Key fobs/Flip Key - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Go Back   Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum > Ford Focus Discussions > Ford Focus & General Car Chat
Old 07-19-2008, 06:40 AM   #1
imaz
Fan#: 48912
What I Drive: 2006, Metalic Silver, LX LS Sedan
FF Reputation: 1 imaz Good Standing Member
Key fobs/Flip Key
Hi,
I drive a focus 2006 Mk2 european model with a key fob which has 3 buttons on it. I'm after a flip key which I intend to get cut. I'm assuming the remote buttons on the flip key will work just like my original key fob buttons once programmed.
Anyone know what the PATS chip look like and is it removable from the original key fob to the new flip key which I'm going to buy?..
Heres what I've tested with my original key fob. I've removed the key blade from the remote buttons half of key fob and tried to start the car. IT DOESNT START! Once I put the key fob half near the key ignition, I can then start the car as normal. i'm assuming the PATS chip is somewhere on the key fob. Can the PATS chip device be remade? or replicated? Or is all PATS chip the same for every FORD key fob????????
i hope not to go to the dealer as they will charge over $200 for a flip key and programmed.
Thanks
imaz is offline
Old 07-19-2008, 12:51 PM   #2
DrkKnight614
GO Green
DrkKnight614's Avatar
Fan#: 14522
Points 26,111, Level 96
Points: 26,111, Level: 96 Points: 26,111, Level: 96 Points: 26,111, Level: 96
Level Up 77% Completed
FF Reputation: 47 DrkKnight614 Great Standing Member
Um, idk seems like alot of work just for a cool flip key. Honestly be happy with what you have, over here we still have a seperate key and remote
My 2003 Ford Focus ZX3 - Finally realized it's a 4cyl
DrkKnight614 is offline
Old 07-19-2008, 01:26 PM   #3
TnFocus
Dumbledore dies?!?!
TnFocus's Avatar
Fan#: 49496
What I Drive: 05 zx4, 88 rx7 with v8 swap, 69 bug
FF Reputation: 8 TnFocus Good Standing Member
Umm, tape the PATS part under the dash? lol
TnFocus is offline
Old 07-21-2008, 10:20 AM   #4
imaz
Fan#: 48912
Found the info! Provided you have two original keys, you can add new keys and have the new pats chip coded as per below:
If you only have 1 known key to the vehicle this has to be done by a Ford dealer using IDS. if you have 2 known keys then you can do it yourself, buy putting the first key in the ignition and turning from off to on and back to off and remove the key, do the same for the second known key, and then again for the non prog 3rd key,(no more then 10 secs betwween removing the keys) leave for a few seconds then all 3 keys will start. You then need to prog the central locking by putting the fobbed key in and turning from off to on 4 times and you will hear a chime, remove the key and press anyone of the buttons on the fob and it will chime again. re-insert the keys and turn off to on and this is all done.
imaz is offline
Similar Threads
How To: Drilling Out Ignition Cylinder Due To Key Won't Turn (Ford Focus ignition lock cylinder) microtonal General Technical Chat 73 01-23-2011 11:39 AM
Need Ford Recall, TSB, or your vehicle history? Click Here! DJ Lukdogg General Technical Chat 368 10-13-2008 06:04 PM
Pop-out car key (Volkswagen type) for focus edu2688 MK1 Interior Mods & Upgrades 24 06-27-2008 07:11 PM
Key Lock Issue jbondjr General Technical Chat 8 06-01-2007 07:22 PM
DTC Codes (Detailed Descriptions) S2 General Technical Chat 13 12-11-2006 12:06 PM
