Brake light keeps flashing! Help please!!! - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 08-10-2008, 01:29 AM   #1
<focusONthis>
<focusONthis>'s Avatar
Fan#: 55388
What I Drive: 2002 silver ZX3
FF Reputation: 1 <focusONthis> Good Standing Member
Buy-Sell-Trade Rating: (6)
My car starts up fine. Emergency brake lifts and drops like normal. The car drives good. But as I'm driving, the red emergency brake light on the dash flashes on and off during the whole drive. I double check the emergency brake to make sure its all the way down but it still flashes on and off. I'll be pushing the gas pedal (not even touching the brake pedal) and it still flashes. Does anyone know what this could be? My brakes aren't too old either. PLEASE HELP!!!
SoCal Crew#16
Zetec Crew#289
<focusONthis> is online now
Old 08-10-2008, 01:41 AM   #2
DarkFire1986
暗炎
DarkFire1986's Avatar
Fan#: 40966
What I Drive: 2010 Silver Fusion, 1994 Ranger
Points 3,421, Level 36
Points: 3,421, Level: 36 Points: 3,421, Level: 36 Points: 3,421, Level: 36
Level Up 48% Completed
Level up: 48% Level up: 48% Level up: 48%
FF Reputation: 31 DarkFire1986 Great Standing Member
That light is telling you somethings wrong with your brake system. If your ebrake is down, I'd start by checking the fluid level.
Originally Posted by mofocus View Post
my car makes babies cry
DarkFire1986 is offline
Old 08-10-2008, 05:14 AM   #3
zappaMan
Fan#: 44
What I Drive: 2000 SE - Zetec Swap
FF Reputation: 63 zappaMan Excellent Standing Member
If it is flashing on and off, especially irregularly, I would check to see if your E-brake position switch is working correctly. I have had one that was going which would flash on and off whenever I went over a bump.
zappaMan is offline
Old 08-10-2008, 05:18 PM   #4
<focusONthis>
Fan#: 55388
The brake fluid looks ok. I could probably add a little but its not below the min. line.
But I got my shift cable replaced not 2 long ago and when I got my car back, the ebrake felt like it was rubbing something everytime I dropped it. It did this 4 so many weeks and then stopped. U think they could've taken the console out, put it back in when they were done, and messed something up?
Also, my trans has been screwing up. 2nd gear grinds when its hot and the gears feel out of place when I'm shifting. The gears feel loose. The stick doesnt shift into gear like normal. Since the brake fluid and clutch fluid are together, and the clutch is in the trans, is there a way that it can be sensing the trans problem? If this is a dumb question, sorry. But I was just curious and trying 2 figure out something it could be. But I'm sure u see how I came up with that.
SoCal Crew#16
Zetec Crew#289
Old 08-10-2008, 05:32 PM   #5
Blackcatn2o
soon to be turbo!
Blackcatn2o's Avatar
Fan#: 48278
What I Drive: 06 silver ZX4 ST
Points 8,020, Level 60
Points: 8,020, Level: 60 Points: 8,020, Level: 60 Points: 8,020, Level: 60
Level Up 35% Completed
Level up: 35% Level up: 35% Level up: 35%
FF Reputation: 48 Blackcatn2o Great Standing Member
Buy-Sell-Trade Rating: (13)
I second that
Blackcatn2o is offline
Old 08-10-2008, 05:46 PM   #6
Blackcatn2o
soon to be turbo!
Fan#: 48278
I second that
Old 08-10-2008, 09:03 PM   #7
zappaMan
Fan#: 44
You have to take the console off to do the shift cables so I think you have found your culprit!
zappaMan is offline
Old 08-10-2008, 09:28 PM   #8
Blurvfocus
Blurvfocus's Avatar
Fan#: 15299
What I Drive: 03 ZX3 Wine Cooled Eng.
FF Reputation: 54 Blurvfocus Excellent Standing Member
If the pads are fairly new, the fluid level should be near the max line, not the nin line. I suggest you add a little fluid and see where you stand. It's a lot easier than ripping your console out, only to find out a tablespoon of brake fluid would have fixed it, no?
Often wrong but never in doubt.
Blurvfocus is offline
Old 08-10-2008, 09:37 PM   #9
zappaMan
Fan#: 44
The throw-out bearing and clutch are not in the transmission, they are between the tranny and the engine in the bell housing. It certainly is possible that it could be the fluid sensor, but if you had work done on the console and you felt your e-brake snag on something it really does point to the ebrake position sensor. It isin't that bad to remove the centre console. It also doesn't make sense to buy a litre of brake fluid to add a touch when you know you can't use it if it sits for more then a month or two.
zappaMan is offline
Old 08-10-2008, 10:08 PM   #10
gonzorelic
gonzorelic's Avatar
Fan#: 13348
What I Drive: 2003 Pitch Black SVT Focus ZX5
FF Reputation: 31 gonzorelic Great Standing Member
pull the boot off the e brake handle. there is a small push button under there facing upward. thats your problem. my car and my friends car both do this. they just flash irregularly. the reason is the button may be going bad or it might have gotten worn on top a bit and the e brake handle doesnt fully push down on the button when its all the way down.
Jealousy is contagious,
Get well soon bitch!
WWW.PATTERNTEK.COM
WWW.SNAPOFFRACING.COM
gonzorelic is offline
Similar Threads
Brake information and educational materials Geezer Wheels & Tires 26 01-07-2009 12:35 PM
brake light mattstpier General Technical Chat 4 01-28-2008 07:34 PM
Brake Light DDyas General Technical Chat 6 05-08-2006 03:56 PM
question about 3rd brake light problem vanman MK1 Focus 0 04-29-2006 02:57 PM
Does your brake light work with key off? djdj General Technical Chat 1 02-22-2006 02:04 PM
