SVT stalling and cleaning your ground connections - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 08-18-2008, 03:45 PM   #1
DirtyDeeds
DirtyDeeds's Avatar
Fan#: 23692
What I Drive: 2003 SVTF, 2003 G35, 2001 Audi S4
FF Reputation: 5 DirtyDeeds Good Standing Member
Over the last few months, I've been refreshing the SVTF (It has 92,000 miles on it). New plugs, wires, cleaned the MAF, cleaned the air filter, new fuel filter, replaced the VCT solenoid, new timing belt, etc.
Anyway, the car has had an issue familiar to many SVTF owners, stalling when coming to a stop. Over the last few months, it's been getting worse and had gotten to the point where I could pretty much count on it stalling at least once per day and come close to stalling a few times per day.
One maintenance item I had not gotten to was cleaning the ground connections by the battery. I've owned two Mustangs, two Merkurs and two Focuses and I've always found that computer controlled Ford products can be sensitive to how strong the ground connection is in the wiring harness.
This past Saturday morning, I set about cleaning the three ground wires attached to the inner fender well just to the right of the battery. I used a wire brush and cleaned both the connectors and the bolts. While I don't believe this to be a cure all, the SVTF is running better, has a better idle and hasn't come close to stalling in two days.
So here is your Top Gear top tip...
Clean those grounds and maybe you won't have to be embarrassed at the next stop light when your SVTF decides to take a nap.
DirtyDeeds is offline
Old 08-18-2008, 05:07 PM   #2
ken6x6
ken6x6's Avatar
Fan#: 31100
What I Drive: 03 Black SVTF
Points 3,466, Level 36
Points: 3,466, Level: 36 Points: 3,466, Level: 36 Points: 3,466, Level: 36
Level Up 78% Completed
FF Reputation: 2 ken6x6 Good Standing Member
Buy-Sell-Trade Rating: (7)
huh... i just might try that
03 SVTF #3804, full suspension, CM FX300, Torsen LSD, no cat, dual exhaust, Tom's tune. 167whp 154 wtq (dyno jet) and some other stuff. dyno- http://www.youtube.com/user/ken6x6#p/a/u/1/cKH4FX7c9L4
ken6x6 is offline
Old 10-09-2008, 08:27 AM   #3
DirtyDeeds
DirtyDeeds's Avatar
Fan#: 23692
Just an update. The car behaved for two weeks and started stalling again. Time for a tune.
Old 10-09-2008, 10:35 AM   #4
WUGcatsvt
Obama Can't Gymkhana
WUGcatsvt's Avatar
Fan#: 36697
What I Drive: 02 SVT, 86 BMW E30, 10 VW GTI
FF Reputation: 62 WUGcatsvt Excellent Standing Member
Buy-Sell-Trade Rating: (18)
Sounds Like it ^^
"No, the Focus is SLOW and just kinda stays that way."-Joe GCR SCCA VP
gumpcrew#10
Gulf Coast Region #12 - Me-45 DSP
My Girl-451 DSPL
WUGcatsvt is offline
Old 10-09-2008, 11:10 AM   #5
Hillyard
Supercharged
Hillyard's Avatar
Fan#: 10982
What I Drive: 2002 ZX3 SVT, 2004 Ford Ranger 4x4
Points 13,364, Level 75
Points: 13,364, Level: 75 Points: 13,364, Level: 75 Points: 13,364, Level: 75
Level Up 29% Completed
Level up: 29% Level up: 29% Level up: 29%
FF Reputation: 2 Hillyard Good Standing Member
Buy-Sell-Trade Rating: (27)
Well the A/C can cause some problems if you don't downshift. If you depress the clutch and coast to a stop then you are more likely to get a stall.
#3788 InfraRed SVT
Hill <><
Hillyard is offline
Old 10-10-2008, 02:48 AM   #6
boarder
boarder's Avatar
Fan#: 59144
What I Drive: 2003 Screamin Demon SVT eap
FF Reputation: 1 boarder Good Standing Member
Ya know...im at 96,xxx and I haven't had a problem with it stalling at all actually. What all have you replaced and whatnot?
boarder is offline
Old 10-10-2008, 09:01 AM   #7
DirtyDeeds
DirtyDeeds's Avatar
Fan#: 23692
I'm at 97,000 and the stalling just became a problem a few months ago. To date, I have replaced plugs, plug wires, IAC, O2 sensors, cleaned the MAF, cleaned the grounds and added a CFM 67mm TB.
The TPS and MAF are original, but the MAF has been cleaned multiple times using MAF cleaner.
Old 10-10-2008, 09:20 AM   #8
Hillyard
Supercharged
Hillyard's Avatar
Fan#: 10982
Sounds like the iginition pack might be starting to go? Do you get any misses?
#3788 InfraRed SVT
Hill <><
Hillyard is offline
Old 10-10-2008, 09:31 AM   #9
DirtyDeeds
DirtyDeeds's Avatar
Fan#: 23692
I forgot to add that one. I had an MSD coil pack when the problem started and swapped back to the stock coil pack when I changed out the plug wires. It made no difference.
Old 10-10-2008, 10:44 AM   #10
JRODSVT
Dragon Warrior
JRODSVT's Avatar
Fan#: 15362
What I Drive: 03 SVT ZX5
FF Reputation: 97 JRODSVT Excellent Standing Member
Buy-Sell-Trade Rating: (6)
Have you considered the Big 3 upgrade?
engine to chassis ground, battery to chassis ground, alternator to battery positive?
I did this a while ago and it helped my stalling problem. even with having an alternator that does not turn on until 1200 rpm.
J-RAWK!!!
FocusFests best of sound 2008
(Oo> (SVT) <oO)
o xxxxxxxxxxxx o
JRODSVT is offline
