Common Ford Focus Transmission Problem, How to fix - Page 3 - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 11-10-2008, 12:53 PM   #21
S2
Retired Fanatic
S2's Avatar
Fan#: 4939
What I Drive: Camaro 2SS/RS
FF Reputation: 67 S2 Excellent Standing Member
Buy-Sell-Trade Rating: (20)
Added to the 'HOW TO ARCHIVE'......
Chad (S2)
S2 is offline
Old 12-27-2008, 06:12 PM   #22
keifer56
Fan#: 52794
What I Drive: '01 Ford Focus
FF Reputation: 1 keifer56 Good Standing Member
Slipping Tranny
hi , got the PO761 code & also PO734 , changed the "A" solenoid , filter & fluid ,, but it didn't help ,,do u have a diagram of the solenoids , i think it might b the "C" solen. but don't know which 1 it is ,,thanks ,,keith ,,
keifer56 is offline
Old 01-02-2009, 03:10 PM   #23
wolfem631
Fan#: 61643
What I Drive: 2003 Pitch Black ZX5
FF Reputation: 1 wolfem631 Good Standing Member
Shift Solenoid "b"
Hi and thank you for the information you've already listed.
I am looking all over for a SHIFT SOLENOID "B" for my 2003 Ford Focus, 2.0. I had Autozone read my code and this is what it says...P0755 OBDII. I cannot find anything about a shift solenoid b anywhere! When I asked the parts dude at the dealer he was unfamiliar with it and according to his computer, the replacement solenoids were not listed as A, B, C, etc...
According to some of the drawings I've found, it looks like the A and B could be the same part??? Is that the case? Maybe the A or B designates location, not type??? Just trying to get this part ordered so I can fix it!
PS--here is what the parts dude at the dealer offered me...a shift solenoid package for $120ish and the turbine shift for $30ish.
THANK YOU IN ADVANCE!!!!
wolfem631 is offline
Old 01-11-2009, 11:46 PM   #24
Steve89
Fan#: 61870
What I Drive: 1991 Ford Ranger
FF Reputation: 1 Steve89 Good Standing Member
Hey,
I just thought I'd post and let other people know that this is great information.
A friend of mines daughters '03 Focus had a transmission problem, (something with the pinion bearing) and he went out and bought a used tranny from the wreckers. Well, after it had been installed there was no fourth gear when overdrive was enabled.
He asked me if I could fix the problem or at least give him advice before he brought it back to the transmission shop. Well, after 10 minutes on google, I came across this post and it matched the symptoms exactly. Popped the oil pan off and the clips for two of the solenoids were all broken a beaten up. I'm pretty sure it was from the wrecker yard throwing the transmission around(old tranny pan was beaten to shit). Since I had access to the old transmission, I just took the solenoids off of that one. Had to re-solder a new plug for the solenoid in and replaced both beaten up solenoids.
Put her all back together, and the car shifted perfectly. My friend and his daughter are relieved to finally have the car working properly again.
Thanks
-Steve
Steve89 is offline
Old 01-11-2009, 11:50 PM   #25
Steve89
Fan#: 61870
Hey,
Thanks
-Steve
Steve89 is offline
Old 03-06-2009, 09:42 PM   #26
briandg510
briandg510's Avatar
Fan#: 3966
What I Drive: 2001 Fort Knox Gold ZTS
Points 1,409, Level 21
Points: 1,409, Level: 21 Points: 1,409, Level: 21 Points: 1,409, Level: 21
Level Up 9% Completed
FF Reputation: 118 briandg510 Excellent Standing Member briandg510 Excellent Standing Member
Buy-Sell-Trade Rating: (13)
Thanks for sharing. Good info for the community.
briandg510 is offline
Old 03-07-2009, 06:29 PM   #27
DrkKnight614
GO Green
DrkKnight614's Avatar
Fan#: 14522
Points 26,111, Level 96
Points: 26,111, Level: 96 Points: 26,111, Level: 96 Points: 26,111, Level: 96
Level Up 77% Completed
FF Reputation: 47 DrkKnight614 Great Standing Member
I just hope Fords new Powershift 6speed auto trans doesnt have as many problems as our 4 speed atx does lol.
My 2003 Ford Focus ZX3 - Finally realized it's a 4cyl
DrkKnight614 is offline
Old 03-07-2009, 08:16 PM   #28
a_2000_se
a_2000_se's Avatar
Fan#: 62964
What I Drive: 2000 SE SOHC SPI, Compression @ 164
Points 4,699, Level 43
Points: 4,699, Level: 43 Points: 4,699, Level: 43 Points: 4,699, Level: 43
Level Up 75% Completed
Forum Activity 5%
FF Reputation: 15 a_2000_se Great Standing Member
Good to see posts like this one. It is just as good to see posts from those that had problems and post a follow-up to their problem/fix/solution so all can learn from them.
a_2000_se is offline
Old 07-22-2009, 11:53 PM   #29
Henry Ford
Henry Ford's Avatar
Fan#: 61680
What I Drive: 2002 white zts
FF Reputation: 1 Henry Ford Good Standing Member
Was going to work to day car was in 4th then RPM went way up I then had no OD I down shifted in to 2nd and it worked lock out overdrive and 3dr worked took off lock and 4th was not there left set at work for 8 hours and it was fine for 3or4 miles then it did it again this time my emition light came on went up the road in 3rd for one mile and the transmission was good the rest of the way home but light is on now?
Sedan Revolution member# 160
Henry Ford is offline
Old 07-24-2009, 04:02 PM   #30
nardvark
Fan#: 54394
What I Drive: 06 ZX4, 05 Mazda6 Wagon, 06 Miata
FF Reputation: 1 nardvark Good Standing Member
I would caution people against re-using old fluid. If it sits in a drain pan, it's very likely to collect dirt, random plant matter, dust, and anything else that's floating around in the air. You don't want that in your transmission. I think the advice is given so that you put the right amount back in (and don't overfill it by mistake), but a little care and you can put in the same amount of new fluid.
nardvark is offline
Similar Threads
Zero to 60 & 1/4 Miles Times (List of all cars) OrangeSVTguy Drag Racing 36 07-09-2013 10:48 PM
Ford debuts Focus Coupe-Cabriolet Kneel Ford Focus & General Car Chat 50 10-02-2011 08:04 PM
Big plans for tiny Focus remusrm Ford Focus & General Car Chat 50 08-19-2009 02:51 PM
The Ford Focus Parts List! gthang MK2 Focus 13 01-27-2009 12:05 AM
Even this fOCUS!!!! Jeezzzz!!!! TORQUERULES Ford Focus & General Car Chat 22 02-11-2007 11:47 PM
