How-To Retro-Fit Stock Headlights W/Projectors - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Closed Thread
Old 06-29-2008, 07:43 AM   #1
Sn4ckM4st3r
Fan#: 24432
What I Drive: 2002 Stealth ZX3
FF Reputation: 91 Sn4ckM4st3r Excellent Standing Member
Buy-Sell-Trade Rating: (4)
This will be updated weekly i would say with new types of headlights fro different cars i will be doing. As well as pics added when the cam makes it back.
Retro-Fitting Stock Headlights w/Projectors-
Tools-
10 Torx
Flat Head Screwdriver
Dremel w/cutting head
Mask
Saftey glasses
Materials-
Stock Headlights
Projectors(E55's, Acura TSX or TL, Audi RS6)
JB Weld
Sheet Metal (optional fitting)
Clear Silicone Sealer.
Optional Materials-
1000 Grit Sandpaper
Primer
Paint your choice of color if you want to paint the headlights.
Washers to prefrom optional Projector modification (more color on the Cut-off)
Headlight Restore kit (if your lenses are crapped)
Projector Shroud
Taking headlights apart-
Preheat your oven to 250 degrees.
Load one headlight into the oven on a cookie sheet or something similar for 10-15 minutes.
Remove at about 10 mins to check glue seal if not all the way stick back in to loosen completely.
One glue seems to just pull apart, use flat head screw driver to pry parts if needed.
Clean glue you will be replacing and using new sealer later.
Preparing for you Projector of Choice-
*This part will depend HUGELY on which projector you will want and what style headlight you will be after.*
OEM Fitting- !*Make sure to wear a mask and saftey glasses while cutting this stuff makes alot of dust and is not fun to get hit by.*
Once the headlight is apart first remove the Screw behind the housing holding in the Bulb Shield.
depending on your projector choice you will need to measure you prjector and then use the dremel to cut a spot from the stock reflector to fit it.
After you have cut this opening clean off the area and then test fit to make sure it will go into the hosuing.
Using a small piece of sheet metal cut into a square place it on the back of housing over the hole. Find a suitable mounting spot and then secure it to the housing with a few screws and some jb weld.
Once again test fit your projector inside of your mounting plate as well your hosuing to assure its level and is secure.
*OPTIONAL*
While apart use the shroud you have chosen to measure and then cut to be placed inside around the projector.
JBweld it all and let sit for approx 6 hours.
Preparing the OEM Fit for a test run-
At this point your Jbweld should have fully cured
After your JBweld has had time to cure take both lens and housing and line with silicone.
Put them back together assuring that each and every space is filled to prevent water or condensation build up.
Let your silicone sit for a couple hours and come back.
Take both Headlights and prepare to reinstall in car to check projector clearence.
Find a set of bulbs or HID's if thats what you will be using and prepare them for a run.
Wait till dark and find a flat surface thats about 15-20 ft from you.
Put the HID's in and adjust headligthts to get a crisp flat cutoff.
*OPTIONAL WASHER MOD*
If you want a little more Blue out of your cutoff and are willing to sacrifice Cutoff sharpness. YOu will need 1-3 #8 washers for the acura projectors. Installing these to lengthen the shield distance will give you a bit more blue.
*Optional Painting*
While the headlights are apart if you would like to paint your headlights to match the vehicle this is the time.
Use the 1000 grit to rough up the chrome pieces really easy to do.
Hit with a few coats of evenly sprayed paint of your choice.
Use a clear as well to prevent and kind of cracking or anything.
Wait to cure and dry reinstall.
Aftermarket Look-
Following the taking apart of the headlights you will need to remove the rear reflector piece.
To do this both plastic peices jsut pop off.
The off white with force can be taken out via the back.
Seal the hole off with silicone or a similar sealing agent.
Once the rear reflector and shield are out remove any spare pieces with the dremel making sure to wear your saftey objects.
Depending on how you want it to look use bondo or fiberglassing to fill in the area to give amore full look to the head light.
Paint your front piece a color of your choice or remove from the headlight.
After you have chosen your style put back together. and continue with the test.
I do have pictures but my camera is in New Hampshire so i will have what i don't have here for everyone. And be sure to watch this as it will be updated frequently with more methods and things
I am looking to try and install some sort of niteshaded parking lamp inside. And may be testing a ST170 Retro fit soon.
Test fit-
Example Cutoff-
Tons more pictures for each segemnt to come.
Also a KEY NOTE!!! I suggest anyone who tries to take this on also look into an eyebrow setup. It will make your car look MUCH better and more agressive here is my test eyebrow.
