questoion on auto locks - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Go Back   Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum > Ford Focus Discussions > Ford Focus & General Car Chat
Old 10-10-2003, 12:11 AM   #1
dbenney
Fan#: 1195
What I Drive: 2012 Tuxedo Black SEL
Points 953, Level 16
Points: 953, Level: 16 Points: 953, Level: 16 Points: 953, Level: 16
Level Up 53% Completed
FF Reputation: 5 dbenney Good Standing Member
the auto locks that lock when u drive a few feet really annoy me! i have an F150 that also has this feature. in the owners manual it told how to disable this feature. i looked all through my focus manual and couldnt find ne thing on this. does anyone know how to disable the autolocking?
Thanks
dbenney
dbenney is offline
Old 10-10-2003, 12:58 AM   #2
Red RocketZx3
Fan#: 424
What I Drive: 2001 Infra Red Zx3
FF Reputation: 1 Red RocketZx3 Good Standing Member
why would you want to? i dont even notice it anymore. and its kinda safe ya know?
Red RocketZx3 is offline
Old 10-10-2003, 02:07 AM   #3
avengerc4
Broken cars s[:)][:)][:)] :(
avengerc4's Avatar
Fan#: 493
What I Drive: 02 PWorks SVTF, 2014 Subaru Outback
FF Reputation: 4 avengerc4 Good Standing Member
Buy-Sell-Trade Rating: (17)
not reaslly if someone stole u'r car and u wanna get in! well also not to mention you have to remember to re-unlock the doors to let u'r friends in when u drive down the block to pick emup! meh I dunno its good yet bad
-Joe
PS: sorry didn't answer q...dunno how to shut it off...most fords are the same though try the manuals way in the f150 book it'll prob work...when I went to get my third key7 made cause I gonna get remote start and still want 2 keys, the guy who programed it said it was the weirdest car yet, everything as still the same with the put in first key, start car, second key start car, third key start car, but you have to have the doors locked and the seatbelt on to do it...no other fords like that...maybey if you tweek the f-150 auto disable thing it'll work somehow...just a suggestion
September ride of the month(2006)
Good judgment is based upon experience. Experience is based upon BAD JUDGMENT!!!
FF Member#: 493 and STILL LEARNING!
avengerc4 is offline
Old 10-10-2003, 02:40 AM   #4
FociFreak
FociFreak's Avatar
Fan#: 978
What I Drive: '01 ZX3 Cloud-9
FF Reputation: 1 FociFreak Good Standing Member
There is a way to do it. It's on Focus hacks web site.
http://www.focushacks.com/
It's listed under the misc. section.
'01 ZX3 Cloud-9 White - Mac Short Air Intake, Magnaflow Cat-Back
SHM 17" Wheels
FociFreak is offline
Old 10-10-2003, 06:17 PM   #5
bfocused
bfocused's Avatar
Fan#: 63
What I Drive: I now drive a 2009 Focus SES
FF Reputation: 2 bfocused Good Standing Member
I had to do this after being locked out of my SVTF. I parked the car and closed the doors, 20 seconds later... doors go click...with the Fing keys in the ignition. We were getting ice cream and planned to be only a few feet away from the car, so I saw no reason to take my keys WRONG. I called road-side and they bailed my dumb ass out. The very next day I was in the car reading the manual on how to dis-able auto lock feature. Yes, it is in there right in the section about keys and door locks.
"The present day composer refuses to die"
Edgar Varese 1883-1967
bfocused is offline
Old 10-10-2003, 06:53 PM   #6
dbenney
Fan#: 1195
huh???? iv looked thru that manual a dozen times. either i was looking too hard & overlooked it or its not in the 2000 manual.
dbenney is offline
Old 10-11-2003, 02:54 AM   #7
FociFreak
FociFreak's Avatar
Fan#: 978
I believe the '03 and up(?) let you disable it with some sequence of things (like the seat belt reminder). The earlier ones require a physical fix. You have to cut a wire near the computer. This hack also lets you use the keyless entry while the car is running.
Check it out.
SHM 17" Wheels
Old 10-11-2003, 12:54 PM   #8
dbenney
Fan#: 1195
ah ok. My wife drives an 02 ZTS and it tells how in her om. I followed those directions and nothing! bah humbug. i guess i'll either live with it or do the mod mentioned earlier in this thread. i can however disable hte seatbelt minder. it tells how in my 2000 ownersman. thanks for hte help guys.
dbenney is offline
Old 11-17-2003, 09:54 PM   #9
dan81
dan81's Avatar
Fan#: 1788
What I Drive: '04 Liquid Metallic ZX3
FF Reputation: 1 dan81 Good Standing Member
This Works for Auto Door Locks!
This worked on my 2002 SE Wagon.
The enable/disable mode is entered when the following series of steps is performed:
1. Confirm that the perimeter alarm is disarmed.
2. Close all doors.
3. Confirm that the ignition switch is in the OFF position.
Note: Steps 4 through 8 must be performed within 30 seconds.
4. Turn the ignition switch from OFF to RUN.
5. Press the power door lock UNLOCK button three times.
6. Turn the ignition switch from RUN to OFF.
7. Press the power door lock UNLOCK button three times.
8. Turn the ignition switch from OFF to RUN.
9. Verify that the RAP module chirps the horn. This indicates that the RAP module is now in the enable/disable mode and ready to accept program changes.
10. Press the power door lock UNLOCK button one time to command the RAP module to toggle the autolock/relock feature ON or OFF.
11. Press the power door lock LOCK button once to enter the command.
12. Verify that the vehicle horn chirps one time to signal the RAP module confirmation of the command. There should only be one chirp indicating that the autolock/relock feature has been disabled. If one chirp is heard, followed by a longer honk, the autolock/relock feature has just been enabled. Return to step 10.
13. Turn the ignition switch to the OFF position to exit the enable/disable mode.
14. Verify that the RAP module chirps the horn once to indicate that a feature has been changed.
dan81 is offline
Similar Threads
Manual vs. Auto - Impact on Performance penguin Ford Focus & General Car Chat 26 05-28-2007 03:34 PM
Updated Nurburgring lap times... Carrera26 Ford Focus & General Car Chat 5 03-16-2006 09:49 AM
WTB: Auto door locks golden305pervert Archive 6 04-07-2005 12:11 PM
auto. door locks imFOCUStman MK1 Interior Mods & Upgrades 7 11-05-2004 10:17 PM
Power Door locks d_e_f General Technical Chat 2 06-11-2004 07:56 PM
