Rear Sway Bar problem? - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 08-27-2008, 04:32 PM   #1
slipster17
slipster17's Avatar
Fan#: 37217
What I Drive: 2011 Yellow Blaze Fiesta SES
Points 4,068, Level 40
Points: 4,068, Level: 40 Points: 4,068, Level: 40 Points: 4,068, Level: 40
Level Up 59% Completed
FF Reputation: 16 slipster17 Great Standing Member
Buy-Sell-Trade Rating: (11)
Ok, hoping I can get some help with this issue.
Began a few weeks back when a friend noted that my rear sway bar end-links were not at all sitting parallel with the control arm like they should be. They were actually canted up at about a 45 degree angle were the sway bar met the rubber bushings.
I just figured this was a result of me lowering my car 2 months ago and not readjusting the sway bar ends.
Just today I got around to breaking out the socket set and try to drop the end links down to parallel. The nuts came off the end easy enough, but the rubber bushings are solid as concrete and cracking. Ok, I thought, they are old, time to replace them! So I played with the sway bar until the ends were level with the control arm... but that point comes when the sway bar end link is about an inch and a half below the control arm. Add to it, the hole on the end of the control arm is not in line with the bolt hole in the control arm. If I slide a long enough bolt through, the difference between the two holes is about 1/2 inch (with the hole on the sway bar being more forward)
Is something screwy going on here? Even if I jack the suspension up as if it were still at stock height, the sway bar hole would not be directly in line with the bolt hole in the control arm.
The distant between the control arm and sway bar, both vertically and horizontally perturbs me greatly.
April 2010 ROTM
2011 Yellow Blaze Metallic SES Fiesta hatch
Carlisle All-Ford Nationals 2011 1st Place - Fiesta Class
slipster17 is offline
Old 08-28-2008, 10:45 AM   #2
slipster17
slipster17's Avatar
Fan#: 37217
Pictures from this morning when I tried dropping in a new set of Energy Susp. bushings:
Still not totally parallel.... and you can see some of the angle that the bolts have.
Close up:
Am I just looking into this too much or is there something bent down under there?
April 2010 ROTM
Old 08-28-2008, 11:16 AM   #3
MattZX3
Detailing Freak
MattZX3's Avatar
Fan#: 30258
What I Drive: 2014 ford
Points 16,124, Level 81
Points: 16,124, Level: 81 Points: 16,124, Level: 81 Points: 16,124, Level: 81
Level Up 55% Completed
FF Reputation: 23 MattZX3 Great Standing Member
Buy-Sell-Trade Rating: (4)
if i remember correctly, mine are like that too, and dude, get shorter bolts for that sway bar
MattZX3 is offline
Old 08-28-2008, 11:37 AM   #4
slipster17
slipster17's Avatar
Fan#: 37217
Bolts of that length are what is needed to keep the stock sway bar parallel
Otherwise I end up like I had before with the sway bar ends bent upwards at a 45 degree angle.
April 2010 ROTM
Old 08-28-2008, 11:46 AM   #5
pistolgripbmx
pistolgripbmx's Avatar
Fan#: 49331
What I Drive: 86 ranger, 2007 focus zx3 s
FF Reputation: 38 pistolgripbmx Great Standing Member
Buy-Sell-Trade Rating: (8)
I re-used the spacers from the stock hardware and just trimmed down the bolts.
edit: i just ran out to my car and looked, and yeah something doesn't look right under there. The top bushings are seated in there right?
teamduratec #143!
focus sport cool-flo, f2 v.3 header, trubendz 2.5 SS, frpp 1.5" front sportline rear, vf rear engine mount, 93oct Focus Power tune
pistolgripbmx is offline
Old 08-28-2008, 12:00 PM   #6
BeeFzX3
BeeFzX3's Avatar
Fan#: 46655
What I Drive: 2013 Focus ST
Points 5,963, Level 50
Points: 5,963, Level: 50 Points: 5,963, Level: 50 Points: 5,963, Level: 50
Level Up 7% Completed
FF Reputation: 40 BeeFzX3 Great Standing Member
you need shorter endlinks, I had the same problem with the ones steeda sent me with their swaybar kit.
The metal tube spacer is way tooo long. You could try to cut that tube, but you might run out of thread for the nut on top.
http://www.focusfanatics.com/forum/s...ybar+installed
right now I have different endlinks: http://www.newedgeperformance.com/in...ROD&ProdID=180
BeeFzX3 is offline
Old 08-28-2008, 12:05 PM   #7
slipster17
slipster17's Avatar
Fan#: 37217
That was what I initially intended to do, but the rubber spacers from my stock sway bar were rock hard and cracking.
I should have grabbed some pics before I took out the old bushings, but they looked something like this when they were in there. With the end of the sway bar digging up into the bottom of the rear control arm.
April 2010 ROTM
Old 08-28-2008, 12:09 PM   #8
slipster17
slipster17's Avatar
Fan#: 37217
Thanks for the links but I think everyone misunderstands the reason for this thread.
I am asking if there is a problem with my sway bar, because it needs to be down so low in order to keep the ends parallel with the control arm above.
I would rather not have it that low, and I can easily go out and buy a new set of the links with a shorter neck, but doing that would not solve the problem of the sway bar ends being turned up at an angle like in my illustration above.
April 2010 ROTM
Old 08-28-2008, 12:12 PM   #9
BeeFzX3
BeeFzX3's Avatar
Fan#: 46655
now i see, that is strange, can you move it up on the subframe?
BeeFzX3 is offline
Old 08-28-2008, 12:13 PM   #10
slipster17
slipster17's Avatar
Fan#: 37217
yeah, I double checked that. The little nipple on the bushings are in the holes in both the control arm and sway bar. There is just that 1/2 inch or less of forward distance to the sway bar that won't let it sit straight up and down.
April 2010 ROTM
Similar Threads
For Sale: (yet another) SVT rear sway bar*SOLD* Phacade Archive 8 03-09-2008 09:18 PM
DTC Codes (Detailed Descriptions) S2 General Technical Chat 13 12-11-2006 12:06 PM
Rear Sway bar on zx3? Stuka Wheels & Tires 22 08-09-2006 11:07 AM
New Volkswagen Rabbit!! nomoreavril Ford Focus & General Car Chat 30 06-29-2006 12:55 PM
SVT Rear Sway Bar ddeg10 Wheels & Tires 4 04-26-2005 10:10 AM
