focus won't start. thinking ECU problem, can anyone help??? - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 08-28-2008, 08:33 AM   #1
ferkozx3
ferkozx3's Avatar
Fan#: 52995
What I Drive: 2004, green, focus zx3
FF Reputation: 2 ferkozx3 Good Standing Member
ok, let me start from the very beginning. i had recently took my motor out and rebuilt it, at the same time i purchased a SCT2 tune device, before i even started the car for the 'first' time i was messin around with the tuner. the first time i went to start it, it wouldnt start. its a 5 speed manual and it was like i just didnt have the clutch in or something. so after a few days i had remembered i messed around with the tuner, so i reset it all to stock and the car started right up. about 2-3 days later it did the came thing, so i reset it again. and than finally last night while out, i hooked up the SCT2 to check some stuff out and the screen went to just blue, and the car did it again. so right now the car wont start, all the dash lights come on and everything but the car does not start. my uncle and his friend own tha "snap-on" MODIS and if anyone knows what they are, its a 12,000 ECU module. and when they hooked it up, it basically read as it it wasnt plugged in, not reading the ECU at all, it read all the body systems but nothing with the engine PCM.
can anybody help me at all???
i miss boost....
ferkozx3 is offline
Old 08-28-2008, 08:40 AM   #2
1turbofocus
FF Affiliate
1turbofocus's Avatar
Fan#: 1123
Points 51,876, Level 100
Points: 51,876, Level: 100 Points: 51,876, Level: 100 Points: 51,876, Level: 100
Level Up 0% Completed
Forum Activity 30%
Buy-Sell-Trade Rating: (28)
Make sure you have restored the origional backup or gone back to stock with the tuner
Make sure the ground wire beside the batt is hooked up and grounded good small wire going to the ground
You have a ECU fuse as well you might want to check
do you have - - - - - on the odometer
What is you PATS light doing the small flashing light over your 4-way flasher switch
Customer Support
AIM: hpdyno
Email: hpdyno@aol.com
Phone: 704-249-3745
Site: focus-power.com
Elder 1turbofocus
1turbofocus is online now
Old 08-28-2008, 10:40 AM   #3
bluefront
bluefront's Avatar
Fan#: 56816
What I Drive: 2006 white ZX5 SES
FF Reputation: 146 bluefront Excellent Standing Member bluefront Excellent Standing Member
Buy-Sell-Trade Rating: (6)
I've seen the same symptom on several cars that would not start. When you hook up an OBDII reader to the system, and it cannot read the codes (assuming the code reader is good), it usually means.....a fuse for the ECU is blown, or a relay supplying power to the ECU is not working for some reason.
A bad ECU is possible, but that's rarely the problem. Of course since you were in the system with your mods, anything is possible......
bluefront is offline
Old 08-28-2008, 06:31 PM   #4
ferkozx3
ferkozx3's Avatar
Fan#: 52995
yes the odometer is reading -------- .
i miss boost....
ferkozx3 is offline
Old 08-28-2008, 07:45 PM   #5
1turbofocus
FF Affiliate
Fan#: 1123
Forum Activity 30%
Ok, If you cannot restory your origional backup and the fuse for the ECU is good and all grounds are good then you will have to have the PATS reset
What is the light above the 4-way flashers doing blink-blink-blink-blink or blink-blink........blink-blink or blink.....blink.....blink.....blink
This light is directly related to how the ECU is communicating with the PATS
Customer Support
AIM: hpdyno
Phone: 704-249-3745
Elder 1turbofocus
Old 08-31-2008, 11:41 PM   #6
06Roush
Fan#: 45862
What I Drive: Frankenstien
FF Reputation: 60 06Roush Excellent Standing Member
tom more info please. mine is doing the same thing _----- on the odomiter. flashes normaly until i try to start it then it just stays on no flashing at all. what should i do?
06Roush is offline
Old 09-01-2008, 08:35 AM   #7
1turbofocus
FF Affiliate
Fan#: 1123
Forum Activity 30%
Dont know what did you do to get the - - - - to come up
What the ------ mean is the ECU is not talking with the key so it could be many things first I need to know what caused it
Customer Support
AIM: hpdyno
Phone: 704-249-3745
Elder 1turbofocus
Old 09-01-2008, 08:37 AM   #8
dullishpage
dullishpage's Avatar
Fan#: 32500
What I Drive: 2006 Ford Focus ZX4 Sonic Blue
FF Reputation: 40 dullishpage Great Standing Member
what I posted was dumb i censored it. -- just ignore me
SEDAN REVOLUTION No. 92
Originally Posted by dullishpage View Post
I Am The Winner! I WIN BECAUSE I DID IT WITH MY MIND.
dullishpage is offline
Old 09-01-2008, 12:03 PM   #9
SlimShady
SlimShady's Avatar
Fan#: 20822
What I Drive: '13 Oxford White ST3, '02 ZX3
FF Reputation: 2 SlimShady Good Standing Member
when i had the ------ i missed one ground wire.
make sure all the grounds are there, one that is not connected can cause this problem.
2013 Ford Focus ST3 Oxford White ->241whp/298wtq<-
AccessPort w/ Cobb Stage 1 tune // Cobb Intake // Cobb Catback
2002 Focus ZX3 Turbo (work in progress)
SlimShady is offline
Old 09-01-2008, 12:05 PM   #10
06Roush
Fan#: 45862
ok tom all i did was move the wireing harness for the headlights, horn, foglights, side markers, and oddly the hood latch. and ran them threw the feder. went to start the car back up every thing works fine. all the lights work horn works. but when i go to start the car i just get ------- and no noise out of it.
06Roush is offline
Similar Threads
Weird Problem with 2001 Focus onedangerouswookie General Technical Chat 2 05-17-2007 09:31 AM
2008 Focus TimHickey Ford Focus & General Car Chat 5 01-11-2007 01:51 PM
Focus Zetec and Duratec ECU chips... gthang Ford Focus & General Car Chat 3 08-04-2005 03:14 PM
Couldn't start my Focus this morning... gthang Ford Focus & General Car Chat 6 08-19-2004 06:25 PM
