Fuel cell... why? - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Go Back   Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum > Ford Focus Racing Discussions > Road Racing & Rally
Road Racing & Rally The place to discuss information about road/rally racing stats, tips and events. Track sanctioned events only.
Old 09-14-2008, 04:21 PM   #1
tmgolden
Fan#: 56490
What I Drive: 2003 Silver Ford Focus SVT EAP
FF Reputation: 1 tmgolden Good Standing Member
Fuel cell... why?
Looking for arguments (pro and con) on the subject of whether a fuel cell is a good idea or a complete waste of time and money?
tmgolden is offline
Old 09-15-2008, 08:43 PM   #2
WeeAsp
Resident Curmudgeon
WeeAsp's Avatar
Fan#: 42718
What I Drive: 2002 RED SVT Focus
FF Reputation: 175 WeeAsp Excellent Standing Member WeeAsp Excellent Standing Member
As you indicated, there are pros and cons to having a fuel cell.
Given your previous post, I gather that you are thinking about competing the car. So, a fuel cell is a good idea.
Pros:
- Less likely to suffer from fuel starvation while cornering
- More accurate fuel readings to determine mileage.
- Fuel remains more stable for a longer period of time and is less prone to evaporation
- Safer
- Fuel is centrally located and sloshing doesn't occur as much to affect weight transfer as fuel shifts inside a conventional tank (It can't do that with a cell)
Cons:
- Expensive
- Usually requires a high volume fuel pump to work effectively. The stock pump will NOT work
- Expensive
- Less fuel capacity
- To install, you need to make modifications to the rear trunk - It will not fit at the stock mounting points
- Fuel vapor can enter the car because of the installation needed
- Expensive
- You cannot pull up to the pump and use a conventional nozzle to fuel. Fuel cells are "sealed" systems that require a special filler nozzle to allow for fueling.
Bottom line is that a fuel cell is neither a good or bad idea. It depends on your application. If you intend to race the car, then definitely a good investment. If not, then save your money. The expense of the cell, fuel pump, special filling equipment and the installation can easily reach $1000 or more.
FORMER Avenging Moderator of the Apocalypse and Leader of the Axis of Oversteer
"I live with fear every day and sometimes, she lets me race."
2002 SVT Focus... Stock
WeeAsp is offline
Old 09-15-2008, 09:15 PM   #3
viney266
viney266's Avatar
Fan#: 93
What I Drive: focus ztw ,zx3,mustang, motorcycles
Points 236,661, Level 100
Points: 236,661, Level: 100 Points: 236,661, Level: 100 Points: 236,661, Level: 100
Level Up 0% Completed
Forum Activity 3%
FF Reputation: 112 viney266 Excellent Standing Member viney266 Excellent Standing Member
Buy-Sell-Trade Rating: (4)
For what purpose are you considering a fuel cell? And are you having any problems with your existing set-up?
Speed is only a matter of money; how fast do you want to go?
viney266 is offline
Old 09-15-2008, 10:55 PM   #4
slo1
Fan#: 49714
What I Drive: 00 zx3 01 zx3
FF Reputation: 23 slo1 Great Standing Member
Buy-Sell-Trade Rating: (9)
Con- usually requires the vehicle has a bulk head separating the the fuel cell area/trunk from the passenger compartment.
slo1 is offline
Old 09-19-2008, 10:31 AM   #5
Geezer
Fan#: 1427
What I Drive: 99 miata, 05Mazda6, 09GTI, 12Imprez
FF Reputation: 141 Geezer Excellent Standing Member Geezer Excellent Standing Member
Pro/Con....sometimes the sanctioning bodies rules (SCCA, NASA, etc) require them. Pro...in a violent crash the fuel tends to be localize (largely confined to the bladder) and doesn't splash all over the place. Pro....you can locate the cell for better weight distribution and balancing.
Geezer is offline
Similar Threads
Every trouble code defined 03OrangeSVT General Forced Induction 9 05-25-2011 01:53 PM
How To: Return Fuel System Turbo Turtle General Forced Induction 40 01-10-2009 10:00 PM
Fuel cell 1turbofocus Archive 10 08-07-2008 10:56 PM
Stalling at idle in drive, PO457,PO455, any ideas? socrates General Technical Chat 6 06-23-2008 11:21 PM
Turbo ZX3 vs. B16A CRX ZX3_Tun3r General Forced Induction 25 04-28-2008 09:22 PM
