Horror Stories of the Rear Drum/Bearing - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 07-13-2008, 09:57 PM   #1
KJsZX5
KJsZX5's Avatar
Fan#: 52563
What I Drive: 2003 Dark Shadow Gray ZX5
FF Reputation: 1 KJsZX5 Good Standing Member
Exclamation Horror Stories of the Rear Drum/Bearing
So I have to replace the rear wheel bearing on my FoFo and started reading everyone's responses as to how horrible taking things apart back there are. Is it really that bad?!
I have the "hum" in the bearings so I bought these at Auto Zone... http://www.autozone.com/R,APP982368/...ductDetail.htm (Its the hub with the bearing already pressed in.)
Will I also need to have this pressed onto the drum or should this come with the drum??
Was also considering replacing the rear brakes but it seems like those are a pain as well.
Just nervous I will get things apart and then can't get them back together again with the car sitting in my friend's drive way! I haven't done any work in this area of the car before and was trying to save some money by doing it myself. Local shops were wanting $340+ to fix with one shop telling me they would need the car for the whole day and it would run me $450 to fix the "hum" alone!
Any help or suggestions would be greatly appreciated.
Project Autobot - Jazz II
KJsZX5 is offline
Old 07-13-2008, 11:37 PM   #2
Geezer
Fan#: 1427
What I Drive: 99 miata, 05Mazda6, 09GTI, 12Imprez
FF Reputation: 141 Geezer Excellent Standing Member Geezer Excellent Standing Member
The bearing is what is pressed into the brake drum. You'll have to have the old one pressed out and a new one pressed in. While the autozone description didn't provide much in the way of info, I'm guessing its a new bearing and a new spindle....but as I said, that's just a guess. I doubt you will need a new spindle unless you had bearing problems. Brake drums are sold with and without bearings installed.
Geezer is offline
Old 07-14-2008, 12:01 AM   #3
MaroonZX3
Fan#: 49579
What I Drive: 2003 Red ZX3
FF Reputation: 12 MaroonZX3 Great Standing Member
When dealing with drum brakes, do one side at a time. That way you have a reference of how it goes together.
MaroonZX3 is offline
Old 07-14-2008, 01:38 AM   #4
Fordfreak3368
Fan#: 3515
What I Drive: 2010 Ford Fusion Sport
FF Reputation: 1 Fordfreak3368 Good Standing Member
My bearing was a total mess. My right rear starting howling but i didnt have the money to do it. When i finally did do it the darn thing pretty much fell right off, with the inner race seized to the spindle and the outer race seized in the drum. I had to take my spindle of and put an air chisel to get the bearing off of it, and I smashed by ABS ring and the only hub napa had was non abs, so now my abs light is on until I get another ring. When you get the new one just make sure you ask if its the whole hub with bearing and all. and you don't have to take the brakes apart to do the bearing.
Proud owner of a now totaled 2004 Ford Focus 2.3l
Team Focus Cleveland #4 is now up for grabs
Fordfreak3368 is offline
Old 07-14-2008, 02:09 AM   #5
thisdude_05
Thou shall fear me!
thisdude_05's Avatar
Fan#: 50808
What I Drive: 2009 Scion tC
FF Reputation: 27 thisdude_05 Great Standing Member
Buy-Sell-Trade Rating: (17)
The link you have in your OP is for the bearing only. I know cuz I had to buy it. But it's cheaper at Checkers if you have one around. I think I paid like $40. And just take the drum to anyone with a press and they'll do it for you. But don't forget to put the ABS ring back on or your ABS light will be on. I paid $40 for the bearing and $25 to have the old one pressed out and the new one pressed in.
thisdude_05 is offline
Old 07-14-2008, 08:08 AM   #6
KJsZX5
KJsZX5's Avatar
Fan#: 52563
Thanks for the info guys!
