Cruise control not working - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 07-06-2008, 05:42 PM   #1
sathyan
Fan#: 54480
What I Drive: 2007 White SE
FF Reputation: 1 sathyan Good Standing Member
Car: 2007 Ford Focus SE
I bought a used Focus (no warranty) which has the buttons for cruise control. I did not test cruise control during my test drive so don't know if it ever worked. Everything else works fine.
When I turn on the cruise control I get no response - the speedcontrol light on the dash does not illuminate. If I press "set/acc" and take my foot off the gas, the car does not hold its speed.
I've checked the following:
-checked fuse #53 inside and #29 under hood - appear to be in good condition
-third brake light works
Is there anything else to check? Or do myself (with no specialized tools)?
How much could it cost to have the cruise control fixed?
thanks,
Sathyan
sathyan is offline
Old 07-06-2008, 08:35 PM   #2
penguin
Fan#: 21700
What I Drive: 2005 Infrared ZXW
FF Reputation: 109 penguin Excellent Standing Member penguin Excellent Standing Member
There is a switch that disengages the cruise control when you press the brake. If it is defective or loose, the cruise will not work. Are your brake lights working?
It also is possible the cable a the throttle body for the cruise control is broken of has come loose.
penguin is offline
Old 07-06-2008, 08:46 PM   #3
ShamrockSVT
ShamrockSVT's Avatar
Fan#: 47719
What I Drive: 2011 Ford Fiesta SE
FF Reputation: 72 ShamrockSVT Excellent Standing Member
another possibilty is the clock spring, which is located under the airbag in your steering wheel.
ShamrockSVT: Doing my part
ShamrockSVT is offline
Old 07-14-2010, 01:42 PM   #4
briancotten
Fan#: 76713
What I Drive: 2006 Charcoal Gray ZX4
FF Reputation: 1 briancotten Good Standing Member
Sathyan,
I'm not familiar with which models are automatic transmission and which are not. My ZX4 is and the cruise seemed to stop working sometimes and start working other times. Either way, you can try this at no cost and it resolved my isssue. When the clutch is pushed in to shift, that also turns off the cruise control. I put my foot under the clutch pedal and lifted the clutch petal up, after which allows the crusie control to work. Basically, when I push the clutch in, it disengages the cruise, then when I let off the clutch, it doesn't always come back up high enough to allow the cruise to work again. Lifting the clutch reengages the switch and allows the cruise to work once more. Maybe this simple fix will help you as well. If this is the case for you as well, maybe you can have the dealer adjust the clutch pedal so it comes higher up after pressing, or try taking a spring or bunjee cord and hooking it up in a way that pulls the clutch higher up when released.
briancotten is offline
Similar Threads
Help me Tell Ford they are WRONG scalderon General Technical Chat 41 07-21-2008 05:01 PM
Installing Stock Cruise Control on zx3 ldruth MK1 Interior Mods & Upgrades 6 09-29-2007 08:34 PM
Installing Stock Cruise Control on 2007 zx3 ldruth General Technical Chat 1 07-10-2007 12:10 PM
cruise control issues....??????? doc gates General Technical Chat 3 07-01-2007 07:40 AM
Cruise Control Died whiterose General Technical Chat 1 07-01-2006 06:24 AM
