Clutch safety switch - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 08-25-2008, 10:14 PM   #1
ExtremeSleeper
ExtremeSleeper's Avatar
Fan#: 56163
What I Drive: 2000 Pitch Black Focus ZX3
FF Reputation: 1 ExtremeSleeper Good Standing Member
Question Clutch safety switch
Hi guys, this is my second post. Anyways, been doing my search in the forum and was trying to find the clutch safety switch. I have a 2000 zx3, standard. I'm having starting issues. Checked the battery, relays, key starter, etc. Please help and if possible pics, please. Key turns, lights in dash light up, just no engine turning over. Talked to locksmith says nothing is wrong with ignition switch. thanks for the help....
ExtremeSleeper is offline
Old 08-26-2008, 08:41 PM   #2
nomad327
Fan#: 19440
What I Drive: red 2002 svt focus
FF Reputation: 13 nomad327 Great Standing Member
The bottom cover under the dashboard will probably have to be unscrewed and dropped down to see what you're doing, the hood release can stay attached to it. There is some discussion of the switches in the clutch master cylinder thread, but the switch you're interested in is black and it is the one that is depressed when the clutch pedal is pressed all the way down. There is also a red switch which clicks as soon as the clutch pedal starts to move to disengage the cruise control, but it doesn't affect starting. An odd aspect of most of the switches mounted on the pedal box is that most of them are self adjusting. This is done by unhooking the switches from their mounts and then stiffly pulling the plunger out of the switch to reset the length. Then the switch is reinstalled, and it self adjusts the first time you push the pedal down.
nomad327 is offline
Old 08-27-2008, 07:40 AM   #3
pattywatters
pattywatters's Avatar
Fan#: 58189
What I Drive: 2001, liquid gray metallic, ZX3 S2
FF Reputation: 1 pattywatters Good Standing Member
I had the same problem, everything lit up, but engine wouldn't turn over. First, I thought it was my starter.
I took the clutch/ingition switch out of it's bracket and held it in my hand and pushed the plunger and the car started right up!
I drive a 2001 ZX3 S2, but my switch doesn't adjust. I ended up bending the push plate on the clutch pedal so it would engage the switch. I have thought about just overriding the switch with a bit of soldering, but haven't done so yet.
Just get down on your floorboard, and push the clutch pedal with your hand, and watch up by the firewall to see where it hits the switch. There's a little rubber foot mounted on the clutch pedal that hits it. The switch itself, comes out by sliding it back to unclip from the bracket.
Hope this helps!
Live well, Laugh often, Love much,,,,
pattywatters is offline
Old 08-31-2008, 10:43 AM   #4
ExtremeSleeper
Fan#: 56163
Thanks guys,
Just found the Clutch Safety Switch or the lack of a switch. Previous owner apperently did the by pass and hid the cables really good. Stripped the cables a little bit higher and the car started. Thanxs
Old 12-26-2011, 03:05 PM   #5
Focussanangelo
Fan#: 93109
What I Drive: 2006 green zx4
FF Reputation: 1 Focussanangelo Good Standing Member
Angled funny
I am having the same problem. I looked under and found the safety switch but the bracket the plastic switch is mounted to is angled to where the clutch has to be completely in the floor (me standing on the clutch pretty much) for it to engage and let me start my car. Any suggestions?
Focussanangelo is offline
Old 12-26-2011, 03:18 PM   #6
whynotthinkwhynot
Captain TMI
whynotthinkwhynot's Avatar
Fan#: 18416
Points 27,927, Level 98
Points: 27,927, Level: 98 Points: 27,927, Level: 98 Points: 27,927, Level: 98
Level Up 58% Completed
Forum Activity 9%
Bend the mounting bracket closer.
Did you notice that the last post in this thread was from 8-31-08? For future help, or for help on this problem, please start your own thread unless you find a thread that answers your question. Thanks for posting!
Be eclectic.
You're special aren't you.
whynotthinkwhynot is offline
Old 08-30-2012, 04:42 AM   #7
djKazanova
Fan#: 103238
What I Drive: 2000 Gold/Brown zx3 Kona
FF Reputation: 1 djKazanova Good Standing Member
This is great
it sounds like the issue I have
Pictures or video
Please
Thanks!
djKazanova is offline
Old 08-30-2012, 04:42 AM   #8
djKazanova
Fan#: 103238
Yes!!!
This is great
Pictures or video
Please
Thanks!
Old 09-05-2012, 12:02 PM   #9
thor27
Fan#: 103494
What I Drive: 2000 ford focus
FF Reputation: 1 thor27 Good Standing Member
hi, same problem. turn key, dash lights up, can turn on radio, but no start and no sound. I took it to a mechanic before and said it was the clutch switch that needed to be adjusted, but didn't tell me how to do it so here i am a year later trying to figure this out on my own. gonna mess with it some more, but no real instructions in forum. :(
thor27 is offline
Old 10-22-2014, 04:40 PM   #10
lairrdfergus
Fan#: 197761
What I Drive: 2003 Focus XTS
Points 4, Level 1
Points: 4, Level: 1 Points: 4, Level: 1 Points: 4, Level: 1
Level Up 7% Completed
FF Reputation: 1 lairrdfergus Good Standing Member
Clutch Pedal Start Switch is Adjustable
Did some work replacing the clutch master cylinder in my 2003 XTS - after the job was done I realized that I had pressed the clutch pedal start switch all the way in and it had now adjusted to be half the length it was originally.
I found that if you wiggle the little plunger and pull out it will come out all the way to full plunger travel and then once you install it it will reset to a default based on how far your pedal actually travels.
I have seen a lot of posts from people concerned about the pedal not being adjusted or bent and I think that the little plunger in the switch is the most common culprit - especially if you have been working around it recently.
Ferg...
lairrdfergus is offline
Similar Threads
DTC Codes (Detailed Descriptions) S2 General Technical Chat 13 12-11-2006 12:06 PM
Do I have a Fading Clutch? Charged SVTF General Technical Chat 0 12-04-2006 02:23 PM
Clutch Sensor Switch Spider SPI Performance (2000-2004) 23 10-06-2005 01:24 AM
TSB for SVT dgualtie SVT Performance (2002-2004) 10 01-12-2005 01:03 PM
Got My SCT Chip.....! ( When, were,why and how I should switch the settings) Dbelle18 General Technical Chat 6 10-10-2004 06:48 PM
