08 Short Shifter Installed !! - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Go Back   Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum > Ford Focus Second Generation > DURATEC Performance (2008-2011)
DURATEC Performance (2008-2011) The place to chat about any Duratec 20 engine performance, tuning and exhaust related upgrades.
Old 09-04-2008, 12:46 AM   #1
BradWhite
Head Hurt
BradWhite's Avatar
Fan#: 54975
What I Drive: 08 Sedan SE Vista Blue
FF Reputation: 174 BradWhite Excellent Standing Member BradWhite Excellent Standing Member
I received and installed my F2USA short shifter in my 08' Sedan today.
The install was straight forward with no issues. The only modification to be made was to the boot, and that was a simple modification.
Does it work? Yes! This is not simply a shorter stick, the shift pattern is much tighter now. Try this with the stock stick, put the stick in neutral with your hand resting comfortably on the shift knob. Now plant your elbow on the center console and try going through the shift pattern without moving your elbow. I'm betting you can't do it. With the F2USA short shifter I can go through the entire gear pattern without my elbow moving at all. Just a flick of the wrist.
The included instructions where good and got me through it, but I wrote these to make is as straight forward as possible for 08' owners.
ITEM: F2USA Short Shifter can be located HERE.
DO NOT confuse these with the Focus Short Shifters available on Ebay which I have confirmed through F2 are knockoffs, probably from China. Other FF members have reported quality issues with these. If you want quality buy U.S.A.
The shifter as pictured on there web-site is not exactly what you will receive. See picture below, the pieces in RED are not included.
COST: $97.17 shipped
Tools Required:
Phillips screw driver
d-ring pliers helpful but not required
long nose pliers
hex key set
Time Required: 1 - 2 hours for install, 3 - 4 hours to write it up
Instructions:
remove center console top trim piece, to do so;
1. Lift the park brake lever upward. (as high as possible)
2. Place the vehicle in NEUTRAL.
3. Unscrew and remove the gearshift knob.
4. Lift the floor console storage compartment door.
5. Remove the floor console finish panel by;
  • Lifting upward on the rear of the floor console finish panel to release the floor console finish panel clips.
  • If equipped, disconnect the electrical connector.
  • Slide the park brake lever boot and the floor console finish panel over the park brake lever.
Next;
Remove the two shifter cables by gently prying them off of their posts.
The shifter cables are shown below
Remove the four Phillips screws from the shifter base
Remove the shifter and base, leaving all other stock parts in place.
It's easier to replace the stock bushings with those included with the kit now, then when they bring it up in their instructions.
The new blue pieces are shown in this picture. (the top right one is hiding)
Do so by;
1. remove the four nuts located around the entire shifter base.
2. remove the metal bushing located under those nuts
3. remove the rubber grommets (a solid grip with needle nose pliers and a slow and steady pull will get them out of there).
4. install the four new pieces included in the kit, the smaller side goes down.
5. re-install the nuts.
Remove the shifter cable arm on the stock shifter to allow you to remove the shifter base.
Remove the shifter cable arm on the F2 (D-ring and set screw)
Place the base on that. (pay attention and get it right side up)
Replace the shifter cable arm on the F2, there is a clear indent in the arm for the set screw so the arm will be correctly positioned (don't forget to replace the D-ring).
Remove the "C" collar from the bottom of the old shifter, that's the piece covered in white grease at the very bottom of the stock shifter.
Place this collar on the F2 positioned so that the flat spot will be facing the front of the car when installed.
Install the F2 in your car. Ensure the the arm with the nylon bushing is inserted into the shift linkage on the drivers side. The RED circle below is the shift linkage. Note: The shift cable bracket on the right side has a metal tab sticking down, (YELLOW circle) that should be positioned between the two white pieces located there. Be gentle you can push those white pieces out of position.
Re-install the shifter base
Check for proper shifting, including reverse.
If everything is fine, continue - if not check for errors, correct and re-check shifting.
When all is well in Focus land re-install the console top trim. Start from the front and work your way back. Make sure all tabs on the trim are inside the console. I did one side at a time and it worked great.
Now all that's left is to modify the shifter boot. Very simple.
Turn the boot inside out and trim as pictured below.
BEFORE
AFTER I left one inch of the original tube, you can trim it flush if you need to
Install the boot and shift knob and you're done.
Here's my completed installation.
And here's your new short shifter in action
If I missed something or can clarify anything, please do not hesitate to let me know.
Best wishes and keep on modding April 2009 SOTM, July 2009 ROTM, 2009 FF ROTY
RIFF CREW, Sedan Revolution #137, TEAM Duratec #181, Bremerton Raceway #658, NW POSSE #6
BradWhite is offline
Old 09-04-2008, 12:57 AM   #2
norcalfocus01
Fan#: 55603
Buy-Sell-Trade Rating: (12)
nice brad looks good, did you get that blue carbonfiber pannels aftermarket or OEM?
norcalfocus01 is offline
Old 09-04-2008, 01:24 AM   #3
BradWhite
Head Hurt
BradWhite's Avatar
Fan#: 54975
Thanks, and that's an aftermarket dash overlay kit. You can read about it HERE if you're interested.
