HELP! Driver side door wont open - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 07-19-2008, 12:03 PM   #1
simonfleming
Fan#: 57818
What I Drive: 2001, gold Ford Focus
FF Reputation: 1 simonfleming Good Standing Member
The driver's side door will not open on my 2001 focus. The inside handle is ajar and will not go back into place and the outside handle only pulls part way. Locking and unlocking does nothing. I cant get to the torx screws to open up the panel. I think I'm screwed. Any suggestions?
simonfleming is offline
Old 07-19-2008, 12:24 PM   #2
Ft_Knox_Focus
Ft_Knox_Focus's Avatar
Fan#: 54188
What I Drive: 2009 Sterling Gray SE(RIP 01 SPI)
FF Reputation: 1 Ft_Knox_Focus Good Standing Member
As Far As The Torx Screws, Until I Got My Full Set I Used Channel Locking Pliers And Locked Onto The Screw! A Lot Of Work But Hey, You Gotta Fix Your Baby!
It isn't fast, but it sure is sexy!
Ft_Knox_Focus is offline
Old 07-19-2008, 02:57 PM   #3
whynotthinkwhynot
Captain TMI
whynotthinkwhynot's Avatar
Fan#: 18416
Points 27,933, Level 98
Level Up 59% Completed
Forum Activity 10%
That's a difficult nightmare to encounter. Sadly Ford didn't design the door panels to be removed with the door closed. You can remove the panels around the door handle- remove what you can and perhaps you can see something that is blocking the action of the handle and allow it to release- or you can release the cable manually. I doubt that this will help, but it's worth trying.
I believe the latch is locked up, and the door panel will have to be destroyed to gain access to repair the problem.
Be eclectic.
You're special aren't you.
whynotthinkwhynot is offline
Old 07-19-2008, 03:03 PM   #4
whynotthinkwhynot
Captain TMI
Fan#: 18416
Forum Activity 10%
OH, you can try removing the outer window trim. First roll down the window, then you should be able to access any screws holding the trim. If you don't see any screws then it should just clip or push on. It will be difficult to loosen it, but eventually you can remove it. Then you can roll the window up, and you might be able to spray some penetrating oil in the direction of the door latch and possibly free it without removing interior door panels.
Be eclectic.
Old 07-19-2008, 04:06 PM   #5
bluefront
bluefront's Avatar
Fan#: 56816
What I Drive: 2006 white ZX5 SES
FF Reputation: 146 bluefront Excellent Standing Member bluefront Excellent Standing Member
Buy-Sell-Trade Rating: (6)
Those door panels can be expensive....find out how much. Then call around some local lock-smiths.....they may be able to hook you up with somebody who knows how to trip the lock with a "slim-gym" or something without hurting the door or trim. Dealers usually know people who can do this. Might be worth having it done...
bluefront is offline
Old 07-21-2008, 01:27 AM   #6
emsvitil
Fan#: 50210
What I Drive: 2000 SE Wagon
Points 3,109, Level 34
Points: 3,109, Level: 34 Points: 3,109, Level: 34 Points: 3,109, Level: 34
Level Up 40% Completed
Forum Activity 2%
FF Reputation: 9 emsvitil Good Standing Member
Most likely the door latch mechanism has failed.
Try locking/unlocking with the remote and you may get lucky........
Once you get lucky, R&R the latch mechanism.
Ed
emsvitil is online now
Old 08-24-2012, 08:38 PM   #7
rwunfocus
Fan#: 102794
What I Drive: 2001 Silver Zetec wagon
FF Reputation: 1 rwunfocus Good Standing Member
Change out the inner door assembly (Driver side), problem solved. See pic why and ford part#.
rwunfocus is offline
Old 01-02-2013, 01:12 PM   #8
Dianes05FocusJunk
Fan#: 60871
What I Drive: 2005 Focus SE ZXW Silver
FF Reputation: 1 Dianes05FocusJunk Good Standing Member
Door Handle Inner Assembly Problem 2007 Focus
Lots of problems with this breaking... obviously a long-time problem forced upon the consumer to repair/replace.. thanks Ford
Dianes05FocusJunk is offline
Similar Threads
How-To: Focus MTX-75 Duratec clutch, Phantom Grip, and Poly mount install sporadic DURATEC Performance (2003-2007) 95 11-24-2014 11:15 PM
Power door lock problems - Driver side is fine, passenger side stopped working =( gaery85 Car Audio, SYNC, MyFord Touch & Electronics 3 03-25-2008 03:59 PM
BMW M3 Convertible Tom Ford Focus & General Car Chat 11 03-23-2008 01:09 PM
My door wont open!! BOOSTA MK1 Focus 0 01-06-2008 02:31 PM
WantToBuy: 01`SE Driver Side "door skins" or doors themselves (both) zaiD Archive 0 09-12-2005 01:55 PM
