Common Ford Focus Transmission Problem, How to fix - Page 2 - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 10-26-2008, 09:38 AM   #11
stphnlfr
Fan#: 60061
What I Drive: Silver 2005 ZX3 SE
FF Reputation: 1 stphnlfr Good Standing Member
From the top post, why reuse the old fluid? aokrongly, did you changed the filter? I'm driving an '05 ZX SE with an automatic and the Justask.com Ford Mechanic is telling me the A solenoid most probably is ther reason I appear to be not making it to fourth (O/D OFF cancell switch not working either). My transmission code from the door sticker says "2" (i.e. automatic) can anyone tell me what transmiision it really is. VIN code indicates the car was built in Hermosillo Mexico.
stphnlfr is offline
Old 10-26-2008, 10:35 AM   #12
whynotthinkwhynot
Captain TMI
whynotthinkwhynot's Avatar
Fan#: 18416
Points 27,776, Level 98
Points: 27,776, Level: 98 Points: 27,776, Level: 98 Points: 27,776, Level: 98
Level Up 43% Completed
Forum Activity 4%
This Dude--- did you use Mercon V? I'm not sure if Mercon III would cause your problem, but since you developed the problem after a change I have to ask
Be eclectic.
You're special aren't you.
whynotthinkwhynot is offline
Old 10-27-2008, 03:17 AM   #13
runfocusrun
runfocusrun's Avatar
Fan#: 43029
What I Drive: 2002 Infra-red ZX5
FF Reputation: 8 runfocusrun Good Standing Member
My ATX slips from 3rd to 4th and back around 60 mph and keeps doing this until I go faster, then it shifts in 4th and stays there. Now after reading this very informative thread I guess it wouldn't hurt to change all the solenoids at once while you're at it.
Plse give me your opinions on this since I have to eventually go this route & appreciate all of your knowledge. Thnxs in advance.
BTW my tranny devolved this issue after a transmision flush at 100K K's.
ZETEC CREW # 121
Current: Volant intake, RS headlight kit, motor/interior parts painted
Upcoming: 2'5 Header, flex & exhaust, Saleen/Eibach susp. & swaybars, small turbo to get some more oumph
runfocusrun is offline
Old 10-27-2008, 04:43 AM   #14
thisdude_05
Thou shall fear me!
thisdude_05's Avatar
Fan#: 50808
What I Drive: 2009 Scion tC
FF Reputation: 27 thisdude_05 Great Standing Member
Buy-Sell-Trade Rating: (17)
No it was Mercon V.
thisdude_05 is offline
Old 10-28-2008, 11:25 AM   #15
tablovel
Fan#: 60180
What I Drive: 2008 misty silver ford focus
FF Reputation: 1 tablovel Good Standing Member
2008 Ford Focus Transmission problem
I have only 5000 miles on my new Ford Focus. It has had problems shifting at about 40 mph. The engine will rev high when the car has sat for a period of time, first thing in the morning and again after work and has set all day. It only does this when the car is "cold". I have had the car in the shop with this problem three times. The first time they had me drive with a computer attached for one week and everytime the car had this concern I pushed a button on a joystick and it recorded what was happening with the car. They then downloaded the readings and found that it was sticking between 3rd and 4th gears. They replace the valve box. This did not correct the problem, but added more transmission problems. Now it was not shifting smoothly into any gear. I took the car back and they found that a spring was correctly placed in position when they replaced the valve box. They reseated that spring and now the car shifts smoothly, except when it is "cold" or set for a period of time. The orginal problem has not been fixed. It still revs high when trying to shift from 3rd to 4th gear (abt 40 mph) everytime when the vehicle has set for a period of time. I am frustrated. This is the first time in my life that I bought a new car, so I would not have car problems. The dealership keeps telling me that it is normal and that it will do this when the car is cold, that nothing is wrong with the car. But they did replace the valve box and the problem still exists. I have trouble believing that it is normal for a car to rev high before shifting. The 2008 Ford Focus they put me into drive while they were "fixing" my car did not perform that way and never that this problem. I just want the car fixed! I invested in a new car and expect the car to ran properly!
tablovel is offline
Old 10-28-2008, 11:32 AM   #16
tablovel
Fan#: 60180
tablovel is offline
Old 10-28-2008, 10:57 PM   #17
FociBoi121
FociBoi121's Avatar
Fan#: 53573
What I Drive: 2003 InfraRed ZX3 ATX
FF Reputation: 4 FociBoi121 Good Standing Member
well change the solenoid that shifts 3rd-4th which is solenoid A
Current Mods: about me profile
ZETEC Crew #237
HATCHBACK LOVER #121
PS3 ID: LarkBoi189
Slow bolt ons added or bolt ons slowly added?
FociBoi121 is offline
Old 10-31-2008, 09:37 PM   #18
Razzy
Fan#: 60255
What I Drive: 2008 Ford Focus SES
FF Reputation: 1 Razzy Good Standing Member
Tablovel, when you said rev high, did you mean transmission flaring? Sorta like slipping?
Razzy is offline
Old 11-01-2008, 02:24 AM   #19
Rich_Rahl
Fan#: 60261
What I Drive: 2002 Ford Focus SE
FF Reputation: 1 Rich_Rahl Good Standing Member
I have a 2002 SE 4door with an atx ..........my ? is would this solenoid cause the issue if your trans seems to shift to 4th fine but when shifting into O/D there is no gear ....seems to shift but just nothing after, engine revs, no forward motion .........if i hit o/d off button it down shifts into 4th and i start going again ......i have a CEL cant remember exactly but i think it was one about mechanical failure like p0671 ill run up to autozone again to check tomorrow
EDIT: went to Autozone its Code PO750 first one on the list so........i will be buying a new solenoid and fixing prolly this comming weekend .......whew think i dodged a $900 bullet here thanks
Rich_Rahl is offline
Old 11-01-2008, 07:25 PM   #20
keash75
Fan#: 60271
What I Drive: 2003 silver se
FF Reputation: 1 keash75 Good Standing Member
hi there i have 03 focus se 2.0L sohc about 85000 kms it has had a tranny problem from going about 20 km\h if i accelerate it has problems shifting it will keep reving but not shift only when i let off the gas and accelerate again it will then shift but it dosent happen all the time but it happens quite a bit the tranny light isnt on i took it the ford dealership were i bought it and they say they cant find nothing wrong i even took the mechanic out for a drive it did it and he said it was nothig it was still under warenty at the time. We got into an argument and so on but thats another story is this a commun thing for these help me pls thax
keash75 is offline
Similar Threads
Zero to 60 & 1/4 Miles Times (List of all cars) OrangeSVTguy Drag Racing 36 07-09-2013 10:48 PM
Ford debuts Focus Coupe-Cabriolet Kneel Ford Focus & General Car Chat 50 10-02-2011 08:04 PM
Big plans for tiny Focus remusrm Ford Focus & General Car Chat 50 08-19-2009 02:51 PM
The Ford Focus Parts List! gthang MK2 Focus 13 01-27-2009 12:05 AM
Even this fOCUS!!!! Jeezzzz!!!! TORQUERULES Ford Focus & General Car Chat 22 02-11-2007 11:47 PM
