How-To flush ATX fluid and change filter - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 08-11-2008, 01:01 AM   #1
focusrun
focusrun's Avatar
Fan#: 14886
What I Drive: 2000 Silver ZTS
FF Reputation: 97 focusrun Excellent Standing Member
to YOU-n00b-ersity! Greetings everyone!! I was able to change my tranny fluid with a lot of coaching from Dezurtrat and Whynotthinkwhynot (I'll call him Alex from now on, too long to type). THANKS GUYS!
Okay, I hope I am able to post the photos properly since I'm using the photobucket thingy. Here we go. This is for anyone and everyone who needs them thar info. But since I'm a n00b myself, please expect some n00b things.
Items needed:
Ramps, jack/jackstand or lift
ATX trans fluid. I used... 13-14 quarts.. OVERKILL!!
5ft/lbs capable torque wrench
Trans filter with gasket
Catch pan (whatever you wanna use) and a bucket.
screwdriver and a putty knife.
Safety glasses!! and some disposable gloves.
I might have forgotten something else but
Pre-requisite: The car must have been driven for enough time that the tranny is up to operating temperature. I drove it for at least 25 mins. That means the fluid will be hot!! Be careful.
1) Lift car via jacks/jack stand or ramps or lift. Please chock the wheels and have the emergency brakes on. No pics. If you can't do all of these... seriously consider NOT doing any work on your Focus!
2) Locate the cooler lines. This should be on in front of the driver side wheel behind the bumper and place a catch pan underneath it co'z when you pull it out, there will be some trans fluid that will come out.
Here's the return "port".
Okay, you guys might have a push clip thing hold the cooler lines.. Please refer to this post for the instruction to unclip as per Dezurtrat and Alex..
http://www.focusfanatics.com/forum/showthread.php?t=147602
3) Then I connected some tubings. Use any tubings that will fit. I didn't know where the fluid was going to come out so I had the tubings connected on both of them.
4) Place them tubings in a bucket.
5) Start the engine and watch them baby flow!!
6) You'll see it trickle down. It smelled like dead fish. It stank!
Okay to be honest, this might have been a n00b thing to do. As in might be a bad thing to do, but I stopped the engine and restarted it several times and it pump out a few squirts more of the sticky old fluid.
Now for the tranny pan.
7) Unscrew all them bolts.
8) EXCEPT FOR THE two in front so allow it to drain. Place a vessel beneath the pan to catch the remaining fluid.
9) Now, break the rtv seal using a putty knife and or a screw driver. I used the screw driver first
10) Then open the rest of the seal with a putty knife. Please use a clean one instead of a drity one like I used (n00B moment ). Alex suggest to use a plastic one too. Don't over jab that thing in the pan. You might damage the electrical wire.
11) Then thar she drops !!!
12) Here is what it looks like inside. Lots of wire thingies.
13) Disconnect that sensor thingy clip. And just pull down the filter.
14) The filter just hangs by this
15) Yuck and smelly
16) Get ready to clean the tranny pan. It was filty with fine metal shavings. Don't forget the magnet too! I just did a wash down with DAWN and scrapped off the old rtv gasket. The circle thing is the magnet.
17) I washed it down and dried it first before scraping of the old rtv. It was easier.
Okay, it wasn't a perfect. some rtv was left.
18) Prepare to install the new filter
19) I didn't take a picture but be sure to aim a small place holder thing on the other side of the filter to make it fit perfectly. You'll know what I meant when you have a new filter with you. Okay then install the filter and re-connect the sensor clip thing.
20) Then set the gasket that came with filter you bought. I made sure it came with a gasket instead of using them rtv liquid gasket thing.
Oh crap... ... Now that I'm looking at that gasket pic... Was I suppose to peel off that protective layer of the gasket. Does the gasket have a protective sticky that needs to be removed so the gasket get to be stuck on like a sticker... Crap can someone verify? I used the FRAM filter kit.. AAAARRRGGH!!
21) Then just bolt it on via a star cross pattern. Use a torque wrench that can do about 5 pounds per foot... ? (okay, n00b moment. I didn't use a torque wrench since the one i had was too big. So I.. hand tightened it to the by 5lbs/ft ). I don't have a pic of this.
Flushing...
Okay, heres what happened. I reconnected the cooler line hose and added 3 quarts of tranny fluid. And drove it around for a few days. Then decided to flush the whole thing.. as in remove as much of the old fluid since I didn't like the thought of having stinky fluid in the tranny. SO I removed the return cooler line and repeated the draining process again.
I used about 13-14 quarts to flush it out. Yeah, pretty expensive since I was using the mobil 1 thing. But I though whatever, this is fun!!
Here's what I did as per Dezurtrat's recommendation/experience. I started the engine and drain was in there. once it trickled out. I stop engine, added about 2.5 quarts and start engine.. Repeat. Until the fluid started to come out clean..er cleaner.. and no more stinky smell!! Here's the comparison on the last flush. I set aside 3.5 full quarts that was not to be used for the flush but for the final fill.
As per Dezurtrat's recomm.. I re-connected cooler line (finally) and only filled it with 2.5 quarts. Currently, I'm in the process of driving it around to and slowly bringing up the fluid level to full, since I was told it's better to NOT overfill!!! And it's easier to add than remove tranny fluid.
Oh yeah, be sure to check for leaks too.
I hope you guys find this info useful.
Thanks again to DEZURTRAT and Alex!!
MY Subaru Legacy GT FREAKING ROCKS!!!!! (But why do I still miss my Ford Focus. It's just a Ford.)
focusrun is offline
Old 08-11-2008, 01:05 AM   #2
SYZ
FocusFreak
SYZ's Avatar
Fan#: 31122
What I Drive: toxic waste
Points 8,010, Level 60
Points: 8,010, Level: 60 Points: 8,010, Level: 60 Points: 8,010, Level: 60
Level Up 30% Completed
FF Reputation: 106 SYZ Excellent Standing Member SYZ Excellent Standing Member
Buy-Sell-Trade Rating: (14)
nice write-up w/ pics!