Projector-
Sn4ckM4st3r is offline
    Quick reply to this message
Old 06-29-2008, 12:55 PM   #2
Sn4ckM4st3r
Fan#: 24432
Anyone interested in something like this? Or am i crazy lol.
Old 06-29-2008, 12:57 PM   #3
dameon81
dameon81's Avatar
Fan#: 24572
What I Drive: 2001 Twilight Blue ZX3 5 Speed
FF Reputation: 1 dameon81 Good Standing Member
Very Interested!
Wishes she wasn't Stock "Money Speaks Louder Than My Dreams"
My ZX3 Is my Problem Child & We have a love/hate relationship. Currently we're back to "Like".
Zetec Crew #263
dameon81 is offline
Old 06-29-2008, 12:58 PM   #4
Sn4ckM4st3r
Fan#: 24432
^^ Ok i thought someone would be. I will have mroe pics like is said. As well as other style headlights for everyone to see.
Old 06-29-2008, 01:04 PM   #5
dameon81
dameon81's Avatar
Fan#: 24572
Awesome. I want to do some sort of projectors, and i read a post (that i think you actually posted) saying that most aftermarket projectors suck for HID conversions. Definetly interested in seeing a detailed write up!
Zetec Crew #263
dameon81 is offline
Old 06-29-2008, 01:09 PM   #6
Sn4ckM4st3r
Fan#: 24432
^^ That was me i try and help out those with HID's that i can. But yes be looking for many more updates to be popping up as well as a write up on retro fit fogs.
Old 06-30-2008, 04:52 PM   #7
dameon81
dameon81's Avatar
Fan#: 24572
Definitely wanna see the Retrofit Fogs! Would definitely want to do that! Would it also theoretically be possible to say, retrofit a pair of like the angel eye projectors with a proper HID projector in similar fashion?
Zetec Crew #263
dameon81 is offline
Old 06-30-2008, 11:03 PM   #8
Deaner
Deaner's Avatar
Fan#: 39531
What I Drive: 2002 ATX Twilight Blue ZX5
FF Reputation: 31 Deaner Great Standing Member
Buy-Sell-Trade Rating: (8)
very very nice write up. im thinking about getting a new set of ST170s to do this too. my current ST170s has a crack in the plastic since the hood slammed on it(was not fitted right) and the lights are used so the clear plastic was some scratches. but im thinking about getting the S2000 projectors
just think, projectors in these lights, but the city light is in the low beam, so i should move it to the high beam lol
alot more pics would be extremely helpful
¸_____
/_|_|__\__
l(o)____(o)l
<--EüRöFöCüS: 02 Twi Blu ZX5 FoFo Euroness SOLD!!!
New toy: TOYota FJ Cruiser 4x4
Deaner is offline
Old 06-30-2008, 11:13 PM   #9
Sn4ckM4st3r
Fan#: 24432
If you wanted to retrofit angel eyes you could run CCFL halos which i will be doing on a set of HL soon so i will update as needed.
And deadly yes those i want to do with some Acura or mercedes ones. I would tint that orange marker too. Might be installing a custom tinted marker to kinda mock alike the ST170's
Thanks though guys like i said always a work in progress and will always be updated hopefully makes its way to the archive.
Also fogs won't be too bad will be picking up some 3000k's soon as well as some mini HELLA fogs for them
Old 07-01-2008, 12:17 AM   #10
brandnew161
brandnew161's Avatar
Fan#: 46064
What I Drive: 95' Eagle Talon TSi AWD
FF Reputation: 4 brandnew161 Good Standing Member
i did this a few months back. Its a really fun project to work on. Maybe i skipped it, but what projectors did you use for the retrofit? Acuras? They have a real clear/sharp cutoff. Very nice work.
ZC#172
brandnew161 is offline
Closed Thread
Similar Threads
03 Stock headlights and Grill. NOT SVT HEADLIGHTS *CLOSED* jlemond Archive 6 02-09-2007 03:17 AM
Stock '02 headlights -not SVT $50 for the pair J-Dawg Archive 22 03-31-2006 10:24 AM
Changing Stock Headlights for Halo? Jojos ZTS Focus MK1 Focus 1 03-10-2006 10:12 AM
will stock 16's fit svt hatchd03 Wheels & Tires 5 07-22-2004 02:05 PM
Wings West Front Air Dam, 2000 Focus stock bumper, 2000 Focus stock suspension sale! meanpiolin Archive 0 07-10-2004 03:51 PM
