ZETEC Timing Belt Replacement - Page 19 - Focus Fanatics
Old 04-14-2013, 04:51 AM   #181
TJForster
Fan#: 113489
What I Drive: 2009 Silver SES
FF Reputation: 1 TJForster Good Standing Member
Help
Hello all, I'm new to this site, trying to find where I can ask this.. Okay here is my problem, I have a 2009 ford focus SES, standard, all the accessories and what not, anyway I just bought this car less then a month ago. What happened was I was racing.. And accidentally shifted from 3rd to second, at a high speed.. My car lost power and stalled, found out one cylinder wasn't working( the second one in from the drivers side). Had unplugged it looked at it plugged it back in and the car still ran the same, then I unplugged it again and the cylinder was working its a different one now that isn't, it's the first one on the drivers side that isn't working now, would it be the distributor? New wires? Spark plugs?? Please help, thank you all, really appreciated!
TJForster is offline
Old 04-14-2013, 05:38 AM   #182
Z3T3C
Fan#: 107116
What I Drive: 2000 SE Zetec with ATX
FF Reputation: 1 Z3T3C Good Standing Member
I'll be the first to welcome you to FF. FYI your car doesn't have a distributor, your engine is a direct coil on plug type. Your issue may be a little more complex than just a bad coil though, but more info is needed. I would suggest looking through the Stickied Threads I'm not sure of technical knowledge, but you can measure resistance of each coil with a multimeter to confirm they are all within spec. If you don't have access to a multimeter you can swap coils out from a known firing cylinder and test it that way. However, like I said your issue could be more involved, so I would suggest starting a new thread under the "General Technical Chat Forum." Be sure to include as much info as possible like if CEL is on, and if it is what code(s) is it throwing, what method(s) or how did you come to the conclusion that a particular cylinder isn't firing, etc. There are several intelligent, fellow focus owners on here more than willing to help once you start a thread. Good luck, TJ.
Z3T3C is offline
Old 04-14-2013, 01:13 PM   #183
TJForster
Fan#: 113489
Thank you for your help, I had just posted a long thread of everything that happened on the general forum you supplied the link to.. I hope my problem gets resolved.. I'm not use to driving new cars with this technology, I use to drive old Camaro muscular cars...
Old 04-14-2013, 06:23 PM   #184
Z3T3C
Fan#: 107116
You're welcome. I hear ya, it's a bit of a learning curve but basic concepts are still there.
Z3T3C is offline
Old 07-10-2013, 05:29 AM   #185
William J Toensing
Fan#: 52435
What I Drive: 2001 Sangria Red ZX3 5 speed
FF Reputation: 1 William J Toensing Good Standing Member
I like these instructions, much better than the Haynes/Chilton or factory manual. My Focus is about ready for its second timing belt at 152000 miles. Had a local mechanic do the first TB replacement. I thought the Zeetech engine on my 2001 ZX3 was an interference engine. From the author's coments it sounds like it isn't.
William J Toensing is offline
Old 07-11-2013, 08:32 PM   #186
amc49
Fan#: 96610
FF Reputation: 19 amc49 Great Standing Member
My bad.........
amc49 is offline
Old 09-11-2013, 09:51 AM   #187
TboneZX3
Ford Fiend
TboneZX3's Avatar
Fan#: 90494
I used this as a basic guide when I recently replaced the timing belt in my Zetec. I used a slightly different method, but overall the writeup was very useful.
However, I did find it odd that the write-up seems to skip the step for removing the crank pulley. I just wanted to mention that having an assistant shift into 5th gear (manual) and apply the brakes provided enough resistance to prevent the engine from rotating when removing the crank pulley bolt.
Hatch Nation #90
TboneZX3 is offline
Old 09-16-2013, 08:13 PM   #188
daffoml
Fan#: 87359
What I Drive: 2002 ZX5
FF Reputation: 1 daffoml Good Standing Member
Hello, I replaced my TB with the help of this writeup, but I am having problems keeping the tension correct it seems.
I did use the pin and bar, so nothing moved during the process.
Before starting, I rotated the engine by hand a few turns to make sure nothing was hung up, and my marks I made kept lining up turn after turn, then, when I started it, the belt tried to 'walk off' the gears, so I shut it down, then checked the tensioner position, and it was 45 deg clockwise of where I set it. I figured that I didn't have all of the slack out of the belt somewhere, and it came out there. After checking the timing by my marks, I reset the tensioner, then moved the belt by hand (ratchet on the crank pulley) and after 1.5-2 rotations of the belt, the tensioner would change position (not as bad as the first time, more like 3-5 deg.
I repeated this a couple times until the belt stopped walking off, it now rides about 1 mm 'inboard' of where it did originally, but I think that's OK, there's still about 3 mm of gear left. The troubling part is that the tensioner is no longer lined up, it's still pointing in the box, but not centered.
I guess my question is: do I need to care?
I can post pics if needed.
Thanks
daffoml is offline
Old 09-17-2013, 06:32 AM   #189
Missourileo
Captain Retard
Missourileo's Avatar
Fan#: 55980
What I Drive: 2002 Black SVT ZX3,93 SVT Lightning
FF Reputation: 20 Missourileo Great Standing Member
Buy-Sell-Trade Rating: (17)
The tensioner is going to move a little bit. This is kind of iffy. Have you checked with bar Nd pin to see if you're still in time?
"It's the Veteran who salutes the flag, serves beneath the flag, and whose coffin is draped by the flag."
Midwest crew #36
Hatch Nation#50
January 2010 ROTM
Missourileo is offline
Old 09-17-2013, 07:03 AM   #190
Mile30
Mile30's Avatar
Fan#: 74686
What I Drive: '03 ZX3
FF Reputation: 7 Mile30 Good Standing Member
Buy-Sell-Trade Rating: (10)
Helluva write-up!
"I'm gonna sing the doom song..."
Mile30 is offline
Similar Threads
When should you get a timing belt changed? Jebus SVT Performance (2002-2004) 13 05-25-2009 03:00 AM
timing belt replacement racer1735 SVT Performance (2002-2004) 15 05-21-2007 11:14 PM
2002 1/2 zx3 timing belt removal With a twist not the same as most of the other cars Knuckles899 General Technical Chat 4 03-11-2007 03:34 PM
1.8 Zetec timing belt ciscodisco ZETEC Performance (2000-2004) 0 02-17-2006 04:10 AM
Focus Fanatics Ford Focus Forum offers many fun ways for you to engage with other Ford Focus Owners from across the world. Whether it be about the aftermarket performance modifications, technical how-to's, European tuned suspension or awesome fuel economy similar to the Acura TLX. You can find all Ford Focus related information here. Join our Ford Focus discussion forums and chat with local Focus enthusiasts in your area.
