How To: SVT Fog Light Protection w/Lexan - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Go Back   Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum > Ford Focus SVT > Focus SVT
Focus SVT The place to chat about general questions, window tinting, exterior body, interior and lighting upgrades for the MK1 2002-2004 Focus SVT.
Old 09-04-2008, 01:25 PM   #1
..:: sleestak ::..
on thin air
..:: sleestak ::..'s Avatar
Fan#: 22528
What I Drive: 04 Forester XTi
Points 14,700, Level 78
Points: 14,700, Level: 78 Points: 14,700, Level: 78 Points: 14,700, Level: 78
Level Up 63% Completed
FF Reputation: 80 ..:: sleestak ::.. Excellent Standing Member
Buy-Sell-Trade Rating: (15)
After replacing many fog lights to rock breakage and severe pitting, I decided I needed to come up with a good way to protect them. 20mil Laminex came to mind, but I have heard that the lenses can still break when hit by a decent sized rock and I knew there had to be a better, cheaper, and more durable than just a sheet of vinyl that adheres directly to the lens.
While talking with Mike @ Hillbish, he recommended rigging something up out of Lexan (thanks for that tip!). So, I stopped off at home depot on my way home.
I had no idea what I was in store for with this project. I expected to get home, pull the fogs and then come up with a plan and a list of addl supplies. But I was pleasantly surprised as things progress, at how simple and effective this really is.
Why Lexan?
  • Lexan is significantly stronger than glass, plastic, or vinyl. Some Uses of Lexan
  • It's UV coated and will resist yellowing for 10 years.
  • It is heat resistant and withstand the temps of your fogs
  • Easy to work with - just add dremmel
  • It's Cheap - and that's always nice
What You Will Need
  • Dremmel w/ a cutter bit and sander bit (see below)
  • 1 sheet Lexan - 8" x 10" .093
  • 7mm socket or wrench
Cost:
Lexan cost me $3.88 @ the HomeDepot
Dremmel Bits
Here are pics of the two bits I used w/ the Dremmel:
I used a cutter like this, my blades were straight though, not spiraled. Although this would probably work fine.
Just a basic sander bit.
Directions
First thing is first, you may want a little extra wiggle room under the bumper, so you will want to slightly jack each side of the car to give you a little more room to work. Then grab a 7mm socket (pref on a screwdriver type handle if you can), or wrench and get under the bumper.
The fog lights are held to a bracket with some metal screws (7mm hex head). Skip these and go right for the bracket itself...it screws to the back of the bumper with 3 - 7mm screws as well. You will see two at the bottom of the bumper and the other is up top, you have to feel for it.
Unscrew these three screws and bring the whole assembly out - bracket and fog. Then take the fog light off the bracket. What you should have is something looking like this (minus the cute dog):
Now go back and sit in front of the bumper and hold the bracket back in place to get an idea of what you are doing.
You will see that the diameter of the bracket is slightly larger than the opening in the bumper. This line shows the edge of the bumper opening.(Sorry for the crappy pic)
What you are going to do is just simply cut a piece of Lexan to sandwich in between the bracket and the bumper ... thats it!
So, place the bracket onto the sheet of lexan and trace the inside. Be sure to take note of the print on the lexan protective sheet. You want the NON-PRINTED SIDE FACING OUT. It has the UV protection. You might also want to mark the top.
Next (with the protetive plastic still on the Lexan) cut the Lexan with the cutter bit. Try to leave the line while cutting then clean up your edges with the sander drum and test fit. You want the Lexan to just fit into the opening of the bracket. The brackets opening is a tiny bit tapered, so you should only be able to push it back in there a little ways, so start big and shave it down a bit till it fits snug.
Here is mine with the protective film off and seated in the bracket. (no those aren't cracks, its a reflection)
Now that it fits good and snug, just pop your fog back into the back of the bracket and screw it in. The entire assembly should look like so:
Now re-install the entire assembly. Be careful to keep the Lexan in place while popping it in. Don't worry about tacking it in place. Once you screw the bracket into the bumper, it will be held firmly in place and look like this:
Note that you can't even see the Lexan in this pic (and yes my car is dirty). The finish is very clean and looks completely stock. You can hit the Lexan with your finger in the corners and see that it is held snugly in place between the bracket and the bumper. You should also have a good 1/4" of space between the Lexan and your fog! So even if that Lexan takes a good hit, the lens should not be effected at all.
Now just repeat the process for the other side and you are done.
Here they are installed. Looks damn good, if I may say so myself. Now all I need are a new set of headlights!
*Note * I am sure that over time the Lexan will get chewed up by rocks and dirt that gets throw on the road here in the winter. But consider that this took me about 30min per light and cost me $3.88 I think I won't mind replacing these Lexan bits vs two new $50 fog lights.
Hope this helps you guys out there who are getting tired of shelling out money for these fogs.
Cheers!
..:: sleestak ::..
"Our mother of blessed accelleration, dont fail us now!" -- Elwood Blues
..:: sleestak ::.. is online now
Old 09-04-2008, 01:39 PM   #2
lunarc
lunarc's Avatar
Fan#: 343
What I Drive: 02' Silver SVT RIP 2007
Points 4,212, Level 41
Points: 4,212, Level: 41 Points: 4,212, Level: 41 Points: 4,212, Level: 41
Level Up 31% Completed
Level up: 31% Level up: 31% Level up: 31%
FF Reputation: 1 lunarc Good Standing Member
Buy-Sell-Trade Rating: (13)
Nice dude! I am amazed how easy that is! Way to go tiger.
