Facts about Acceleration - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Go Back   Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum > Ford Focus Racing Discussions > Drag Racing
Drag Racing The place to discuss information about drag racing stats, tips and events. Track sanctioned events only.
Old 09-12-2008, 06:58 AM   #1
WeeAsp
Resident Curmudgeon
WeeAsp's Avatar
Fan#: 42718
What I Drive: 2002 RED SVT Focus
FF Reputation: 175 WeeAsp Excellent Standing Member WeeAsp Excellent Standing Member
Ever wonder how truly amazing a top fuel dragster is?
Enjoy these little tidbits....
* One Top Fuel dragster outfitted with a 500 cubic-inch Dodge Hemi engine makes more horsepower (8,000 HP) than the first 4 rows at NASCAR's Daytona 500.
* Under full throttle, a dragster engine will consume 11.2 gallons of nitro methane per second; a fully loaded Boeing 747 consumes jet fuel at the same rate but with 25% less energy being produced.
* A stock Dodge Hemi V8 engine cannot pr oduce enough power to merely drive the dragster's supercharger.
* With 3000 CFM of air being rammed in by the supercharger on overdrive, the fuel mixture is compressed into a near-solid form before ignition. Cylinders run on the verge of hydraulic lockup at full throttle.
* At the stoichiometric 1.7:1 air/fuel mixture for nitro methane the flame front temperature measures 7050 degrees F.
* Nitro methane burns yellow. The spectacular white flame seen above the stacks at night is raw burning hydrogen, dissociated from atmospheric water vapor by the searing exhaust gases.
*The exhaust pressure escaping the open header pipes produces 1000 LBS of downforce ALONE.
* Dual magnetos supply 44 amps to each spark plug. Which is typically the output of an electric arc welder in each cylinder.
* Spark plug electrodes are totally consumed during a pass. After 1/2 way thru the run, the engine is 'dieseling' from compression and the glow of the exhaust valves at 1400 degrees F. The engine can only be shut down by cutting the fuel flow.
* If spark momentarily fails early in the run, unburned nitro builds up in the affected cylinders and then explodes with enough sufficient force to blow the cylinder heads off the block in pieces or split the block in half !!
* Dragsters reach over 300 MPH +... before you have completed reading this sentence.
* In order to exceed 300 MPH in 4.5 seconds, a dragster must accelerate an average of over 4 G's. In order to reach 200 MPH well before reaching half-track, at launch the acceleration approaches 8 G's.
* Top Fuel engines turn approximately 540 revolutions from light to light !
* Including the burnout, the engine must only survive 900 revolutions under load.
* The redline is actually quite high at 9500 RPM.
* THE BOTTOM LINE: Assuming all the equipment is paid for, the pit crew is working for free, & NOTHING BLOWS UP, each run will cost an estimated $1,000 per second.
0 to 100 MPH in .8 seconds (the first 60 feet of the run)
0 to 200 MPH in 2.2 seconds (the first 350 feet of the run)
6 g-forces at the starting line (nothing accelerates faster on land)
6 negative g-forces upon deployment of twin 'chutes at 300 MPH
An NHRA Top Fuel Dragster accelerates quicker than any other land vehicle on earth . . quicker than a jet fighter plane . . . quicker than the space shuttle....or snapping your fingers !!
The current Top Fuel dragster elapsed time record is 4.420 seconds for the quarter-mile (2004, Doug Kalitta). The top speed record is 337.58 MPH as measured over the last 66' of the run (2005, Tony Schumacher).
Let's now put this all into perspective:
Imagine this...........You are driving a new $140,000 Lingenfelter twin-turbo powered Corvette Z-06. Over a mile up the road, a Top Fuel dragster is staged & ready to 'launch' down a quarter-mile strip as you pass. You have the advantage of a flying start. You run the 'Vette hard, on up through the gears and blast acro ss the starting line & pass the dragster at an honest 200 MPH.... The 'tree' goes green for both of you at that exact moment.
The dragster departs & starts after you. You keep your foot buried hard to the floor, and suddenly you hear an incredibly brutally screaming whine that seares and pummels your eardrums & within a mere 3 seconds the dragster effortlessly catches & passes you.
He beats you to the finish line, a quarter-mile away from where you just
passed him. Think about it - from a standing start, the dragster had
spotted you 200 MPH....and it not only caught, but nearly blasted you off the planet when he passed you within a mere 1320 foot long race !!!!
That my friends.....is acceleration
FORMER Avenging Moderator of the Apocalypse and Leader of the Axis of Oversteer
"I live with fear every day and sometimes, she lets me race."
2002 SVT Focus... Stock
WeeAsp is offline
Old 09-12-2008, 07:19 AM   #2
joshfink
joshfink's Avatar
Fan#: 50565
What I Drive: Black 2007 ford Focus
FF Reputation: 4 joshfink Good Standing Member
After reading that... Where can I go buy one so I can get to work in about 1.5 minutes?
