Rear suspension noise over bumps. - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 06-11-2004, 02:16 PM   #1
binspoonal
Fan#: 8788
What I Drive: 2000 zx3 Kona Edition
FF Reputation: 1 binspoonal Good Standing Member
Angry Rear suspension noise over bumps.
When going over small bumps i hear a knocking sound in the rear drivers side suspension area. After reading some of the threads in here someone pointed out that it may be the rubber grommet on the top of the rear shock. Do you think this is what it may be or have any other ideas of what it could be. If it is the grommet, anyone know where to get a new one to replace it with if that can be done?
Thanks in advance!!
binspoonal is offline
Old 06-11-2004, 04:29 PM   #2
Lil PZEV
Lil PZEV's Avatar
Fan#: 242
What I Drive: 2003 TwiBlue 2.3 ZX3
FF Reputation: 15 Lil PZEV Great Standing Member
Buy-Sell-Trade Rating: (14)
bin, have you seen the thread "rattle from hatch area" in the Focus Technical Chat section? There are a lot of possible answers in that one, I'd try the easiest ones first and if they dont work go to the more labor-intensive ideas... I'm assuming your car is out of warranty since it's an '00.
If you need to replace the grommet then I'd say your best bet is the Ford parts counter, it can't be more than a couple bucks at most, and they're probably kept in stock.
Lil PZEV is offline
Old 06-11-2004, 04:32 PM   #3
binspoonal
Fan#: 8788
Ok I'll check it out, thanks. Yeah it's out of warrenty 30k ago.... Other than that it's solid.
Old 11-16-2012, 01:18 AM   #4
ldwinslow
Fan#: 105829
What I Drive: 2006 dk. red zxw
FF Reputation: 1 ldwinslow Good Standing Member
I had a similar problem after replacing the rear shocks. After talking with a tech rep. from Gabriel I had not torqued the shock bolts properly. I retorqued the bolts per the tech's spec of 85 ft/lbs on the upper and 76 on the lower and the clunking noise went away when driving over bumps.
ldwinslow is offline
Old 11-16-2012, 11:38 AM   #5
Geezer
Fan#: 1427
What I Drive: 99 miata, 05Mazda6, 09GTI, 12Imprez
FF Reputation: 141 Geezer Excellent Standing Member Geezer Excellent Standing Member
The upper shock mounts on the rear end are different between wagons and sedans/hatchbacks. Torque settings are different as well. The upper shock mount on the inside of the car on hatches and sedans is problematic. The top washer has to be properly positioned and properly torqued within the rubber mount. These mounts by their design can weaken and cause some thumping noises. Some people have had success using delrin or polyurethane spacers to fill the air gap between the washer and mount. Also check the side panel that has to be removed to get at the top mount. The clips can be incorrectly inserted or damaged when the panel is reinstalled. This allows the panel to thump as well.
Geezer is offline
Old 11-16-2012, 01:13 PM   #6
wrc_fan
slow
wrc_fan's Avatar
Fan#: 11913
What I Drive: 03 ZX3 Duratec 08 WRX Hatch
Points 3,584, Level 37
Points: 3,584, Level: 37 Points: 3,584, Level: 37 Points: 3,584, Level: 37
Level Up 56% Completed
FF Reputation: 23 wrc_fan Great Standing Member
zombie thread!!!!!!
Parking Lot Hero
2008 WRX daily driver
2003 ZX3 23D Autox Car 42 FSP
"Hella Functional - Raced, Not Hard Parked"
wrc_fan is offline
Similar Threads
How To - Extensive Suspension Overhaul (Front and Rear) SuperFlea Brakes, Suspension & Body Chassis 74 01-28-2015 11:20 AM
**Vote for Focusfanatics.com Ride of the Year 2008** Chick Ford Focus - Ride of the Month 85 07-31-2008 08:11 PM
spring noise from front suspension after coil change siffleu General Technical Chat 9 05-12-2008 08:37 PM
**Vote for FF.com ROTY** Chick Ford Focus - Ride of the Month 113 07-31-2007 12:04 PM
Noise from Rear Suspension (i'm new) Ryan07se General Technical Chat 5 07-23-2007 06:56 PM
