tried everything electrical problem on 05 ford focus need help - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 08-19-2008, 10:00 AM   #1
ghost1031
Fan#: 58607
What I Drive: 2005 burgundy ford focus
FF Reputation: 1 ghost1031 Good Standing Member
Unhappy tried everything electrical problem on 05 ford focus need help
i own a 2005 ford focus and i have been havin an electrical issue with it...while driving all the light will blink and as i drive more they blink faster..what i mean by light is the radio the dashboard..i also start hearing a clicking noise coming from under the sterring wheel and the car act like it wants to turn off..if i turn it off sometimes it wont turn back on and i have to wait or if it does turn on my clock and radio resets...i have taking it to several mechanics including the dealership and i keep getting new things done but never is it fixed..they have changed the battery, did a tune up, changed the electrical ignition switch and disconnected the auto alarm and still not fixed..i just want to know whats wrong..i cant afford all these guesses..im a single mom of two lil ones and i need a reliable vehicle...can anyone help me?
ghost1031 is offline
Old 08-19-2008, 05:11 PM   #2
ammorgan
Fan#: 34226
What I Drive: 2003 Dark Blue ZTS
FF Reputation: 1 ammorgan Good Standing Member
I'm gonna take a guess here. Electric relay. Or some fuse is bad in the car fuse box (not the one under the hood)
ammorgan is offline
Old 08-19-2008, 05:49 PM   #3
ILuvMyZX3
ILuvMyZX3's Avatar
Fan#: 26263
What I Drive: 2005 Pitch Black ZX3
FF Reputation: 1 ILuvMyZX3 Good Standing Member
^^ I think the mechanics would've thought of that one already and checked them out, but you never know. might be. pull the fuses from under the dashboard. there's a little CD case compartment/holder under the dashboard by where your left knee would be if you're sitting on the driver side. Open it and pull it all the way out. the fuse box is right behind that little door. i suggest you use pliers to pull them out as they are very tight. make sure you pull them out and put them back in one by one to avoid problems and confusion.
keep us posted.
and welcome to the forums.
Hector
Team Duratec #45
ILuvMyZX3 is offline
Old 08-19-2008, 06:04 PM   #4
bluefront
bluefront's Avatar
Fan#: 56816
What I Drive: 2006 white ZX5 SES
FF Reputation: 146 bluefront Excellent Standing Member bluefront Excellent Standing Member
Buy-Sell-Trade Rating: (6)
You actually paid for a tune-up to fix an electrical problem?
You need to take it back to whoever worked on it, and demand the problem be fixed at no cost.....or you want your money back for the previous unsuccessful repair.
bluefront is offline
Old 08-19-2008, 06:11 PM   #5
ammorgan
Fan#: 34226
With the problem with our car originally we were told the ignition was going bad and that it wasn't reading the chip in the key sometimes. So they put in a new ignition switch, relay, and then it kept happening so we took it back and this time they told us the gem module needed to be replaced. It was a problem they didn't "find" the first time and would need to be replaced for our car to work right supposedly.
Last edited by whynotthinkwhynot; 08-20-2008 at 07:41 PM. Reason: GEM module, not GE =)
ammorgan is offline
Old 08-19-2008, 06:12 PM   #6
ammorgan
Fan#: 34226
Duplicate post
ammorgan is offline
Old 08-20-2008, 03:19 PM   #7
Feral
Feral's Avatar
Fan#: 58350
What I Drive: 1 2002 / 2 2001 Wagons
FF Reputation: 53 Feral Excellent Standing Member
Buy-Sell-Trade Rating: (23)
Had the same problem on my car turned out to be the rebuilt alternator that was just installed.. it had a faulty regulator the faster I went the less charge it would supply which triggered the relays into acting up... I also has the Light Phases on one occasion they light up so bright they burnt out which I then plugged in my battery minder ( has a volt meter and it was sitting at 18.7 volts and the unit beeped overcharge
on the controllers they will act up, stop working or misbehave if there voltage fluctuates to much seeing not everything has a voltage stabilizer
I complained to the rebuilder they refunded the money and bought a scrap yard alternator and everythings running fine now
whats funny is my neighbour just approached me with the same problem with his import about the lights phasing and I asked was his alternator rebuilt or new he said rebuilt 7 months ago.. I told him to change it
Feral is offline
Old 08-20-2008, 05:40 PM   #8
oddballish
Fan#: 51285
What I Drive: 2006,Blue,fx4
FF Reputation: 1 oddballish Good Standing Member
If the radio and clock are clearing it has to be a complete power disconnect. The clicking is probably a /or several relays going off / on when the power drops out and then back on.
Start at the battery connections, then where the cables are crimped / soldered to the cable connectors, and unfortunately the focus is notorious for its bad grounds. If none of these are bad check the loom in the tilt portion of the steering column for shorts / bare wires .
oddballish is offline
Old 06-23-2009, 01:34 AM   #9
macados
Fan#: 66252
What I Drive: 2005 Black ZX4 SES
FF Reputation: 1 macados Good Standing Member
This sound like a problem I'm having in my ZX4. Just bought it 4 months ago. If you can fix the problem, let me know what works. I'll keep the alternator in mind. My IAC is clicking (I just learned from a different thread). It seems there are a lot of culprits to this issue.
macados is offline
Old 06-23-2009, 09:39 AM   #10
BigEd
Fan#: 38134
What I Drive: 04 focus se
FF Reputation: 2 BigEd Good Standing Member
[QUOTE=ghost1031;2297076]i own a 2005 ford focus and i have been havin an electrical issue with it...while driving all the light will blink and as i drive more they blink faster..what i mean by light is the radio the dashboard..QUOTE]
I know I am late to this posting, but here goes...
Replace the alternator, first.... The blinking lights is because the electric fan is kicking on for either the air conditioner or engine cooling and its loading the system extra hard at initial startup, causing the already weak alternator to not be able to keep up. I am at our 3rd alternator on an 04 se 4dr with 114k miles on it.
Good luck with it, as I am already greasied up and in the middle of changing my own alternator, myself.
BigEd is offline
Similar Threads
The Ford Focus Parts List! gthang MK2 Focus 13 01-27-2009 12:05 AM
Focus Light Bulb Guide (MOD STICKY THIS) TKE_Quailman MK2 Focus 13 11-09-2008 05:36 PM
Aussie Fords Coming? igor Ford Focus & General Car Chat 27 06-06-2006 12:32 PM
Interesting Read on Ford Platforms on Wikipedia igor Ford Focus & General Car Chat 2 02-28-2006 03:45 AM