"Whoopie! That may have been a small one for Neil but it was a long one for me!" - Pete Conrad stepping off the LEM onto the lunar surface during Apollo 12.
joshfink is offline
Old 09-12-2008, 09:04 AM   #3
HyBalz
HyBalz's Avatar
Fan#: 18573
What I Drive: 2000 Silver ZX3
FF Reputation: 49 HyBalz Great Standing Member
Buy-Sell-Trade Rating: (14)
And just think, it all started something like this: "My car's faster than your's." "Is not!" "Wanna bet?" "Let's race!"
"I aim to misbehave"-Malcolm Reynolds
HyBalz is offline
Old 09-12-2008, 09:11 AM   #4
nov173
nov173's Avatar
Fan#: 29840
What I Drive: 2014 Focus ST
FF Reputation: 79 nov173 Excellent Standing Member
Buy-Sell-Trade Rating: (4)
now its a multi million dollar industry... crazy. But's it's amazing to see them in action.
SVT header kit, 2.25 MBRP cat-back & flex, r/t high flow cat. aem cai, frpp kit
For Sale: Rear bumper(stock). SVT side skirts FS as well. Buy em!!!!
nov173 is offline
Old 09-12-2008, 10:29 AM   #5
Fordcus Fan
Fan#: 31604
What I Drive: Blue 2014 twin turbo F150 Limited
Points 674, Level 13
Points: 674, Level: 13 Points: 674, Level: 13 Points: 674, Level: 13
Level Up 48% Completed
Level up: 48% Level up: 48% Level up: 48%
FF Reputation: 3 Fordcus Fan Good Standing Member
Buy-Sell-Trade Rating: (11)
Gives new meaning to supercharger vs turbo charger, twin turbos even.
I don't need training wheels.
(AWD,Traction control,Stability control,Launch assist,Autotrans,Paddle shifters). Got my driving skills driving front/rear wheel drive high performance cars on the street for the last 40 years.
Fordcus Fan is offline
Old 09-12-2008, 11:01 AM   #6
HaveBlue83
Guest
Fan#: 1358
What I Drive: a car
FF Reputation: 70 HaveBlue83 Excellent Standing Member
Buy-Sell-Trade Rating: (12)
so a Roots Blower is better........where's Tom?????
........just kidding with ya Tom.....hehe..
AWESOME FACTS......I am saving that.....
HaveBlue83 is offline
Old 09-12-2008, 04:32 PM   #7
Insane
Adam
Insane's Avatar
Fan#: 51468
What I Drive: 2003 Infra Red ZX3
FF Reputation: 41 Insane Great Standing Member
This is Insane.
http://www.youtube.com/watch?v=ws6gseaIIJU
-Zetec Crew #215
Volant Intake, SVT Snorkle, By past A/C, AFX UDP, Copper Plugs, 9mm Plug Wires, Toms Tune, Roush springs/shocks/struts, Eibach Sway-Bars, C-F-M Racing Lower Engine Mount.
Insane is offline
Old 09-13-2008, 12:47 AM   #8
Wagamos
Stock
Wagamos's Avatar
Fan#: 21396
What I Drive: 2001 Malibu Blue ZX3; 03 ZX3 PZEV
Points 9,489, Level 65
Points: 9,489, Level: 65 Points: 9,489, Level: 65 Points: 9,489, Level: 65
Level Up 47% Completed
FF Reputation: 13 Wagamos Great Standing Member
^^ Very interesting.
Bone Stock
223whp/218wtq
Wagamos is offline
Old 09-13-2008, 01:01 AM   #9
j-zetec_pr
Machinery Technician
j-zetec_pr's Avatar
Fan#: 47101
What I Drive: 2000 Silver ZX3 Kona, MTX-75, Zetec
Points 45,167, Level 100
Points: 45,167, Level: 100 Points: 45,167, Level: 100 Points: 45,167, Level: 100
Level Up 0% Completed
Forum Activity 2%
FF Reputation: 27 j-zetec_pr Great Standing Member
Buy-Sell-Trade Rating: (9)
those cars really are truly amazing.. does that record ET still stand ?
Carpe diem quam minimum credula postero
ODOMETER: 169,000 miles
j-zetec_pr is offline
Old 09-13-2008, 01:34 AM   #10
pistolgripbmx
pistolgripbmx's Avatar
Fan#: 49331
What I Drive: 86 ranger, 2007 focus zx3 s
FF Reputation: 38 pistolgripbmx Great Standing Member
Buy-Sell-Trade Rating: (8)
check out the fuel consumption per cylinder.
http://www.youtube.com/watch?v=T5lrM...eature=related
crazy stuff, I love watchin those cars race.
teamduratec #143!
focus sport cool-flo, f2 v.3 header, trubendz 2.5 SS, frpp 1.5" front sportline rear, vf rear engine mount, 93oct Focus Power tune
pistolgripbmx is offline
Similar Threads
Need some input for more acceleration!!! teamrc49 Ford Focus & General Car Chat 2 05-07-2007 03:18 PM
Loss of acceleration uphill, hesistation, engine light.. -diVe- General Technical Chat 7 05-30-2006 09:51 PM
I have lost my acceleration......help stxen12 ZETEC Performance (2000-2004) 16 06-12-2004 12:21 PM
