
Adam
Insane's Avatar
Fan#: 51468
What I Drive: 2003 Infra Red ZX3
FF Reputation: 41 Insane Great Standing Member
2.2 isn't that bad..
-Zetec Crew #215
Volant Intake, SVT Snorkle, By past A/C, AFX UDP, Copper Plugs, 9mm Plug Wires, Toms Tune, Roush springs/shocks/struts, Eibach Sway-Bars, C-F-M Racing Lower Engine Mount.
Insane is offline
Old 09-28-2008, 02:15 PM   #3
Onyx flash
Onyx flash's Avatar
Fan#: 19859
What I Drive: 05' pitch black ZX3
FF Reputation: 1 Onyx flash Good Standing Member
Buy-Sell-Trade Rating: (10)
wowsers thats on a zts? what do you have done?
228whp 216wtq
05 Zx3 2.0 Duratec w/CP Pistons, K1 H-Beam Rods,HiBoost Turbo kit w/Focus Sport tuning @7 psi, 3" Magnaflow flex-back exhaust w/Carsound cat,F2 Flywheel,Exedy organic,VF dogbone,Koni dampers
Onyx flash is offline
Old 09-28-2008, 04:07 PM   #4
ZtsFocus
Fan#: 878
no, its actually my zx3 i used to have a zts. my car is turbod
ZtsFocus is offline
Old 10-22-2008, 08:19 AM   #5
ZX3_2NV
ZX3_2NV's Avatar
Fan#: 29238
What I Drive: 2000 ZX3 Turbo, 2001 ZX3
FF Reputation: 4 ZX3_2NV Good Standing Member
Preloading will bring that 60 foot right down basically line it up after you light the second bulb. Grab the ebrake pull it up about 3/4 the way up holding in the release button, so it doesn't get stuck up. Bring the rpm's up I usally launch around 5800 on slicks (try different rpms for your set up) QUICK TIP: Usally its best to launch around the same rpm you have the highest whp on a dyno run. Then once you have the rpms up start releasing the clutch SLOWLY almost till its fully disengaged BUT the car won't move or red light since your still holding up the ebrake and then when u see green drop the ebrake let go of the clutch completly and off you go. Keep in mind you only have a split second to do all this. So practice makes perfect Good luck the best 60 foot i've had is 1.73 with consistant 1.8's
Founder Of The Boosted Crew If your Turbocharged, Supercharged or on Nitrous.
ZX3_2NV is offline
Old 10-23-2008, 05:35 PM   #6
VenomRogue
VenomRogue's Avatar
Fan#: 24506
What I Drive: just another slow focus.
FF Reputation: 12 VenomRogue Great Standing Member
Buy-Sell-Trade Rating: (23)
Thats way I do it....
pulled a 2.00x 60 ft with a stock open diff, on street tires.
8 Foci.
Yes, I have issues.
Next question.
VenomRogue is offline
Old 10-23-2008, 06:34 PM   #7
focuztyle
focuztyle's Avatar
Fan#: 28785
What I Drive: Built ZX3
FF Reputation: 1 focuztyle Good Standing Member
Buy-Sell-Trade Rating: (14)
Preloading will bring that 60 foot right down basically line it up after you light the second bulb. Grab the ebrake pull it up about 3/4 the way .....
I have never of this on a stick, wtf? really? i have to try this next time!
Also, question for u ZTS? what kinda of slick u running, I'm bout to get 22' in a couple of weeks, how much HP? Tq? LBS?
Rich
Sit down, hold on, and shut up!
Boosted Crew member # 20
One-off Crew member #1
focuztyle is offline
Old 10-23-2008, 07:35 PM   #8
ZtsFocus
Fan#: 878
on a humid day i put down 207, 228. im going again soon to see what im putting down now that it is colder out. i got 225/50/15s not sure what that comes out too.
ZtsFocus is offline
Old 10-24-2008, 11:38 AM   #9
ZX3_2NV
ZX3_2NV's Avatar
Fan#: 29238
Venom thats an awsome time for street tires preloading is the best way to go add 2step to the mix and its game over and easiest on your transmission most of the time. Good luch and have fun.
ZX3_2NV is offline
Old 10-24-2008, 07:23 PM   #10
streetracer
streetracer's Avatar
Fan#: 49229
What I Drive: 2005 Infra Red Focus ST
FF Reputation: 5 streetracer Good Standing Member
what psi is in the tires? 2.2 is pretty high for slicks.. i ran a 2.146 on street tires at 30psi with an open diff and spinning a lot.. :/
i need some slicks.. i wanna get under 13 in the 1/4! lol
streetracer is offline
Similar Threads
POLL: Would you buy used tires (almost new) j-zetec_pr Wheels, Tires, Brakes & Suspension - Sponsored By Tire Rack 20 04-12-2008 09:26 PM
Another: What should I do!? BlackJack03 Wheels, Tires, Brakes & Suspension - Sponsored By Tire Rack 22 04-11-2007 08:52 AM
Review: Goodyear Integrity tires SD_Focus Wheels, Tires, Brakes & Suspension - Sponsored By Tire Rack 5 04-03-2005 12:51 AM
Suggestions on new tires / rims? Dartimous Wheels, Tires, Brakes & Suspension - Sponsored By Tire Rack 15 01-26-2005 05:55 PM
Almost blew tires off coming home from Calgary FOCUS_ZTS ZETEC Performance (2000-2004) 13 10-08-2003 07:54 AM
