Car won't start, timing belt? help please - Focus Fanatics
Old 08-16-2008, 09:59 PM   #1
javiersvt
javiersvt's Avatar
Fan#: 32135
What I Drive: .
FF Reputation: 6 javiersvt Good Standing Member
Post Car won't start, timing belt? help please
ok i'll try to explain as good as i can.
driving to work, the car was dying, like about to stall from being in 6th at low speed/low rpm, so i downshifted to 4th, i pressed the gas and car was very weak, so i put it in 3rd, at this time car was already dead, so i popped the clutch with no luck so i pulled over. the only thing i see is that there is a little slack on the timing belt. i went back in the car and tried cranking again i hear the starter but sound like is not engaging the flywheel,.
question: if the timing belt skipped a tooth or 2 and threw the timming off, will the car still crank or there is a sensor that won't allow it to so it doesn't damage anything?
i could take the starter out and get tested but when i tried push starting the car it didn't start either so that's my concer.
it's an svt with 126k on the odo.
thanks for any help/advice
javier
javiersvt is offline
Old 08-16-2008, 10:31 PM   #2
three_X_Z
Fan#: 883
What I Drive: 2000 ZX3
FF Reputation: 1 three_X_Z Good Standing Member
Well you could always pull off the oil cap and see if the cams are turning while you crank. Although the svt is an interferance motor so that might be bad news to keep cranking on it.
three_X_Z is offline
Old 08-16-2008, 10:35 PM   #3
javiersvt
javiersvt's Avatar
Fan#: 32135
What I Drive: .
well, i don't have a timing belt cover so i can see that the belt/cam pullies are not turning, but i can hear the starter like is not engaging...
Old 08-17-2008, 12:11 AM   #4
whynotthinkwhynot
Captain TMI
whynotthinkwhynot's Avatar
Fan#: 18416
What I Drive: 05 ZXW; 02 Windstar; 13 C-Max SEL
FF Reputation: 270 whynotthinkwhynot Outstanding Standing Memberwhynotthinkwhynot Outstanding Standing Memberwhynotthinkwhynot Outstanding Standing Member
So let me get this right from what you wrote:
You turn the key, but the engine does not turn, and the car died while you were driving?
As far as the timing belt theory goes, it should be very tight, if it's not, then your tensioner is bad, and yes, it could've skipped a few teeth and would not start after that. However, it would crank, sputter, but not start. Maybe your problem is not related to the timing belt at all- try tracing down the negative cable on your battery. It should be connected near the starter. One FF had problems with the wires melting in half due to being too close to the EGR tube. This would explain why it died, why the timing belt is still there, and why you can't get it started.
Interior lights and things will still work because there are other connections to the body, and engine. However, none of these grounds are large enough to handle the load of the starter motor.
Be eclectic.
You're special aren't you.
whynotthinkwhynot is offline
Old 08-17-2008, 06:24 AM   #5
javiersvt
javiersvt's Avatar
Fan#: 32135
What I Drive: .
yeah all i hear is the starter but maybe the bendix is not kicking out. i'll start with that, and the wireing and i'll check the timing marks
thanks
javier
Old 04-09-2009, 09:14 PM   #6
pablowdidit
pablowdidit's Avatar
Fan#: 59620
What I Drive: 2002 Ford -Focus Whits wgn
FF Reputation: 1 pablowdidit Good Standing Member
My Focus was SPLUTTERING AS WELL AND i changed the fuel filter ,was full of water like mud puddle ,thought the problem was gone ,NOT ! so then i got a dist cap and new spark plug wires ,the cap was the wrong one so I just changed the wires ,yes ""that was it ,runs excellent ,until today ,when it just quit ,??? coming home from work cost me 50 bucks to tow ,thought it could be the timing belt cause i thought i heard a coiling sound just before it stopped running ,i have to start checking everything tomorrow ,this sucks .
THE BEAST I RIDEAPON IS
NOT A LOCUST
BUT A FOCUS ,
pablowdidit is offline
Old 04-10-2009, 11:23 AM   #7
03FocusZX3
03FocusZX3's Avatar
Fan#: 61785
What I Drive: 2003 Liquid Grey ZX3
FF Reputation: 1 03FocusZX3 Good Standing Member
Gah this thread makes me paranoid, i dont want my foci just quitting on me and never cranking back up 0.0
When I die, I want to go peacefully like my grandfather did, in his sleep, not screaming, like the passengers in his car.
03FocusZX3 is offline
Old 07-01-2013, 07:12 PM   #8
mvcsvt
Fan#: 116324
What I Drive: 2002 Red Focus SVT
FF Reputation: 1 mvcsvt Good Standing Member
I just had the same thing happen to me. Driving in 4th gear around 2,500 RPMS car dies like it ran out of gas try to start but wont start motor is turning over. Try to coast start wont start try the key again and now it sounds like the starter is not engaging on the fly wheel. WHATS UP!!
I did just replace the plugs, cleaned the air filter and the throttle 60 miles ago. The car was running GREAT.
mvcsvt is offline
Old 07-01-2013, 07:22 PM   #9
javiersvt
javiersvt's Avatar
Fan#: 32135
What I Drive: .
try rocking the car back and forth in gear then try to start it again.
also take a look at the timing belt, mine lost 13 teeth and it got down to the crank pulley was too many teeth meesing to grab the gear and bent all the valves...
best of luck with it
Old 07-01-2013, 07:29 PM   #10
mvcsvt
Fan#: 116324
Thanks Javier I have a feeling I am going to find the same thing. I have owned the car for 2 weeks.
mvcsvt is offline
Similar Threads
Car wont start dttaz General Technical Chat 2 07-19-2008 07:33 PM
Timing belt where to get it done (Advice Needed) xaeniac General Technical Chat 3 07-12-2008 12:57 AM
Timing belt problem matthewsvt General Technical Chat 22 07-16-2007 03:00 PM
Cam/Crank alignment marks for new timing belt SPI/SOHC? QwikKota General Technical Chat 1 01-14-2007 06:53 PM
Well, That Sucks blck01zx3 Video Showroom 6 02-23-2005 01:51 PM