2003 Ford Escape 4x4 Limited
On Order: 2015 Porsche Cayman S
SYZ is offline
Old 08-11-2008, 02:55 AM   #3
viney266
viney266's Avatar
Fan#: 93
What I Drive: focus ztw ,zx3,mustang, motorcycles
Points 238,851, Level 100
Points: 238,851, Level: 100 Points: 238,851, Level: 100 Points: 238,851, Level: 100
Level Up 0% Completed
FF Reputation: 112 viney266 Excellent Standing Member viney266 Excellent Standing Member
Buy-Sell-Trade Rating: (4)
Nice job !
Speed is only a matter of money; how fast do you want to go?
viney266 is offline
Old 08-11-2008, 06:25 AM   #4
whynotthinkwhynot
Captain TMI
whynotthinkwhynot's Avatar
Fan#: 18416
Points 27,933, Level 98
Level Up 59% Completed
Forum Activity 10%
Congrats!!!
The only thing I'd like to add is that when you go separating the pan from the transmission, be very careful not to pry with lots of force on the pan. You don't want to bend it so that it won't seal. Most manuals will recommend removing all the bolts, and then hitting the ban lightly with a hammer until the pan loosens/falls off. Well, that's all find and dandy for the guy writing it, but he's not going to clean up the transmission fluid all over the freaking driveway.
My suggestion is to drain as Focusrun wrote, then remove most of the bolts from the pan leaving enough for the corners. Loosen these bolts as much as possible. Then use a plastic putty knife to push in and separate the old RTV.
Everything else is very correct- including the part about searching for a filter kit with a gasket. I expected a rubber gasket, but that one looks like a good one. Yes, you have to remove the cellophane from the adhesive on the gasket, then make sure it's positioned correctly, and stick it to either the pan on the transmission- which depends on which side the adhesive is on. Line up one hole and work your way around.
I know a lot of people here don't like Fram products, but just the adhesive backed gasket alone makes that kit sound worthwhile IMO. Without adhesive backing, use a thin coat of RTV under the gasket, put the gasket on the pan, flip the pan over onto a flat surface making sure that holes still line up, put some weight on it to be sure it's all flat, and wait until it's set in place. 15 mins or so.
Many many thanks to Focusrun for making this HOW-TO with pics!! We'll surely have to add it because we desperately need one for all the ATX junkies out there
Be eclectic.
You're special aren't you.
whynotthinkwhynot is offline
Old 08-11-2008, 06:40 AM   #5
joshfink
joshfink's Avatar
Fan#: 50565
What I Drive: Black 2007 ford Focus
FF Reputation: 4 joshfink Good Standing Member
Awesome write up! Rep for you... Been looking for a good write up on this as my tranny fluid needs to be changed soon! Now I shall attempt it on my own yay!
"Whoopie! That may have been a small one for Neil but it was a long one for me!" - Pete Conrad stepping off the LEM onto the lunar surface during Apollo 12.
joshfink is offline
Old 08-11-2008, 10:51 PM   #6
dezurtrat
Fan#: 53144
What I Drive: 2006 White
FF Reputation: 1 dezurtrat Good Standing Member
Awesome write up focusrun!!!!!
dezurtrat is offline
Old 08-11-2008, 11:17 PM   #7
Mr.Bergner
coffee, have some
Mr.Bergner's Avatar
Fan#: 32799
What I Drive: 2004 TW Blue ZX3
Points 6,353, Level 52
Points: 6,353, Level: 52 Points: 6,353, Level: 52 Points: 6,353, Level: 52
Level Up 2% Completed
FF Reputation: 53 Mr.Bergner Excellent Standing Member
Buy-Sell-Trade Rating: (12)
Wow, very nice!
How many miles do you have on it when you did this?
Mr.Bergner is offline
Old 08-13-2008, 01:08 AM   #8
MeAnDg5
MeAnDg5's Avatar
Fan#: 10097
What I Drive: 2004 White ZX3 2.3 Duratec
FF Reputation: 1 MeAnDg5 Good Standing Member
Great write-up. When you connect the tubing to drain, does it drain only out of one tube?
Howie
MeAnDg5 is offline
Old 08-13-2008, 12:40 PM   #9
focusrun
focusrun's Avatar
Fan#: 14886
Hi guys! I'm very glad you guys find this helpful.
Mr. Lemon has 91k miles
And the fluid came out of the tubing connected to the port.. Not the tubing connected to return hose.
Hope this helps.
focusrun is offline
Old 08-14-2008, 09:33 AM   #10
S2
Retired Fanatic
S2's Avatar
Fan#: 4939
What I Drive: Camaro 2SS/RS
FF Reputation: 67 S2 Excellent Standing Member
Buy-Sell-Trade Rating: (20)
Added to the 'HOW TO ARCHIVE'.....
Chad (S2)
S2 is offline
Similar Threads
MTX Fluid Change? Coolant Flush? Djmike2485 General Technical Chat 13 12-16-2007 10:04 PM
ATX fluid change with RP? Mr.Bergner ZETEC Performance (2000-2004) 6 02-08-2007 06:01 PM
How change ATX fluid at 30K cking General Technical Chat 0 08-28-2006 09:22 AM
Vehicle Maintenence Schedule S2 General Technical Chat 0 05-08-2006 11:57 AM
ATX Shifts Hard After Fluid and filter change 2k2zx3 General Technical Chat 5 02-16-2006 09:03 PM
