CFM Tubular Front Control Arms NOW AVAILABLE! - Page 8 - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Go Back   Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum > Exclusive Vendor Discussions > Central Florida Motorsports
Central Florida Motorsports Discuss about performance and appearance upgrades for your Ford Focus.
Sponsored By: C-F-M.com
Old 08-17-2010, 01:47 PM   #71
kbrownfocus
kbrownfocus's Avatar
Fan#: 14709
What I Drive: 2009 Dodge Journey waiting on my ST
Points 289, Level 5
Points: 289, Level: 5 Points: 289, Level: 5 Points: 289, Level: 5
Level Up 78% Completed
FF Reputation: 1 kbrownfocus Good Standing Member
Originally Posted by illinipo View Post
the knowledge base required for properly doing aero engineering is COMPLETELY different from the knowledge base required for properly designing mechanical parts. As a mechanician with friends in aero engieering, I can assure you that my friends are not qualified to design these arms. (and I also recognize that I cannot design airplanes...)
Im sorry to be blaint, but the materials and the design of these LCA's are designed the same way landing gear for jets and airlines are, they are made as one peice, not tigged together and seamed. Sad thing is its 500% over the stock LCA's witch are weak and just straight junk. and an aero engineer should make these because the simple fact that if it is made the same way landing gear is made then hell a 4000LBS max vehicle realy isnt anything to even put the least amount of stress on the tubing.
kbrownfocus..02 Yellow ZX3
ZETEC Crew #341
kbrownfocus is offline
Old 08-17-2010, 04:39 PM   #72
bradshsi
bradshsi's Avatar
Fan#: 58770
What I Drive: 2002 Sonic Blue Turbocharged SVT
Points 342, Level 6
Points: 342, Level: 6 Points: 342, Level: 6 Points: 342, Level: 6
Level Up 84% Completed
FF Reputation: 6 bradshsi Good Standing Member
Buy-Sell-Trade Rating: (4)
Hmm, I realize this is probably not the forum to go too deep into the engineering of structures to resist fatigue, but some good points have been raised already. As someone who designs structural parts and machinery I'm concerned regarding the explanation given so far by CFM.
The control arms that failed appeared to do so after less than 4 months of use. That sounds consistent with a low cycle fatigue failure.
The discussion in the other FC thread was that the tube material was out of specification (high carbon instead of whatever grade they used since they are not saying, My guess is the planned to use ASTM A513 1020 or 1026). This would be a plausable reason since trying to use the same weld procedure with a high carbon content steel would cetainly give you very brittle welds prone to cracking and fatigue failure. (This is contrary to the statement made above that it was a "weak spot" in the metal.)
My question is:
If the issue is simply poor quality control at the manufacturer due to incorrectly identifying tubing material, why are CFM requiring gussets be added ? These won't help if the same material identification failure happens again.
So that leaves the question of whether there is some other issue ? Has any FEA and fatigue analysis been done ? Has the weld procedure been reviewed ?
Personally I'd like to see the proposed solution address the original cause of the faulure. Everything else is just fluff.
Sona si latine loqueris
bradshsi is offline
Old 08-17-2010, 04:59 PM   #73
bradshsi
bradshsi's Avatar
Fan#: 58770
Points 342, Level 6
I'd also note that contrary to claims made on the thread:
ASTM A108 1018 is not brittle (actually it's really ductile and easy to successfully weld vs ASTM A513 1020 or 1026).
Both MIG and TIG can have excellent penetration. The issue is careful control of the weld parameters (that's what I employ my welding engineer to determine). The carbon equivalent of the steel is much more of a concern. High carbon equivalents make the tolerance for out of parameter welds smaller. At a carbon equivalent of over 0.5% you are basically assured that your welds will fail.
bradshsi is offline
Old 06-30-2011, 05:31 PM   #74
SPI Tuner
Fan#: 47140
What I Drive: 2001, Red, LX
Points 90, Level 1
Points: 90, Level: 1 Points: 90, Level: 1 Points: 90, Level: 1
Level Up 80% Completed
FF Reputation: 1 SPI Tuner Good Standing Member
Any one got any pics
Hey just wanted to know if anyone who has been talking about getting these installed on there car have any pictures on what it looks like. Also does it lower the car any I have a Eibach set up and I was just wondering if there was any lowering or tucking that it would do to the tires if installed. I ask because my front 15" tires stick out a little after I got it aligned by a guy at the dealership. He was a little confused on how to adjust camber until I showed him how to adjust under the hood. Sorry its a long statement but I figured since I found this if there was a way to fix this or if it is just something I have to live with. If you guys need pix I can take them and post on the forum of I need to be redirected somewhere else for an answer.