KJsZX5 is offline
Old 07-22-2011, 11:05 AM   #7
FrogSpot
Fan#: 87997
What I Drive: 2002 Gold SE
FF Reputation: 1 FrogSpot Good Standing Member
It's not bad
I'm no mechanic but I just replaced the drum with the bearing preinstalled. My biggest problem was that the auto parts stores kept selling me the wrong parts. I finally took the old one into Autozone and the guy matched the item. The uninstall was easy. I just rented an electric impact wrench with a 30mm deep socket for $8 from the hardware store. And borrowed a torque wrench from the auto parts store ($80 deposit which I got back when returned). The drum slipped off with a little prying (make sure the e-brake is not on) then the new one just slips back on the same way and tightens down. Torque to 233 LB.
The problem is that no one mentioned that I also need an ABS ring on the new drum. apparently no auto parts store can get that so FORD is going to charge me over $50 for that little ring. They don't have it in stock yes so I'll have to wait to get that put on. I don't know why Autozone sold me the drum without the ABS ring when the ABS ring is required!!
FrogSpot is offline
Old 07-22-2011, 11:27 AM   #8
wrc_fan
slow
wrc_fan's Avatar
Fan#: 11913
What I Drive: 03 ZX3 Duratec 08 WRX Hatch
Points 3,584, Level 37
Points: 3,584, Level: 37 Points: 3,584, Level: 37 Points: 3,584, Level: 37
Level Up 56% Completed
FF Reputation: 23 wrc_fan Great Standing Member
You can remove the ring from the old drum and reinstall on the new. It takes some creative prying, but its doable.
Parking Lot Hero
2008 WRX daily driver
2003 ZX3 23D Autox Car 42 FSP
"Hella Functional - Raced, Not Hard Parked"
wrc_fan is offline
Old 07-22-2011, 12:55 PM   #9
Geezer
Fan#: 1427
A lot of early (maybe most?) foci did not come standard with ABS. My 03 ZX3 did not have ABS. IF you told them the car had ABS then yes, they should have provided you with the right parts. Did you check Tousley Ford for their ring price?
Geezer is offline
Old 09-14-2011, 04:56 PM   #10
2003zx5
Fan#: 84545
What I Drive: White 2012 SEL sedan
Points 291, Level 5
Points: 291, Level: 5 Points: 291, Level: 5 Points: 291, Level: 5
Level Up 82% Completed
FF Reputation: 1 2003zx5 Good Standing Member
I just did my rear drum brakes last night. Not too bad. At least not as bad as what I have been reading. It all started yesterday morning going to work I heard a grinding noise. I wanted to pull the drum off at work and check the shoes but I could not get the drum off. So last night I rented a hub puller - what they use to remove the front hubs on front wheel drive vehicles. Pulled the tire, used 2 of the lug bolts to install the hub puller and the drum still needed to be pryed off. Once I got the drum off I saw the problem. The shoes were delaminted and the lining was in two pieces. The drum had a gouge around the outside edge which prevented me from just pulling the drums off. All the hardware was rusted and the adjuster was frozen. I got it all freed up, put it back together and moved onto the other side which was a whole lot easier.
I purchased new drums w/bearings, shoes and hardware.
The one thing I did notice is that the new drums did not come with the oil seal sleeve - this was on the backside and is a ring that slides over the rubber seal on the spindle. You have to make sure that you pop the old sleeve out and install it into the new drum or water and brake dust will get into the bearings.
2003zx5 is offline
Similar Threads
Rs Replica Help rs-steve Ford Focus & General Car Chat 4 09-15-2007 09:06 PM
[:)][:)][:)][:)][:)][:)]ing Rattles! Rear hatch, driver rear panels... Lumadar Ford Focus & General Car Chat 2 12-30-2006 05:00 PM
Rear suspension . How to....get you in trouble...... mpcv2000 Brakes, Suspension & Body Chassis 32 10-03-2006 08:50 PM
Not able to align rear....HELP romano2 General Technical Chat 9 07-23-2005 11:49 PM
OEM Rear Spoiler nelson25 MK1 Focus 11 04-16-2005 07:43 PM
