ZETEC Timing Belt Replacement - Page 3 - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 08-31-2008, 02:11 PM   #21
lhc_focus
Fan#: 42464
What I Drive: 2002 ZX5
Points 46,343, Level 100
Points: 46,343, Level: 100 Points: 46,343, Level: 100 Points: 46,343, Level: 100
Level Up 0% Completed
FF Reputation: 11 lhc_focus Great Standing Member
The timing belt is on and tensioner set.
REMOVE THE TIMING PIN AND CAM BAR, NOW!!!!!!!!!!!!
Put the plug back in the timing pin hole. Get your 18mm socket put it on the crank bolt. Let's slowly rotate the engine clockwise several revolutions. This will align the timing belt on the pullies and sprockets.
That's it folks. Now it's time to put it all back together.
lhc_focus is online now
Old 08-31-2008, 02:37 PM   #22
lhc_focus
Fan#: 42464
On a scale of 1-10 I'd rate this a 4. All your doing is removing and replacing. Take plenty of pics and notes. Trust me on this. Use all tools available to your advantage. I did 99% of this myself. My son helped with the removal of the exhaust manifold to cat nuts.
Don't attempt this if:
Your mechanical skills are limited to oil changes and filters.
This is your daily driver and it's sunday afternoon.
Don't have the tools.
Parts used
Timing belt kit from NAPA #2522941 $124.88
Water pump NAPA #41013 $53.29
Serp belt tensioner NAPA #38188 $35.97
Serp belt $19.99
Serp belt idler pulley bearing $4.99
These parts I replaced for my own reasons
P-side motor mount Checker auto #7153224 $69.01
Before cat O2 sensor Autozone #15717 $48.99
After cat 02 sensor Autozone #15717 $48.99
Autozone computer had 15718 for one of the sensors but was not = to what I had. The 15717 did. The plugs were the same, only difference was the length of wire.
Old 08-31-2008, 02:53 PM   #23
lhc_focus
Fan#: 42464
Hope all this makes sense. If I missed something or you see an error let me know.
Good luck.
Old 08-31-2008, 11:31 PM   #24
grahama
grahama's Avatar
Fan#: 20127
What I Drive: 2003 Black ZTW
FF Reputation: 1 grahama Good Standing Member
Very nice write up. I won't need my timing belt replace for a few years, but my alterntor one may need replacing sooner. May just be best to do all at once
grahama is offline
Old 09-13-2008, 08:47 AM   #25
DoubleD
Fan#: 58014
What I Drive: 2002 ZX3
FF Reputation: 1 DoubleD Good Standing Member
Awesome write up and great detail! Did you break the cam bolts loose to allow the cam gears to float while installing the belt, or just figure the cam timing was fine since it had jumped the crank gear?
DoubleD is offline
Old 09-13-2008, 10:39 AM   #26
lhc_focus
Fan#: 42464
It was all about luck that neither one of the cams jumped timing. Once the bar was in the cam slots I figured the cams were good to go. No reason now to mess with the cam sprockts. The bar holds them in place while putting the belt on. Hope this helps.
Old 11-20-2008, 03:38 PM   #27
sffish
Fan#: 47718
What I Drive: 2000 Ford Focus SE Wagon
FF Reputation: 1 sffish Good Standing Member
Thanks
lhc_focus, thanks for the nice write up. I was a little apprehensive about doing this myself since all I had is a service manual and no air tools, but looks like I don't really need the air tools and this is doable. Thanks again, you've helped at least one person.
sffish is offline
Old 12-23-2008, 09:03 PM   #28
S2
Retired Fanatic
S2's Avatar
Fan#: 4939
What I Drive: Camaro 2SS/RS
FF Reputation: 67 S2 Excellent Standing Member
Buy-Sell-Trade Rating: (20)
Added to the 'How To' Archive.....
Chad (S2)
S2 is offline
Old 04-04-2009, 01:38 AM   #29
wildfire329
wildfire329's Avatar
Fan#: 63404
What I Drive: 2001, twilightblue, zx3
Points 1,508, Level 22
Points: 1,508, Level: 22 Points: 1,508, Level: 22 Points: 1,508, Level: 22
Level Up 8% Completed
FF Reputation: 1 wildfire329 Good Standing Member
shweet!!!!!!!!
wildfire329 is offline
Old 04-04-2009, 07:50 AM   #30
soccrstar
Fan#: 12917
FF Reputation: 1 soccrstar Good Standing Member
I had my timing belt changed along with the tensioner and some gasket. total 442 bucks and some change. going to go pick it up now.
the shop folks at the shop said the belt was on its way out. luckily it didn't break
car has 196k miles on it
-Soccr Star
soccrstar is offline
Similar Threads
When should you get a timing belt changed? Jebus SVT Performance (2002-2004) 13 05-25-2009 04:00 AM
timing belt replacement racer1735 SVT Performance (2002-2004) 15 05-22-2007 12:14 AM
2002 1/2 zx3 timing belt removal With a twist not the same as most of the other cars Knuckles899 General Technical Chat 4 03-11-2007 04:34 PM
1.8 Zetec timing belt ciscodisco ZETEC Performance (2000-2004) 0 02-17-2006 05:10 AM