Thanks A lot
Last edited by SPI Tuner; 06-30-2011 at 05:32 PM. Reason: changing some misspelling problems
SPI Tuner is offline
Old 07-01-2011, 07:02 AM   #75
PSUrivie
PSUrivie's Avatar
Fan#: 67329
What I Drive: Boostin in the Mid-A
Points 7,162, Level 56
Points: 7,162, Level: 56 Points: 7,162, Level: 56 Points: 7,162, Level: 56
Level Up 6% Completed
FF Reputation: 15 PSUrivie Great Standing Member
Buy-Sell-Trade Rating: (10)
I have these installed on my 09. Sorry the car is so dirty, these were taken right after winter. These are worth every cent. The have held up very well and cornering is sik!!!
I read through this thread and honestly, some of you guys need to lay off the crack rock.
FSWerks stg2 w/ water/meth; Cossie intake.
PSUrivie is offline
Old 07-01-2011, 07:56 AM   #76
benkap
Hatch Nation #136
benkap's Avatar
Fan#: 86366
What I Drive: 2003 Mineral Grey Metallic ZX3
FF Reputation: 14 benkap Great Standing Member
Mine come in today. I couldn't be more excited.
benkap is offline
Old 07-01-2011, 12:19 PM   #77
PSUrivie
PSUrivie's Avatar
Fan#: 67329
oh yeah, whatever happened to the rear control arms you guys were making?
PSUrivie is offline
Old 07-15-2011, 11:21 PM   #78
felixthecat
w/ my magic bag
felixthecat's Avatar
Fan#: 80663
Points 13,699, Level 76
Points: 13,699, Level: 76 Points: 13,699, Level: 76 Points: 13,699, Level: 76
Level Up 13% Completed
Forum Activity 100%
Activity: 100% Activity: 100% Activity: 100%
I've had my on since 7-10, no problem at all. I used a couple of jam nut's to replace the lock-nut, to make it easier to remove if I have to, & I start out w/ 4.5 turn's out, & that made my camber -1.7 degree's. Lighter weight, more forward bite, adjustable camber= win, win ,win !
felixthecat is online now
Old 07-17-2011, 02:33 PM   #79
Blue5ive
R.I.P Kona
Blue5ive's Avatar
Fan#: 83941
What I Drive: 2003 TW Blue ZX5
Points 7,577, Level 58
Points: 7,577, Level: 58 Points: 7,577, Level: 58 Points: 7,577, Level: 58
Level Up 14% Completed
Forum Activity 28%
Activity: 28% Activity: 28% Activity: 28%
FF Reputation: 10 Blue5ive Great Standing Member
Buy-Sell-Trade Rating: (8)
Interested to see how these hold up in the long term and with some aggressive hard driving. Keep us updated.
Team Focalize
Hatch Nation #9
"2 by 2 Hands of Blue."
Blue5ive is online now
Old 08-12-2011, 09:33 PM   #80
Andrew
Andrew's Avatar
Fan#: 6565
What I Drive: 08 Caliber SRT4, 05 ZX5 SES
FF Reputation: 2 Andrew Good Standing Member
Buy-Sell-Trade Rating: (6)
Make them for the 05s and up yet?
Andrew is offline
Similar Threads
The Ford Focus Parts List! gthang MK2 Focus 13 01-27-2009 12:05 AM
Focus Rear Tire Wear - Camber Bolts or Control Arms? 2003focusowner Brakes, Suspension & Body Chassis 8 04-05-2008 06:32 PM
Fried PCM!? On my SVT 02_SonicBluSVT SVT Performance (2002-2004) 31 06-12-2007 10:48 AM
Need new front lower control arms... gthang Ford Focus & General Car Chat 23 11-19-2003 12:35 PM
