Common Ford Focus Transmission Problem, How to fix - Page 5 - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 09-19-2009, 10:57 AM   #41
Henry Ford
Henry Ford's Avatar
Fan#: 61680
What I Drive: 2002 white zts
FF Reputation: 1 Henry Ford Good Standing Member
well just an up date on my focus it took longer to get it into the next shop just got it back today $340.00 was how much it ended up being . it was two solenoids the two little ones if you only do the one it weal burn it right out again the shop found that out the hard way but ford covered it and it didn't cost me anything if i would have did it myself i would have pay for three of them instead of two plus he cleared the codes changed filter,gasket,fluid and added conditioner additive now it shifts better then when it was new.O and there was nothing wrong with anything else like the first shop said! So before you pay haft what the car is Worth ask someone else.Solenoids cost $134.52 throu ford.
Sedan Revolution member# 160
Henry Ford is offline
Old 10-20-2009, 01:36 AM   #42
ChuckDee
Ehh...
ChuckDee's Avatar
Fan#: 43589
What I Drive: 02 SC SVT
Points 17,687, Level 84
Points: 17,687, Level: 84 Points: 17,687, Level: 84 Points: 17,687, Level: 84
Level Up 68% Completed
FF Reputation: 48 ChuckDee Great Standing Member
Buy-Sell-Trade Rating: (6)
great write up! ima use this info and replace mine soon.
unique(adj): to break off from the crowd and do your own thing
ChuckDee is offline
Old 10-22-2009, 11:54 PM   #43
Lancer211
Lancer211's Avatar
Fan#: 65747
What I Drive: 2004 infrared sedan SE
FF Reputation: 4 Lancer211 Good Standing Member
Buy-Sell-Trade Rating: (9)
It's actually not too hard to get from here to swapping in a performance valvebody, either.
2004 Zetec infrared ATX sedan SE "Ruby"
CarDomain page: http://www.cardomain.com/ride/3345563
Lancer211 is offline
Old 11-17-2009, 07:03 PM   #44
gratefulluke
Fan#: 63264
What I Drive: 2002 Twilight Blue SE
FF Reputation: 1 gratefulluke Good Standing Member
Thanks for this info! Swapped out Solenoid "A", no sweat. $50 for the solenoid from the dealer and $5 for the liquid gasket.
gratefulluke is offline
Old 11-19-2009, 11:21 PM   #45
cmurdah
Fan#: 54806
What I Drive: 05 se
FF Reputation: 3 cmurdah Good Standing Member
Posted via FF Mobile
so i pulled code for the "d" solenoid, think it was p0765 or something, im sure the last digits were 65 and it used theword "ssd" on the printout. i read the guide, which is great, but for the code i have the OP listed to "check pinpoint a" and im not really sure what that means?
engine light is on, very rough shifting at low speeds and in/out of gear. 02 zts 103k miles
cmurdah is offline
Old 03-28-2010, 10:02 AM   #46
tiger61378
tiger61378's Avatar
Fan#: 54476
What I Drive: 2003 Red ZX3 Sport
FF Reputation: 3 tiger61378 Good Standing Member
This is a great writeup, and since I have code 0750, I'll be getting that solenoid A in the next couple of days.
Hatchback Lover #53
tiger61378 is offline
Old 03-28-2010, 07:59 PM   #47
runfocusrun
runfocusrun's Avatar
Fan#: 43029
What I Drive: 2002 Infra-red ZX5
FF Reputation: 8 runfocusrun Good Standing Member
Hi guys, haven't been on the site in quite a while, remember I said I thought my solenoids were gone ? Well finally late october '09 I went to Ford, spoke to the master of transmissions there, hence the guy has 35 yrs of experience only in Ford tranny's, we hooked a computer on the car and went driving, guess what, there's absolutely nothing wrong with the tranny, it only is a tiny bit hard on the lock-up (yes I drive an automatic) but further all is ok. Ended up paying 45 $ for the check up but it was worth it.
