Thermostat housing - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Go Back   Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum > Regional Forums > South West Fanatics > Fanatics: AZ, NV, NM
Fanatics: AZ, NV, NM Regional discussion Forum for planning events and sharing information with all Members in the Desert areas.
Old 07-01-2008, 03:17 PM   #1
SVT1208
SVT1208's Avatar
Fan#: 53736
What I Drive: '03 Comp Orange SVT
FF Reputation: 1 SVT1208 Good Standing Member
Angry Thermostat housing
What should I do I just took my car in and they said that the thermostat housing was cracked.....It would be like $418 or something like that. does that sound right? what should I do??
Please leave in AZ group.
SVT1208 is offline
Old 07-01-2008, 03:26 PM   #2
nov173
nov173's Avatar
Fan#: 29840
What I Drive: 2014 Focus ST
FF Reputation: 79 nov173 Excellent Standing Member
Buy-Sell-Trade Rating: (4)
pm b161991sir on here... he will get you one for a GOOD deal. he works at a dealer in the parts dept. This is something you can def do yourself and save the $$$ and feel better about it cuz you know you did it. There are how to's on this too. Do a quick search on the subject and you will find a lot of info on it.
SVT header kit, 2.25 MBRP cat-back & flex, r/t high flow cat. aem cai, frpp kit
For Sale: Rear bumper(stock). SVT side skirts FS as well. Buy em!!!!
nov173 is offline
Old 07-01-2008, 03:31 PM   #3
PumkinSvt
PumkinSvt's Avatar
Fan#: 46561
What I Drive: 10 Forte DD,Comp SVTF, 14 Fiesta ST
Points 16,375, Level 82
Points: 16,375, Level: 82 Points: 16,375, Level: 82 Points: 16,375, Level: 82
Level Up 5% Completed
FF Reputation: 28 PumkinSvt Great Standing Member
Buy-Sell-Trade Rating: (33)
I would just buy the part and do it myself! its so simple! and when you finish it you would feel good knowing you did it yourself!
HKS||Garrett||TopSpeed||Tial||Massive||
PumkinSvt is offline
Old 07-01-2008, 06:03 PM   #4
ShamrockSVT
ShamrockSVT's Avatar
Fan#: 47719
What I Drive: 2011 Ford Fiesta SE
FF Reputation: 72 ShamrockSVT Excellent Standing Member
I had mine changed at Earnhart ford in chandler for like 150 bucks.
Not sure why you want to stay local, you will get more responces in the technical forums.
ShamrockSVT: Doing my part
ShamrockSVT is offline
Old 07-01-2008, 07:53 PM   #5
SVT1208
SVT1208's Avatar
Fan#: 53736
ok its ok to move....
Ya i just found out that the powertrain warranty is transferable so i got that transfered but it will take about a couple of days to a couple of weeks....
SVT1208 is offline
Old 07-02-2008, 03:04 AM   #6
FF Founder
Tom's Avatar
Fan#: 2
What I Drive: 2005 Saleen ZX3 SES Turbo
Points 85,999, Level 100
Points: 85,999, Level: 100 Points: 85,999, Level: 100 Points: 85,999, Level: 100
Level Up 0% Completed
FF Reputation: 60 Tom Excellent Standing Member
Buy-Sell-Trade Rating: (7)
$418 is a ripoff. Shouldnt take no more than an hour.
Its really easy to replace that part. If you can coast it down to the valley I'll do it for you.
Tom is offline
Old 07-23-2008, 10:30 PM   #7
Zona Kona
Zona Kona's Avatar
Fan#: 8907
What I Drive: 2000 Dirt Brown Kona
FF Reputation: 1 Zona Kona Good Standing Member
Are you fixed?
Zona Kona is offline
Old 07-24-2008, 04:33 AM   #8
SVT1208
SVT1208's Avatar
Fan#: 53736
Ya it is. It seems like it might be leaking again.... I dont know what to do about it anymore.
SVT1208 is offline
Old 09-15-2008, 04:38 PM   #9
teamksr
Fan#: 45264
What I Drive: 2002 Liquid Grey Metalic ZX3
FF Reputation: 1 teamksr Good Standing Member
Talking Plz Read!!!!!
Do not pay for them new housings. If it is internally cracked around the o ring I have a solution for you all! I was personally tired of it so I found a cheap self fix that anyone with a few tools can take care of in about 30 minutes or less depending on your mechanical know how and experience.
What you need?
Go down to your local Advanced Auto or AutoZone or what ever your local parts store is and buy a $4 roll of rubber cork for making gaskets. Make sure it is the kind for sealing water or oil. Very inportant!
What to do?
Remove battery and battery box. Like 3 to 4 bolts total. At least on my foci.
Disconnect the 4 hoses on the thermostat housing. Remove the 3 bolts connecting the housing to the cyclinder head.
Now cut a piece or the rubber cork into a square and tuck the one side under the metal flap ( see picture )
(at bottom of pic is the metal flap. the cork should slide right in which will hold it in place durring instal)
Now carefully cut an hole in the middle where the water will flow through. Does not need to be exact size of the opeinging. leave a little overlapping. then shove the bolts through the bolt holes backwards so that you have punctured them and made a opeing to get them back through when you reinstall.
Now just reinstall the housing and torc it to about 4lbs / 4 and a half pounds somewhere in there should do it. dont want to crack the external housing. reconnect all your hoses and put battery box and battery back in and you should be good to go... PS dont forget to replenish your coolant since much has been lost in this process, also good idea to have a catch pan under your car for all the spillage you will lose.
my car has been running fine. only scare was my thermostat was stuck close for about 30 minutes but finally started working again. being that im in florida i might just remove it completely but not right now. Save yourself the money and try this out. been holding up for me very well. anyquestions just email me at david_kneece@falconmail.daytonastate.edu I will be happy to answer
teamksr is offline
Old 09-15-2008, 05:36 PM   #10
ShamrockSVT
Fan#: 47719
teamksr, thanks for posting that, very helpful.
Similar Threads
Thermostat housing leak 02_zxFIVE General Technical Chat 53 01-21-2013 09:02 PM
Where to buy Thermostat Housing and Thermostat? Squareleft General Technical Chat 7 05-16-2008 10:25 AM
Thermostat Housing Wagamos General Technical Chat 8 11-25-2006 03:14 PM
:: Cracked Thermostat Housing Assembly :: ..:: sleestak ::.. General Technical Chat 8 08-11-2006 09:35 AM
Cracked thermostat housing?? biederboat General Technical Chat 3 10-07-2004 01:37 PM
