real racing/beaverun - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Go Back   Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum > Ford Focus Racing Discussions > Autocross Racing
Autocross Racing The place to discuss information about autocross stats, tips and events. Track sanctioned events only.
Old 06-14-2004, 10:49 AM   #1
garyk
Guest
Fan#: 171
What I Drive: focus race car, stock svt street ca
FF Reputation: 1 garyk Good Standing Member
well squirt finally did it. after fridays tsunami conditions for practice (open track for SEVEN! hours) and only running 1:22's with dying fuel pump, it did not look promising. sat. dawned clear and cool. enduro went off at 3:30, pitted at 4:38 with corded tire while in 3rd. went out on fresh rubber and car died on back straight and coasted for 1/2 mile. figured that was it until it caught again. amazingly we out lasted almost everyone else and despite losing the power steering at the end took a second.
garyk is offline
Old 06-14-2004, 11:39 AM   #2
Egz
Sückn' n Blown
Egz's Avatar
Fan#: 442
What I Drive: 2003 2.3l ZX3
FF Reputation: 111 Egz Excellent Standing Member Egz Excellent Standing Member
Some like it wet:
Some like it hot:
January 2008 Focus Fanatics ROTM
2003 Ford Focus ZX3 2.3l N/A = 221 HP, 162 ft-lbs, 13.967@100.88MPH
2006 Ford Fusion 2.3l Turbo = 244HP, 247ft-lbs
duratec.wikispaces.com - Duratec Wiki - Sign up and contribute!
Egz is offline
Old 06-14-2004, 01:45 PM   #3
WD40
The Librarian
WD40's Avatar
Fan#: 5157
Nice job, Gary.
Did you find the culprit that caused the engine to die?
And, what happened to the power steering?
WD40 is offline
Old 06-14-2004, 01:59 PM   #4
garyk
Guest
Fan#: 171
dying engine
we think there were 3 separate things going on. 1st fuel pump was dying causing sputter on uphills. fuel mileage (!) went way up with new pump we found sat a.m. at dealer about 22 miles away. however still cut out every time i caught the rumble strip in turn 6 leading us to think there is also a short somewhere. and to top that off, we may have water in the tank from refueling in torrential rain friday, that may have gotten into fuel cans. will no more after this weekend at vir. and power steering pump has leak on high pressure side. its not really meant to run hours on end at 5 to 7 thousand rpm! back to fuel pump-i was using a 1/4 tank for every 1/2 hour prctice friday in the rain when i was only running around 1:22 laps and keeping speed to no more than 100 on the straights due to aquaplaning issues on lousy tires. in saturdays race, was running a best of 1:12 and seeing 110-115 at times. used only 1/2 a tank for the race that ran over an hour. so though replacing it did not cure all problems, at least i was back to my usual 10 mpg at race speed.
garyk is offline
Old 06-14-2004, 03:33 PM   #5
WD40
The Librarian
WD40's Avatar
Fan#: 5157
So, the leak is at the pump itself?
Just asking, as during my first oil change I found THIS on my rack and pinion.
Holy Cow! Maybe I better just stick to short ~2:00min AutoCross races.
Too bad about the fuel pump, though it does sound like electrical, not mechanical problem.
Personally, I hate trying to track down electrical gremlins.
Good luck!
WD40 is offline
Old 06-14-2004, 03:58 PM   #6
garyk
Guest
Fan#: 171
well
i also hate electrical gremlins. have a feeling that its a loose ground somewhere. keep in mind, my battery is in the back, making things interesting with lots of extra wire. on the p/s-the eastern director of svtoa came out for the race. had same problem w/his. he replaced the line and still had leak. turns out ford, in its infinite wisdom, doesn't send the teflon outer seal with the line thats needed for repair. talked to one of our techs this a.m. and he said the seals go frequently on them. hopefully seal will be here tomorrow and we'll see if that fixes it. we are going to modify the pump to slow it down (basically take out the spring and cut 25% off) and run aeroquip lines soon. oops, sorry-no leak is in line or seal, not pump.
garyk is offline
Old 06-14-2004, 08:09 PM   #7
Egz
Sückn' n Blown
Egz's Avatar
Fan#: 442
http://members.cox.net/jeggert4/garyk.avi
1.5Mb
Encoded with DivX 5.11
Used my cheap little digi cam, so not the best quality. I tried to clean it up.
Egz is offline
Old 06-15-2004, 03:03 PM   #8
viney266
viney266's Avatar
Fan#: 93
What I Drive: focus ztw ,zx3,mustang, motorcycles
Points 235,208, Level 100
Points: 235,208, Level: 100 Points: 235,208, Level: 100 Points: 235,208, Level: 100
Level Up 0% Completed
Forum Activity 5%
FF Reputation: 112 viney266 Excellent Standing Member viney266 Excellent Standing Member
Buy-Sell-Trade Rating: (4)
I haven't been to beaverrun yet, looks like a wide track....lots of quardrail ( body shiver). Those small little cars like the rain ?!
Speed is only a matter of money; how fast do you want to go?
viney266 is offline
Old 06-15-2004, 03:12 PM   #9
WD40
The Librarian
WD40's Avatar
Fan#: 5157
Egz:
Does that clip have video?
I'm only getting the audio.
Sounds cool, but it would be nice to see.
WD40 is offline
Old 06-15-2004, 03:21 PM   #10
garyk
Guest
Fan#: 171
well
bill, that little car loves the rain. that track is so new that adhesion is amazing. i put a self imposed limit of 95 on the back kinks and 100 on the front straight friday. above that i tended to aquaplane. i would have loved rain for the race. helps me with the higher power rwd cars. actually, adhesion was too good in the dry-ruined 3 v700 kuhmo race tires. down to the cord. and wd40-all i can get is the audio also. i would be more fustrated if i did not have an in car vid of the whole race. still would like to see it from the outside.
garyk is offline
Similar Threads
SCT X3 for real time data? Chupathingy009 Focus Tuning Chat 4 01-18-2009 09:56 PM
real recaros? schrader SVT Performance (2002-2004) 6 12-19-2003 03:06 PM