ZETEC CREW # 121
Current: Volant intake, RS headlight kit, motor/interior parts painted
Upcoming: 2'5 Header, flex & exhaust, Saleen/Eibach susp. & swaybars, small turbo to get some more oumph
runfocusrun is offline
Old 03-29-2010, 09:53 AM   #48
tiger61378
tiger61378's Avatar
Fan#: 54476
Hey, not too bad...
And, btw, a little tip for people. You can get a PocketScan from Advance Auto Parts for around $80. It just gives the codes & lets you clear em, but its about the best $80 I ever spent (needed the thing when I had my old Geo Tracker...damn check engine light would never go out, it had so many problems LOL). I'd call it an essential for your tool box (or better, glove box...easy to hook up to the OBDII port on the Focus, and you have it if you get a sudden check engine light while driving).
Hatchback Lover #53
Old 04-13-2010, 09:32 AM   #49
Livens
Fan#: 52547
What I Drive: 2002 Silver ZX5
FF Reputation: 1 Livens Good Standing Member
my ATX is now fixed
Here is my experience with the 4F27E ATX.
It started slipping out of 4th and progressed to not going into 4th at all, and slipping out of 3rd gear. A week later I lost reverse completely. So I was thinking 'rebuild' and big $$$. But after reading this article I was convinced that it was the SSA. So I went to Ford and got one for $47 and swapped it out. Nothing. No change.
So I asked a freind of mine if her Husband, who is a master mech., could fix it. No problem she said. He took the ATX out and tore it down. He found the problem, or a problem. There is a small snap ring about 3 inches in diameter that hold the 'inards' of the reverse/4th gear drum together. It had popped out of place causing things to be loose and no pressure was able to build up. It looksl ike Ford had realized there was a problem with this because they redesigned another ring that helps keep that one from coming out. The original had tabs along the inside that held the ring in, new one was solid all the way around.
Anyway he got it all back together replacing a few seals and a new piston for the reverse drum, it had a depression in a rubber ring or something were the retaining ring had popped out. Yeah, fixed! Almost...
The next day it starts slipping in 3rd and wont go into 4th. Check engine light is on. Slip into Autozone and its code P0755, the SSB. Fortunatly the SSA and SSB solenoid are identicle, so I swap out my original SSA for my SSB. Success! It looks like my ATX had 2 problems, the retaining ring and a bad SSB.
Thanks for the great writeup on these solenoids! Really gave me the confidence to do them myself!
PS. I dont believe in coincidences. Having a solenoid go bad and a retaining ring pop out at almost the same time... they have to be related. Im wondering if the jerking from the ATX slipping put too much pressure somehow on that reverse drum?
Livens is offline
Old 04-24-2010, 03:03 AM   #50
memphisguy2000
memphisguy2000's Avatar
Fan#: 19671
What I Drive: 2001 Ford Focus SE
FF Reputation: 1 memphisguy2000 Good Standing Member
Question......
I have almost 185,000 miles on my 2001 atx, and have had zero issues. I'll be changing the transmission filter and fluid this coming weekend. I am guessing thsi is not something I can do just because I have the pan cracked open right? In other words, do not change out the solonoid until I have an issue right?
memphisguy2000 is offline
Similar Threads
Zero to 60 & 1/4 Miles Times (List of all cars) OrangeSVTguy Drag Racing 36 07-09-2013 10:48 PM
Ford debuts Focus Coupe-Cabriolet Kneel Ford Focus & General Car Chat 50 10-02-2011 08:04 PM
Big plans for tiny Focus remusrm Ford Focus & General Car Chat 50 08-19-2009 02:51 PM
The Ford Focus Parts List! gthang MK2 Focus 13 01-27-2009 12:05 AM
Even this fOCUS!!!! Jeezzzz!!!! TORQUERULES Ford Focus & General Car Chat 22 02-11-2007 11:47 PM