Brad
Old 09-04-2008, 01:52 AM   #4
loudfocus01
loudfocus01's Avatar
Fan#: 26006
What I Drive: 2001 White LX 2002 Infra-Red Svt
FF Reputation: 107 loudfocus01 Excellent Standing Member loudfocus01 Excellent Standing Member
Buy-Sell-Trade Rating: (17)
Awsome write up man. I bet you are loving the new short shifter.
O'Reilly Auto Parts
Store Manager
Oak Grove, MO
loudfocus01 is offline
Old 09-04-2008, 01:58 AM   #5
BradWhite
Head Hurt
BradWhite's Avatar
Fan#: 54975
I'm looking for an excuse to drive to the store right now!! Oh wait, the light bulb in the refrigerator is burned out. I'll be back in 20 minutes !!
Old 09-04-2008, 02:16 AM   #6
captcurt_18
captcurt_18's Avatar
Fan#: 49565
What I Drive: 2005 Light Tundra ZX4
FF Reputation: 26 captcurt_18 Great Standing Member
good write up brad. there was a lot of concern that this was just a shorter shift arm, not an actual sts. way to prove us wrong lol
2005 Light Tundra ZX4 2002 BMW 325xi
Sedan Revolution Member #120
University of Montana
Photoshop Guru! PM me if you need something chopped up
Give me rep if im helpful!
captcurt_18 is offline
Old 09-04-2008, 03:09 AM   #7
N2O Focus
N2O Focus's Avatar
Fan#: 37645
What I Drive: 2004 Yellow Saleen Focus ZX3
FF Reputation: 53 N2O Focus Excellent Standing Member
Buy-Sell-Trade Rating: (9)
How much lower did it drop the knob?
Who Rides The Short Bus?
Originally Posted by the_07ninja View Post
my car's weight is 2546lb w/ me in the car and some crap in my pants.
N2O Focus is offline
Old 09-04-2008, 03:21 AM   #8
08sesfocus
08sesfocus's Avatar
Fan#: 53462
What I Drive: 2008 white SES
FF Reputation: 17 08sesfocus Great Standing Member
damn now that ive seen it installed im gonna order it right now. nice writeup brad
2008 Focus SES / 5 speed / Team Duratec #177
STEEDA SRI
custom 2.5 exhaust in the near future
REP points are always appreciated if i mange to help anyone
08sesfocus is offline
Old 09-04-2008, 07:25 AM   #9
Buickboy
br/o/stang
Buickboy's Avatar
Fan#: 28542
What I Drive: 72 Skylark, '12 Mustang
Points 28,213, Level 98
Points: 28,213, Level: 98 Points: 28,213, Level: 98 Points: 28,213, Level: 98
Level Up 87% Completed
Level up: 87% Level up: 87% Level up: 87%
Forum Activity 3%
FF Reputation: 39 Buickboy Great Standing Member
Buy-Sell-Trade Rating: (29)
Great write-up!
for anyone whos interested, F2 shifter = ebay. Go there and save some money, hopefully the quality is better now because before it seemed to be hit or miss.
==2012 Kona Blue Mustang V6==
==1995 Light Iris Neon Coupe==
==1972 Skylark==
Buickboy is offline
Old 09-04-2008, 11:22 AM   #10
the_07ninja
Gal. 2:20
the_07ninja's Avatar
Fan#: 45089
What I Drive: 07 ZX3 some red color.
FF Reputation: 88 the_07ninja Excellent Standing Member
nice write up. I just ordered mine and I don't even have an 08, Damn Brad your that good, to make me wanna buy something that I don't need, can't afford, and even w/ the write up will prolly screw something up.
Team Duratec #36
RIFF crew /
L.O.T.H #69 baby
Originally Posted by jhurst747 View Post
Any man comfortable enough to use Vanilla Ice as his avatar is my hero.
the_07ninja is offline
Similar Threads
Short shifter and MonsterKnob mod done 07SES MK1 Interior Mods & Upgrades 4 10-08-2006 08:35 AM
Just installed my short throw shifter! 04CD4mee SVT Performance (2002-2004) 7 04-21-2005 09:03 PM
short shifter problem totalfocus ZETEC Performance (2000-2004) 3 03-21-2005 03:33 PM
New Shifter Knob..Killed my short shifter? jb10fan Ford Focus & General Car Chat 16 08-21-2004 02:27 PM
Which Short Shifter? silverfoci ZETEC Performance (2000-2004) 7 09-15-2003 11:21 PM
