ZETEC Timing Belt Replacement - Page 16 - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 11-25-2012, 11:11 AM   #151
coldbear
Fan#: 78292
What I Drive: 2014 Race Red 6/spd. SE
Points 1,358, Level 20
Points: 1,358, Level: 20 Points: 1,358, Level: 20 Points: 1,358, Level: 20
Level Up 58% Completed
FF Reputation: 1 coldbear Good Standing Member
Nothing to it.....just do it!
It really isn't a bad job. Take your time and buy only top of the line belts. Stay away from those bargin part stores. It helps if you had a bud that has done this job before, but if not come back to these forums. Good luck.cb.
coldbear is online now
Old 11-25-2012, 11:20 AM   #152
Spyder man
Fan#: 105737
What I Drive: 2002 SVTF DD
FF Reputation: 1 Spyder man Good Standing Member
Unfortunately this is a solo job. Everything has been somewhat smooth so far thanks to all of you guys that have posted up info and advice. It appears that that hard part is over. I checked the tdc and it appears to be good. Just swapping out the belt and reassembling. I did replace the waterpump, serp belt & tensioner.
Spyder man is offline
Old 12-29-2012, 11:18 AM   #153
CBen
Fan#: 51928
What I Drive: unfocused
FF Reputation: 1 CBen Good Standing Member
To echo an earlier post that doesn't seem to have been answered, is the Zetec an "interference" engine? From reading all the posts I'm guessing that it's not and is, therefore, not the end of the world if one doesn't get the timing right or if the belt goes while running.
My ZTW only has 120k miles and, speaking with the dealer yesterday, they said that even though the service manual recommends tbelt changing at 120, they might not if it didn't need it. How long does the tbelt typically last (daily driver, no engine mods, no racing)? Are the signs of wear the same as in other belts (i.e., cracking, tearing, glazing, etc)?
CBen is offline
Old 12-29-2012, 02:40 PM   #154
coldbear
Fan#: 78292
I have 168,000 miles on my 2001 ZTS Zetec and have never changed the belt. I've helped change one on my brothers 02 and it had 157,000 plus on it. Beside a little worn for most part, the lugs were still in tact and I think 200,000 was not impossible. My opinion, it's how you drive her that makes the difference. I keep mine under 3000 RPM as AMAP. Drive her like Ricky Racer, you''ll be changing the belt much sooner. And I've heard that the stock Zetec is not an interference engine. But don't take my word on the interference question. If you drive hard, change the belt asap after 100,000 miles. jmo.
Old 12-30-2012, 05:36 AM   #155
amc49
Fan#: 96610
Points 3,267, Level 35
Points: 3,267, Level: 35 Points: 3,267, Level: 35 Points: 3,267, Level: 35
Level Up 45% Completed
Level up: 45% Level up: 45% Level up: 45%
Forum Activity 7%
The people who make the belt material itself say 120K mile change interval. You cannot ever say how long they will last, driving conservatively helps but simply being in a high temperature environment will shorten life. Although wear can often be seen, just as many strip teeth with no warning and belt will look perfect other than missing the teeth that went. The pulleys very often shell out too, not looking can get you stranded if pulley goes out on a fine belt. You'll see the cracks developing in plastic of pulley but obviously not if you simply disregard looking. I've seen Ford pulley come apart at 50k miles, other Ford pulley next to it was cracked good too.
amc49 is offline
Old 12-30-2012, 12:05 PM   #156
coldbear
Fan#: 78292
Change em' when they need it...?
I'M PLANNING MY TIMING BELT CHANGE AT 200,000 MILES. I WILL POST A PICTURE OF IT AND THEN ALL WILL SEE HOW DRIVING UNDER 3000 rpm will prolong the belt life. I am a gambler!
Old 12-30-2012, 03:18 PM   #157
Jon_SVT
Jon_SVT's Avatar
Fan#: 34787
What I Drive: 2002 Silver SVT Focus
Points 587, Level 11
Points: 587, Level: 11 Points: 587, Level: 11 Points: 587, Level: 11
Level Up 74% Completed
FF Reputation: 2 Jon_SVT Good Standing Member
Regular Zetec - Non-interference engine
SVT Zetec - Interference engine
That being said..... why risk your belt snapping and being stuck on the side of the road just to prove that your piece of rubber lasted longer than the next guys. Change it out! It's really not that hard of a job IF YOU HAVE THE RIGHT TOOLS (cam locker bar and crank alignment plug)
You can buy those two tools from C-F-M.... grab all your belts, pulleys, and tensioners from www.rockauto.com. Guarantee that the whole job doesn't cost you more than $400
Pro-active maintenence is MUCH better on the overall life of your car than Re-active maintenence
Loyal Focus Owner!!!
First: 2003 Ford Focus ZX5
Second: 2002 Ford Focus SVT (#2808 of 4788)
Jon_SVT is offline
Old 12-30-2012, 07:31 PM   #158
CBen
Fan#: 51928
Thank you. At present, I have neither the proper tools nor money. Lack of money is the only reason why I'm not being proactive with this.
CBen is offline
Old 12-31-2012, 02:39 AM   #159
amc49
Fan#: 96610
Forum Activity 7%
Some people just like to walk.
The tow charge may sink you with thinking like that, or the oddball possibility that belt snaps rather than strips teeth and the snapped belt wads up just right in crank to break damper and oil pump case. Rare, but I found one at junkyard that ended like that.
Gambling with motor vehicles repeatedly rarely works out longterm, the more you get away with it the more you self-reinforce your belief that it is good policy and acceptable, one loss generally will cost you all that perceived freely gained benefit.
Part of it comes from the fact that the car really just does not care what you do, it will do what IT will do, when gambling you have given up control to random chance............BUT, think of the money you'll save. Why not go further for more benefit? Don't ever change or add oil again, or never, ever check water, or drive on bald tires, or....................
You ARE a gambler right?????
Maybe gambling is WHY you have a lack of money...........
amc49 is offline
Old 12-31-2012, 04:13 AM   #160
Jon_SVT
Jon_SVT's Avatar
Fan#: 34787
lol nicely said amc49.... a TAD harsh, but you def got the point across haha!
One thing I WILL add is that not only is changing the belt good becaucse its a good thing to do. Your car litterally FEELS like a brand new car! Timing is now perfectly aligned and its responsive like it used to be!
It's like having a 60yr old girl friend and suddenly turning her into a 25yr old babe. They both get the job done.... but one is just SOO much more worth the experience! ;) haha!!!
Jon_SVT is offline
Similar Threads
When should you get a timing belt changed? Jebus SVT Performance (2002-2004) 13 05-25-2009 04:00 AM
timing belt replacement racer1735 SVT Performance (2002-2004) 15 05-22-2007 12:14 AM
2002 1/2 zx3 timing belt removal With a twist not the same as most of the other cars Knuckles899 General Technical Chat 4 03-11-2007 04:34 PM
1.8 Zetec timing belt ciscodisco ZETEC Performance (2000-2004) 0 02-17-2006 05:10 AM
