2005 Focus Fuel Pump - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 07-03-2008, 10:14 PM   #1
Ezpimpin
Ezpimpin's Avatar
Fan#: 38882
What I Drive: 2005 Black ZX3
FF Reputation: 6 Ezpimpin Good Standing Member
It appears that my fuel pump is starting to go. I'm currently a little past 70,000 on the ticker and my fuel pump loses pressure every time my car sits for a little while. My question is is there a way to fix the fuel pump so it doesn't leak and lose pressure? and if there isn't does the fuel pump that says 04' work on an 05'
Firemen never die, they just burn forever in the hearts of the people whose lives they saved.
Ezpimpin is offline
Old 07-03-2008, 11:17 PM   #2
Grumpy
Fan#: 43791
What I Drive: 2005 Sonic Blue ZX3
FF Reputation: 28 Grumpy Great Standing Member
What makes you think that you are losing system pressure quicker than "normal"? This has been verified with a pressure gauge or are you just assuming it because of "long" cranking times/hard starting? Does it occur all the time.......engine cold, or engine still hot/warm? If the engine has no other operating issues then it isn't strickly the pump. It could be the check valve, but have you checked for external fuel leaks such as from the fuel filter connections? Has any part of the fuel system been disturbed recently? Are you sure that it isn't just some fuel vapor issue with a heat soaked, just shut down engine? Any leak between the check valve and the injectors (including a "dripping" injector) will increase the rate of pressure drop after shutdown. The check valve I'm pretty sure is part of the pump assembly but I would first check the rest of the system first.
Grumpy is offline
Old 07-04-2008, 12:48 AM   #3
Ezpimpin
Ezpimpin's Avatar
Fan#: 38882
noted i'll check that as soon as I get a chance, thanks
Ezpimpin is offline
Old 07-04-2008, 08:32 AM   #4
whynotthinkwhynot
Captain TMI
whynotthinkwhynot's Avatar
Fan#: 18416
Points 27,933, Level 98
Level Up 59% Completed
Forum Activity 10%
^^ You're mostly correct Grumpy, however Ford's new fuel injection system has no check valve or fuel pressure valve if that's what you're referring to. The new system uses what's called a fuel sensor which senses fuel temperature and pressure. Voltage is variable at the pump according to the sensor's information. This solves the problem of fuel return line losses.
You're right that it could be a number of things besides the pump, however, in Ford's new design it's not as simple as hooking up a fuel pressure tester to verify that the pump is putting out proper pressure. There is a procedure listed in Ford's manuals, but you'd basically need to replace the fuel line with another line that has a mechanical gauge in the line.
If I were in your position, the first thing I'd check is the fuel sensor. It's located in the center of the fuel rail above the intake manifold. You'll notice a small rubber line coming from the center of the sensor- this provides vacuum to the sensor for whatever purpose that serves. Remove that line, and sniff. If you smell fuel, then the fuel sensor is definitely bad. Next, check the fuel line as much as you can physically- I doubt you have a break in the line because that would cause the car not to run at all, but it's worth checking. Also, when is the last time you changed your fuel filter? Fuel filters only last for 25k miles or so- actually a bit longer depending on the quality of fuel you use, but the service interval is 25k miles. Most people don't think about the fuel filter until the pump goes out at around 100k. If you decide to change it yourself, press on the white flat spot on the fuel filter clip to remove the lines- do not try to remove the clip from the line or you could break it.
There are several other things that could be causing your problem besides the fuel system, but since you drive the car and think that the fuel system is the problem- we'll go with that assumption first. If you could more plainly describe exactly what it's doing without assumptions, then we can use our knowledge to determine other possibilities.
Other basic preventive maintenance things to try-
1) clean the MAF with spray MAF cleaner, or carefully with alcohol and a Q-tip.
2) test air filter if it's stock, or clean aftermarket air filter.
3) check spark plug gap and clean plugs. I don't recommend replacing plugs at this stage in repair, simply scrape the crud off the areas where the spark bridges the gap, and make sure that the gap is correct. If any plugs are damaged- then you should replace, of course. Replace the plugs later if you feel you need to.
Be eclectic.
You're special aren't you.
whynotthinkwhynot is offline
Old 07-04-2008, 12:44 PM   #5
Grumpy
Fan#: 43791
I believe that he's talking about his system not "holding pressure" for any length of time after engine shutdown........not the actual operating pressure with the engine running.
Grumpy is offline
Old 07-06-2008, 07:22 PM   #6
Ezpimpin
Ezpimpin's Avatar
Fan#: 38882
yes exactly Grumpy, the system only looses pressure once the engine is shutdown I've drove my car for several hours with no problems but once the engine is shutdown for more than 15 min. the fuel system seems to loose pressure and if I go to start the motor again, it needs to turn over like 4 or 5 times before fireing
Ezpimpin is offline
Old 07-06-2008, 09:05 PM   #7
Grumpy
Fan#: 43791
You could just end up unnecessarily chasing your tail on this. If your car has no visible fuel leaks, no real "gassy" smell eminating from anywhere including from under the hood, and no performance issues, then I don't really think you've got anything to worry about........mine does the same thing, particularly with the hotter weather and I believe others on this forum have commented on this same issue. I can live with 3 or 4 extra "cranks". Other cars that I've owned previously have suffered from the same thing in varying degrees. If you haven't done so already, try letting the pump build up pressure, before cranking it over.
Grumpy is offline
Old 07-06-2008, 10:15 PM   #8
penguin
Fan#: 21700
What I Drive: 2005 Infrared ZXW
FF Reputation: 109 penguin Excellent Standing Member penguin Excellent Standing Member
I thought the fuel pump assembly had one built-in to hold pressure after shut-down, to make starting quicker.
penguin is offline
Old 07-06-2008, 10:48 PM   #9
Grumpy
Fan#: 43791
This system doesn't have/require the fuel pressure regulator/return line, but going by the pressure behind the fuel that I got "spritzed" with on the fuel filter change, I'd say that there is (and it just makes sense) a check valve at the pump discharge. I'm basically lazy, and I have never done it yet on any car for simply replacing the fuel filter, but isn't there a procedure still for the Focus for "depleting" the fuel pressure by pulling the fuel pump relay and starting the engine?
Grumpy is offline
Old 07-07-2008, 12:39 AM   #10
Ezpimpin
Ezpimpin's Avatar
Fan#: 38882
yeah I just replaced the fuel filter about 5,000 miles ago. In order to kick the engine over in "decent" conditions I have to turn the key to the "on" position wait about 5 - 10 sec. and then fire the engine. Even when I wait n everything though the engine still takes a couple seconds to turn over. Also, the weather conditions have nothing to do with it, I live in Michigan (new weather every day,) n this has persisted in 30 degree weather and 90 degree weather and everything in between.
Ezpimpin is offline
Similar Threads
How To: Return Fuel System Turbo Turtle General Forced Induction 61 Yesterday 04:25 AM
Engine Light zummracer General Technical Chat 18 12-10-2013 10:08 PM
Help! 2000 Focus - no fuel - need wiring diagram thebigreddog! General Technical Chat 7 09-21-2013 10:19 AM
Focus stalls - fuel pump dead - what gives? Mikey West General Technical Chat 9 04-23-2008 08:16 PM
TRUE gas mileage cruzstyle Ford Focus & General Car Chat 17 06-09-2006 01:14 AM