-------RIP 01-01-08--------
2002 SVT Focus #1848
New ride E36 DINAN BMW, Dinan CAI, Dinan Exhaust, Dinan Stg1 Suspension, Dinan Stg1 Chip
lunarc is offline
Old 09-04-2008, 01:44 PM   #3
AerofurySC
AerofurySC's Avatar
Fan#: 31835
What I Drive: 2003 Comp Orange SVT Euro
FF Reputation: 29 AerofurySC Great Standing Member
Buy-Sell-Trade Rating: (11)
Good writeup! Thats a good alternative to Lamin-X and considerably stronger. Rep +
AerofurySC is offline
Old 09-04-2008, 03:14 PM   #4
..:: sleestak ::..
on thin air
Fan#: 22528
Thanks Josh, I appreciate the rep! I think this set up is far superior to laminx for fogs...headlights, I think the Laminx would still be the way to go.
Other things to add here are that you can smoke out the Lexan with NiteShades for a tinted look, or some other colored paint for the desired effect, and easily return it back to clear if you dont like it.
..:: sleestak ::..
Old 09-04-2008, 04:03 PM   #5
macdiesel
I used to drive this
macdiesel's Avatar
Fan#: 31579
What I Drive: 2010 red mazdaspeed3 w/tech package
Points 4,228, Level 41
Points: 4,228, Level: 41 Points: 4,228, Level: 41 Points: 4,228, Level: 41
Level Up 39% Completed
Forum Activity 4%
FF Reputation: 22 macdiesel Great Standing Member
Buy-Sell-Trade Rating: (17)
Cool mod. Did a similair thing with metal leaf gaurds for track days, except I took my lights out. The Lexan looks soo transparent. Hopefully the foglight won't get too dirty back there.
I now drive a Japanese Ford.
macdiesel is offline
Old 09-04-2008, 04:12 PM   #6
scrammer
scrammer's Avatar
Fan#: 26570
What I Drive: February 2010 ROTM
FF Reputation: 172 scrammer Excellent Standing Member scrammer Excellent Standing Member
Buy-Sell-Trade Rating: (29)
i thought about this the other day and rememberd how easily lexan is scratched. i already have laminx, so im good.
++ for a great job and execution though
scrammer is offline
Old 09-04-2008, 04:20 PM   #7
Sn4ckM4st3r
Fan#: 24432
What I Drive: 2002 Stealth ZX3
FF Reputation: 91 Sn4ckM4st3r Excellent Standing Member
Buy-Sell-Trade Rating: (4)
Nice job man i dont have them but def a nice fix. Laminx them and you would be MORE than set.
good work and good thinking
Sn4ckM4st3r is offline
Old 09-04-2008, 04:22 PM   #8
..:: sleestak ::..
on thin air
Fan#: 22528
Scratches I can deal with, since I plan on just swapping them out once a year. Its the breakage that I cant deal with anymore. Thanks for the kudos
..:: sleestak ::..
Old 09-04-2008, 05:53 PM   #9
cbrenn71
cbrenn71's Avatar
Fan#: 30613
What I Drive: 2003 Black ZX3, 2000 Dodge Durango
Points 7,037, Level 55
Points: 7,037, Level: 55 Points: 7,037, Level: 55 Points: 7,037, Level: 55
Level Up 44% Completed
FF Reputation: 5 cbrenn71 Good Standing Member
Buy-Sell-Trade Rating: (21)
sleestak - good idea!
now, i know you aren't looking to lamin-x, but keep in mind, Lamin-X is self-healing/annealing.... meaning that it will heal itself if it is cut/punctured by a stone/rock.
It is also easily polished. It may be a good addition to this mod, as a means to keep it from having to be replaced.
cbrenn71 is offline
Old 09-04-2008, 06:59 PM   #10
..:: sleestak ::..
on thin air
Fan#: 22528
Well I just ordered up a new set of TYC headlights - look just like the stock svt's w/ black housing. I am gonna laminX those for sure.
I just figured that LaminX alone would not take the abuse of the winter conditions here. They throw gravel (read "Small Boulders") all over the place and it never gets cleaned up. I get giant holes through the lenses all the time and I am sure the LaminX might stop the hole from happening, but def not a crack. I might consider throwing some on the Lexan though.
..:: sleestak ::..
Similar Threads
svt fog light josejsanchez Focus SVT 6 06-01-2008 10:52 AM
2009 Ford Focus Coupe Unveiling at 12:01AM EST Tom Ford Focus & General Car Chat 97 05-13-2008 07:34 PM
WTB: A/C condenser, SVT fog light and passengerside mountng, lower radiator support, 2002_zts Archive 2 10-13-2006 12:34 AM
WTB: passenger side svt fog light.... my 2003SVT Archive 1 02-27-2006 12:03 PM
Soon to come, more SVT parts for your non-SVT Focus... myFordPerformance.com ZETEC Performance (2000-2004) 32 05-02-2004 05:31 PM
