ZETEC Timing Belt Replacement - Page 7 - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 05-18-2010, 02:54 AM   #61
sailor
Elder
sailor's Avatar
Fan#: 57268
Points 13,377, Level 75
Points: 13,377, Level: 75 Points: 13,377, Level: 75 Points: 13,377, Level: 75
Level Up 32% Completed
Forum Activity 99%
Posted via FF MobileSounds good, like to rotate once by hand to recheck without chancing damage.
sailor is online now
Old 05-18-2010, 03:53 AM   #62
Missourileo
Captain Retard
Missourileo's Avatar
Fan#: 55980
What I Drive: 2002 Black SVT ZX3,93 SVT Lightning
Points 5,373, Level 47
Points: 5,373, Level: 47 Points: 5,373, Level: 47 Points: 5,373, Level: 47
Level Up 12% Completed
FF Reputation: 20 Missourileo Great Standing Member
Buy-Sell-Trade Rating: (17)
Sounds like you got it together. Good job.
"It's the Veteran who salutes the flag, serves beneath the flag, and whose coffin is draped by the flag."
Midwest crew #36
Hatch Nation#50
January 2010 ROTM
Missourileo is offline
Old 05-18-2010, 07:01 AM   #63
RickNC
RickNC's Avatar
Fan#: 38833
What I Drive: Focus
FF Reputation: 1 RickNC Good Standing Member
I rotated it a few times clockwise and all looks good. Nice and tight. The OP here didn't loosen his cam gears but it was recommended and I can see why now. I did that step.
RickNC is offline
Old 05-18-2010, 07:07 AM   #64
Missourileo
Captain Retard
Fan#: 55980
Excellent. I'm glad to hear all went well.
Midwest crew #36
Hatch Nation#50
January 2010 ROTM
Old 05-18-2010, 05:35 PM   #65
RickNC
RickNC's Avatar
Fan#: 38833
What I Drive: Focus
Here are my thoughts on this job. It isn't hard if you have some experience wrenching. I was really only confused about the timing aspect of it, but turns out it was very simple with the tools.
The bar works well to hold the cams in place. I found this out after trying to do it with a wrench with little success. You may have to turn the cams 360 degrees to get the bar inserted into the slots. Took me a bit to figure that out.
You need a good selection of tools. This took me longer than it should have because I had to order the timing tools and had to run and pick up a tool here and there. I found I was short on things like torx and star bits. I also had to find an impact wrench to remove the crank bolt. Also, I had to wait on some parts from the Ford dealer (pulley).
This writeup thread was very helpful. I recommend breaking the cam sprockets loose though. I also found it much easier to start the belt on the cams and slip it over the crank pulley. Everything I read said to start at the crank. Like I said, not that bad of a job really. I also own an SVT so hopefully when time comes for that I can do it in a fraction of the time. I think this is really only a few hours worth of work if you have everything on hand and have done it before.
RickNC is offline
Old 06-08-2010, 09:29 AM   #66
Jon_SVT
Jon_SVT's Avatar
Fan#: 34787
What I Drive: 2002 Silver SVT Focus
Points 639, Level 12
Points: 639, Level: 12 Points: 639, Level: 12 Points: 639, Level: 12
Level Up 78% Completed
FF Reputation: 2 Jon_SVT Good Standing Member
Exclamation
Question to anyone out there:
we got pretty much everything in, new timing belt, new water pump, pulleys, tensioners etc but we made a boo-boo.... stripped the hole where the water pump screws go into the block. The hole is F'd but the screw is fine...... any suggestions on what our options are?
I was thinking of unbuttoning all 3 motor mounts, undoing exhaust manifold somewhere then hoisting the engine up high enough to get a straight drill bit into it to insert some helicoils. Suggestions please!! you can only imagine howmuch I'm freakin out over here when the water pump won't bolt in tight
Loyal Focus Owner!!!
First: 2003 Ford Focus ZX5
Second: 2002 Ford Focus SVT (#2808 of 4788)
Jon_SVT is offline
Old 06-08-2010, 10:10 AM   #67
the_doc735
Fan#: 74469
What I Drive: focus lx blue
FF Reputation: 1 the_doc735 Good Standing Member
I would have said helicoils too matey!
the_doc735 is offline
Old 06-08-2010, 03:02 PM   #68
sailor
Elder
sailor's Avatar
Fan#: 57268
Forum Activity 99%
Posted via FF MobileIf there`s a large enough hole (or can be enlarged slightly) on the pump for a larger bolt, maybe switching metric to american so it`s not MUCH larger, you may be able to tap larger with engine in place, saving hoisting it to get a drill in...
Old 06-08-2010, 03:41 PM   #69
the_doc735
Fan#: 74469
Yes, maybe he could indeed 'tap' the thread? [to the next size up!]
Old 06-08-2010, 09:17 PM   #70
lhc_focus
Fan#: 42464
What I Drive: 2002 ZX5
Points 46,343, Level 100
Points: 46,343, Level: 100 Points: 46,343, Level: 100 Points: 46,343, Level: 100
Level Up 0% Completed
FF Reputation: 11 lhc_focus Great Standing Member
Yup x2
lhc_focus is offline
Similar Threads
When should you get a timing belt changed? Jebus SVT Performance (2002-2004) 13 05-25-2009 04:00 AM
timing belt replacement racer1735 SVT Performance (2002-2004) 15 05-22-2007 12:14 AM
2002 1/2 zx3 timing belt removal With a twist not the same as most of the other cars Knuckles899 General Technical Chat 4 03-11-2007 04:34 PM
1.8 Zetec timing belt ciscodisco ZETEC Performance (2000-2004) 0 02-17-2006 05:10 AM
