Window Regulator Replacement Guide - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 09-04-2008, 11:37 PM   #1
danovotny
Fan#: 58998
What I Drive: N/A
FF Reputation: 7 danovotny Good Standing Member
Arrow Window Regulator Replacement Guide
Hello! First off, I want to thank everyone for giving me the confidence to perform this task. I had initially thought the window regulator would be too hard to replace. After reading several posts, most stated that it was very easy to do. I decided to follow the various descriptions and instruction to successfully install the new regulator. Several posts had requested pictures and a guide for the job. I decided to document the process and make a PDF for it. Hopefully others will find this guide useful and give them the confidence to save some money and gain a greater appreciation for the inner workings of their car. Any feedback and comments are welcome. Thanks again!
PDF Download
danovotny is offline
Old 09-05-2008, 01:40 AM   #2
networkalias
Fan#: 58828
What I Drive: 2000 Emerald Green ZTS
FF Reputation: 1 networkalias Good Standing Member
Thanks danovotny! I'lll give it another try. I've been driving around with a custom cut piece of wood stuck in the door to keep the window up.
networkalias is offline
Old 09-05-2008, 01:45 AM   #3
mikebontoft
Aurelius Pardus
mikebontoft's Avatar
Fan#: 58647
Points 23,646, Level 94
Points: 23,646, Level: 94 Points: 23,646, Level: 94 Points: 23,646, Level: 94
Level Up 30% Completed
Forum Activity 14%
hey danovotny.......I guess you had trouble with your windows then since you're a sedan.... tell me, did they even work and all that? like, did the motor work? I've got that problem where both rear windows don't open and all that; tried to replace the motor, but there's not enough power going to it, if any. I'll look at the how-to of course
mikebontoft is online now
Old 09-05-2008, 02:02 AM   #4
grahama
grahama's Avatar
Fan#: 20127
What I Drive: 2003 Black ZTW
FF Reputation: 1 grahama Good Standing Member
nice write up! will be doing this to my wagon in the near future. Any tips for doing the front regulators?
grahama is offline
Old 09-05-2008, 02:38 AM   #5
mikebontoft
Aurelius Pardus
Fan#: 58647
Forum Activity 14%
front regulators should be the same, except I think there's one less torx screw in the panel, and of course it's all backwards......the rest should be the same :)
Old 09-05-2008, 08:21 AM   #6
danovotny
Fan#: 58998
What I Drive: N/A
In my case, the motor was still functional, but the cable had come disconnected from the clip. When I would press the button to roll the window up and down, I would hear the motor turn over, but since the cable was broken, the white clip and the window would not move at all.
I can't speak from experience, as I have only done the back ones. I would make the same assumption that mikebontoft did, that they shouldbe the same.
Old 09-05-2008, 05:22 PM   #7
mikebontoft
Aurelius Pardus
Fan#: 58647
Forum Activity 14%
ah yeah see.....when I try, I get nothing... thankfully to a school funded alldata pro subscription, I can figure out what it is :)
Old 09-07-2008, 01:23 AM   #8
danovotny
Fan#: 58998
What I Drive: N/A
So, I had my replacement job fail me today. When I tried to roll down the window, the track went down, but the window didn't follow. I had made certain that the window was tightly fitted into the white clip. Did I miss something like a clip or bolt that attached the window to the clip? There was no pin joining the regulator clip and window as I have heard described in other posts?
Old 09-07-2008, 03:31 PM   #9
mikebontoft
Aurelius Pardus
Fan#: 58647
Forum Activity 14%
yeah Haynes manual says there's a pin of some sort, so you might want to investigate that and probably get a replacement
Old 09-07-2008, 03:49 PM   #10
Kauai Guy
/人◕ ‿‿ ◕人\
Kauai Guy's Avatar
Fan#: 58297
What I Drive: Car
Points 6,484, Level 52
Points: 6,484, Level: 52 Points: 6,484, Level: 52 Points: 6,484, Level: 52
Level Up 67% Completed
FF Reputation: 17 Kauai Guy Great Standing Member
Buy-Sell-Trade Rating: (17)
The pin is actually this white cylinder with a little cut in it, with a smaller cylinder inside of it.
It probably fell in the door somewhere. The hard part is getting that white clip in. What i did was put the larger one in first to hold the window, and put the smaller one in.
Kauai Guy is offline
Similar Threads
Broken Rear Window refemall MK1 Focus 6 02-02-2011 08:29 PM
Water Inside the car WTF!! akmer General Technical Chat 3 08-19-2007 09:49 AM
DTC Codes (Detailed Descriptions) S2 General Technical Chat 13 12-11-2006 12:06 PM
window smudge help ChaoticJello Auto Washing, Detailing & Paint Protection 8 02-22-2006 03:46 PM
My Window shattered! focuson03 Ford Focus & General Car Chat 8 10-03-2005 06:26 PM
