Thermostat housing, How-to, but need detail. - Page 2 - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 09-29-2008, 11:29 AM   #11
hEaT
Fan#: 20699
What I Drive: 2013 Oxford White Focus ST
Points 3,097, Level 34
Points: 3,097, Level: 34 Points: 3,097, Level: 34 Points: 3,097, Level: 34
Level Up 32% Completed
FF Reputation: 11 hEaT Great Standing Member
Originally Posted by iminhell View Post
Well, do the fans come on?
If not there is your problem, with the solution probably being a new Cooling Fan Resistor Pack.
The fan should come on when you turn the A/C on as well. If not, that's your problem.
ZETEC Crew #49
Originally posted by DrkKnight614
......hmm if that works then if i put a spinner on my butt hole and rip one will i be able to run faster. ...idiots
hEaT is offline
Old 09-29-2008, 11:46 AM   #12
Executionerhk
Executionerhk's Avatar
Fan#: 55338
What I Drive: 2000 VW Passat TDI
FF Reputation: 3 Executionerhk Good Standing Member
Buy-Sell-Trade Rating: (4)
hEaT,
I will try to make it over heat, and then check the fan...
but i still think it is the new thermostat, because it was an open item... should I go with the ford oem one from the dealership?
thanks,
Steven
Executionerhk is offline
Old 09-29-2008, 12:17 PM   #13
Executionerhk
Fan#: 55338
ok hEaT,
I have driven to school and make the engine hot enough to make the fan turn on.. and I max out my A/C, seems the fan on the drive side is blowing hard... dono about the pessenger side yet... coz i am late for class... so i cannot check it.... and it was not even a mile drive... my car heat up completely... i seriously think my new themostat is not working...
guys more idea please
best regards guys,
Steven
Old 09-30-2008, 12:04 AM   #14
Executionerhk
Fan#: 55338
bump for the question...
i want it to be fix, please help
Old 10-01-2008, 11:52 AM   #15
hEaT
Fan#: 20699
Have you replaced the thermostat yet?
If you do, the OEM Ford one should be fine. No need for a cool one unless you want to seriously track the car.
You can test your current one this way:
http://www.focushacks.com/index.php?modid=60
I'll have to pop my hood and look, I'm not sure how the fans work. One may be the A/C fan and the other a two speed, or one is low speed and one is high speed. I'm not quite sure, but I'm guessing the first. If it is the first, it sounds like your resistor pack is shot.
ZETEC Crew #49
hEaT is offline
Old 10-01-2008, 12:21 PM   #16
PlasticRacer
PlasticRacer's Avatar
Fan#: 51304
What I Drive: '02 Yellow ZX3
Points 4,034, Level 40
Points: 4,034, Level: 40 Points: 4,034, Level: 40 Points: 4,034, Level: 40
Level Up 43% Completed
FF Reputation: 6 PlasticRacer Good Standing Member
Buy-Sell-Trade Rating: (19)
i really don't mean to jack this thread, but i'm glad i looked at it cause now i can get a lil more specific as to what i'm looking for. That hose that comes from the firewall and goes to the thermostat, the hose in between that attaches to the hose coming from the firewall, #18472, what is that hose called because i need to replace it on my car? thanx
Car status: Gettin right
PlasticRacer is offline
Old 10-01-2008, 04:01 PM   #17
hEaT
Fan#: 20699
Both of my fans come on with temp...
Just checked a few min ago. I have an SCT tune so that may change it.
ZETEC Crew #49
hEaT is offline
Old 10-03-2008, 03:24 PM   #18
Executionerhk
Fan#: 55338
the OEM ford part...
the parts department gave me a wrong part...
that is why it won't fit...
and i believe my friend mount the themostat wrong direction..
which should be the reason why it is over heating...
Old 11-14-2012, 04:36 PM   #19
Xin Ansin
Xin Ansin's Avatar
Fan#: 105987
What I Drive: 2002 Silver ZTS
FF Reputation: 1 Xin Ansin Good Standing Member
I watched a video on replacing the thermostat housing, the guy vacuumed all the air out of the coolant system as he refilled the coolant. is it strictly necessary to do so? or can I just fill it up and let the system to it on it's own?
Xin Ansin is offline
Old 11-14-2012, 10:29 PM   #20
amc49
Fan#: 96610
Points 3,381, Level 36
Points: 3,381, Level: 36 Points: 3,381, Level: 36 Points: 3,381, Level: 36
Level Up 21% Completed
Forum Activity 55%
No vacuuming needed, make sure small hole in stat faces straight up to match the small hose entry in the front cover. The system pretty much bleeds itslef and quick then.
On Focus cars BOTH fans come on as one, they are both on low or both on high as needed.
The stat goes in with the smaller disc end toward back of car. Again, small hole in outer edge faces straight up. That hole may have a loose BB or little poppet trapped in it, I always take it out on mine. That stops it from getting stuck from corrosion later in life.
amc49 is offline
Similar Threads
Thermostat housing leak 02_zxFIVE General Technical Chat 53 01-21-2013 09:02 PM
zetec thermostat housing leaking gonzorelic General Technical Chat 10 07-06-2008 02:38 PM
Where to buy Thermostat Housing and Thermostat? Squareleft General Technical Chat 7 05-16-2008 10:25 AM
Thermostat Housing Wagamos General Technical Chat 8 11-25-2006 03:14 PM
:: Cracked Thermostat Housing Assembly :: ..:: sleestak ::.. General Technical Chat 8 08-11-2006 09:35 AM
