Go Back   Focus Fanatics > Model Specific Discussions > MK1 Focus
Old 08-14-2008, 11:01 AM   #1
bluefront
bluefront's Avatar
Fan#: 56816
What I Drive: 2006 white ZX5 SES
FF Reputation: 145 bluefront Excellent Standing Memberbluefront Excellent Standing Member
Buy-Sell-Trade Rating: (6)
Got Any Rust? Prevention methods..
I don't have any, and I don't want any. My car is less than three years old, so I wouldn't expect any this soon. But how about ten years from now.....if you've still got the thing?
There are areas on my car that I can see will be a problem.....from past experience and from some inspection of this particular Focus. Here's where the first outer body rust will occur (IMHO) and what you can do about it before the fact.....
Take off a front fender inner splash shield......but before you do buy some new 5/16 nylon rivets, because they break easily. O'Rileys a box of 15 for $3.
Take a look where the dirt/water is getting in there.....
You can't prevent all this crap from getting in, but you can stop a lot of it with a foam collar around the shock opening.
Here's where the rust is likely to start first.....at the rear of the opening behind this foam flap. The thing is sealed too well at the bottom. Any crap that enters there is likely to stay trapped behind the flap, build up, stay wet, and eventually cause fender rust. This happens on many cars. Here's what mine looked like....the other side was much worse.
Crap will get back there no doubt. But if you cut about an inch off that foam flap on the bottom, water will drain out easier, taking the crap with it. There is no 100% certain way to keep this area clean and free from dirt build-up. But if you take the wheel-well shield off maybe once a year for cleaning.....you might prevent this area from rusting. I cleaned everything off and re-painted the area with Rustoleum black paint before I put everything back together. Here's where I made the little cut....
If you only keep cars a few years, rust is no worry. I usually keep cars over 10 years......rust can be a bad problem. It's much easier to prevent.
I'm doing several of this sort of rust prevention methods....anybody interested? I can post more photos....
bluefront is offline
Fan#: 1
Old 08-14-2008, 01:08 PM   #2
trailbikerider
I <3 Conspiricizing.
trailbikerider's Avatar
Fan#: 50501
What I Drive: 2002 Granny Gold ZTS, 94 2.3 Ranger
FF Reputation: 14 trailbikerider Great Standing Member
Buy-Sell-Trade Rating: (15)
Too bad my car wasn't newer than it is. I'm getting rust on my trunk lid right above and below the trim strip where the ford emblem is; common place to rust.
Originally Posted by SVT3658
I am enjoying this ice cream like Evan enjoys drinking a beer from a koozi in a beach chair across the street from a middle school
trailbikerider is offline
Old 08-14-2008, 01:24 PM   #3
bluefront
bluefront's Avatar
Fan#: 56816
Hey thanks for that info.....I guess that's the next place to check.
Old 08-14-2008, 04:52 PM   #4
bluefront
bluefront's Avatar
Fan#: 56816
It's quite likely that different years/models have different potential rust issues. I took the hatch cover off my '06, but couldn't see any problems, existing or potential.
But I did find an issue with the drain holes (five) on the hatch itself. You don't have to take the cover off to see these holes (two are visible in the photo). These drains are important to prevent rusting. Well....two were clogged with wax, and one was improperly punched out at the factory. I was able to open them all up with a small screw-driver. This chips some paint....a little touch-up paint fixed it. Something to check out...
Old 08-14-2008, 05:00 PM   #5
bluefront
bluefront's Avatar
Fan#: 56816
Strange double-post......
Old 08-14-2008, 08:59 PM   #6
1stTimeFocus00
Fan#: 44202
What I Drive: 2000 InfaRed Zx3
FF Reputation: 27 1stTimeFocus00 Great Standing Member
Buy-Sell-Trade Rating: (9)
Well what i would of done if i got my car earlier in its years was rustproof everything. My 89 ranger was fully rustproofed and its just chippin and rusting. So yea look at gettin that sheet metal and ur frame rustproofed. I think it comes in spray cans now??
Zetec Crew #152
United States Army
1stTimeFocus00 is offline
Old 08-20-2008, 12:07 PM   #7
StealthGray
StealthGray's Avatar
Fan#: 19017
What I Drive: '04 Liquid Gray ZX3
FF Reputation: 12 StealthGray Great Standing Member
I just found a couple of developing rust spots I need to take care of. For those with hatches - raise the hatch, and look along where the bumper cover fits under the hatch opening, my cover has rubbed the paint off two small spots about eight inches in from each side of the hatch opening. Sorry, no pics right now.
You know what a learning experience is? A learning experience is one of those things that says, 'You know that thing you just did? Don't do that.' - Douglas Adams
StealthGray is offline
Old 08-22-2008, 06:32 PM   #8
bluefront
bluefront's Avatar
Fan#: 56816
That last rust problem....tough one. Sounds like the hatch needs adjustment....either that or the rear bumper got hit and is pushed upward. How to fix? Maybe touch-up the edge where the paint is rubbed.....but it's likely to get rubbed off again. I'd try running a strip of that door edge guard (the clear tape type)......over the bottom edge of the hatch. Plus keep after it....
I've been taking parts off my Focus...just checking for potential rust problem areas. Took the tail lights off today. That's a bad spot on many cars that leaks water into the trunk area. Mine looked pretty good. There's a rubber boot around the wire harness.....but it looked ok. There are three plastic inserts in the body for the attachment. There are seals to keep out the water, but I applied a glob of silicone grease on each insert before I put the things back together. Should be ok....check the wire boot every few years.
Water leaks in the trunk usually end up by the spare tire.....check it frequently. If anything's wet back there find the leak....
Old 09-14-2009, 11:55 AM   #9
codemonkey
Fan#: 42989
What I Drive: 2005 Black ZX5
FF Reputation: 3 codemonkey Good Standing Member
What is the corrosion warranty on the Focus'? Is there not certain things that should be covered under that?
codemonkey is offline
Old 09-14-2009, 12:40 PM   #10
bluefront
bluefront's Avatar
Fan#: 56816
Don't know the answer to that....
I'll keep my guns, my freedom, and my money.....you can keep the "change".
Similar Threads
Rust. how to stop it, slow it down etc? honhon MK1 Focus 20 05-26-2007 07:43 AM
rust imprtslyr0223 MK1 Focus 5 07-12-2006 02:04 PM
Rust!!! Help fspeed Wheels, Tires, Brakes & Suspension - Sponsored By Tire Rack 9 10-03-2005 03:55 PM
There's Rust in my new car!!!! KAG Ford Focus & General Car Chat 24 05-25-2005 09:18 PM
Rust Around Gas filler "Neck" Kalos General Technical Chat 18 09-21-2004 02:41 PM
