ZETEC Timing Belt Replacement - Page 14 - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 11-12-2011, 11:21 PM   #131
5alarm
Fan#: 91632
What I Drive: 2003 Beige SE Wagon
FF Reputation: 1 5alarm Good Standing Member
I need to do this and want to get the engine to max reliability so I want to know what would be the "total" package to replace while in there doing the timing belt.
Are water pumps a weak link? What is the shopping list with priority of items?
My big concern is tightening the crank bolt. What is the torque spec and how do you achieve that? I haven't seen anything that addresses this specific question.
5alarm is offline
Old 11-13-2011, 09:25 PM   #132
zorro55555
Fan#: 60503
What I Drive: 2002 zx5 blue
Points 86, Level 1
Points: 86, Level: 1 Points: 86, Level: 1 Points: 86, Level: 1
Level Up 72% Completed
FF Reputation: 1 zorro55555 Good Standing Member
If the water pump is still original I'd call it a weak link. Mine had a plastic impeller and when it dropped onto the cement floor it broke. (it was leaking anyway)
zorro55555 is online now
Old 11-13-2011, 10:47 PM   #133
5alarm
Fan#: 91632
Zorro, thanks, I will definitely do the pump at the same time.
5alarm is offline
Old 11-14-2011, 07:07 AM   #134
Missourileo
Captain Retard
Missourileo's Avatar
Fan#: 55980
What I Drive: 2002 Black SVT ZX3,93 SVT Lightning
Points 5,373, Level 47
Points: 5,373, Level: 47 Points: 5,373, Level: 47 Points: 5,373, Level: 47
Level Up 12% Completed
FF Reputation: 20 Missourileo Great Standing Member
Buy-Sell-Trade Rating: (17)
As for a shopping list............. T-belt kit(idler pulley, tensioner, t-belt), water pump,valve cover gasket with grommets and while you're in there, serpentine belt.
"It's the Veteran who salutes the flag, serves beneath the flag, and whose coffin is draped by the flag."
Midwest crew #36
Hatch Nation#50
January 2010 ROTM
Missourileo is offline
Old 11-18-2011, 01:06 PM   #135
anarchyamp
Fan#: 70907
What I Drive: 2002 pitch black focus SVT turbo
Points 731, Level 14
Points: 731, Level: 14 Points: 731, Level: 14 Points: 731, Level: 14
Level Up 31% Completed
Level up: 31% Level up: 31% Level up: 31%
FF Reputation: 1 anarchyamp Good Standing Member
Buy-Sell-Trade Rating: (4)
Ok, I'm doing the timing belt on my svt focus...im in deep and got the belt off and have the timing tools. I put the crank pin in and rotated clockwise until the crank hit the pin. then I tried to slide the cam plate in the cams and it went into one cam slot and the other cam was like barely barely off, so i just turned the intake cam gear a tiny bit so it would line up and the bar slid in place, now the bar is in place holding the cams. My question is, is this ok or do I NEED to loosen the cam gears?
Why is everbody loosening the cam gears? Do I have to?
anarchyamp is offline
Old 11-18-2011, 05:06 PM   #136
Missourileo
Captain Retard
Fan#: 55980
Yes, that is normal. It is correct to loosen the cam gears. When you put the new belt on and tighten the tensioner, you will see both gears rotate. Then you tighten the gears down and voila, you are in time.
Midwest crew #36
Hatch Nation#50
January 2010 ROTM
Old 11-18-2011, 07:42 PM   #137
anarchyamp
Fan#: 70907
Yeah but I don't get why you would loosen the cam gears? Like some other guy said, why would the gears ever move or change regardless of what the belt has done? So I still don't know, do you absolutely have to loosen and retighten the cam gears? It looks like the guy who made this how to on pages 1&2 did NOT loosen his cam gears.
Here's a vid I just made explaining my concern before I put everything back together because I NEVER want to do this again lol...so I want to be sure that I'm ok and that I wont get p1381 again because this is an interference motor. http://www.youtube.com/watch?feature...&v=72U037-owiA
Sorry the video is a bit long and backwards, (filmed upside down and it flipped everything so everything thats on the right should be on the left and everything thats on the left should be on the right if that makes sense) but I want to be thorough and also forgot to mention in the video that everytime we knocked up against the pin to be at TDC #1, the timing mark on the crank pulley(harmonic balancer) lined up with the raised portion on the block skirt, so I THINK everything is ok.
Old 11-18-2011, 11:36 PM   #138
Missourileo
Captain Retard
Fan#: 55980
Send me your email addy and I'll send you the ford workshop manual instructions on this procedure. Goes into detail on how to do this.
Midwest crew #36
Hatch Nation#50
January 2010 ROTM
Old 12-19-2011, 05:27 PM   #139
eggsmith
eggsmith's Avatar
Fan#: 92910
What I Drive: 1999 Black Contour
FF Reputation: 1 eggsmith Good Standing Member
Hi,
New to the site and hope to add my .02 worth at times.
But for now I am following timing belt posts.
As for the crank TDC pin goes, can I use a positive piston stop screwed into #1 spark pulg hole to stop piston at TDC, would it do the same thing as the crank pin lock.
I use this method on my race bikes when degreeing cams in and it has always works.
eggsmith is offline
Old 12-19-2011, 07:56 PM   #140
coldbear
Fan#: 78292
What I Drive: 2014 Race Red 6/spd. SE
Points 1,374, Level 20
Points: 1,374, Level: 20 Points: 1,374, Level: 20 Points: 1,374, Level: 20
Level Up 74% Completed
FF Reputation: 1 coldbear Good Standing Member
Only prob. I see with your process is locking the crank on TDC. When timming the cams, you do not want ANY movement from the crank either way. So how do we lock the crank from rocking either way? PIN IT! Or make damn sure it stays static.cb.
coldbear is offline
Similar Threads
When should you get a timing belt changed? Jebus SVT Performance (2002-2004) 13 05-25-2009 04:00 AM
timing belt replacement racer1735 SVT Performance (2002-2004) 15 05-22-2007 12:14 AM
2002 1/2 zx3 timing belt removal With a twist not the same as most of the other cars Knuckles899 General Technical Chat 4 03-11-2007 04:34 PM
1.8 Zetec timing belt ciscodisco ZETEC Performance (2000-2004) 0 02-17-2006 05:10 AM
