2001 Ford Focus squeal or chirp noise - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 06-26-2008, 03:20 PM   #1
dawnrshng
Fan#: 57205
What I Drive: 2001 Ford Focus SE
FF Reputation: 1 dawnrshng Good Standing Member
I've been trying to hunt down a solution to my problem for about a month now and have had 0 luck. My car is making this squealing or chirping noise when accelerating and goes away (not completely) when the car is warmed up. The noise sounds like a million crickets under my hood. The mechanic changed the belt, all the pullys and the alternator and is out of ideas. Does anyone know of anything else? Oh and I thought it might be the Cam Synchronizer but my car is a SOHC so it does not have one. Is there any other possibilities?
FYI - I know nothing about cars.
Thanks! :)
dawnrshng is offline
Old 06-26-2008, 03:51 PM   #2
nov173
nov173's Avatar
Fan#: 29840
What I Drive: 2014 Focus ST
FF Reputation: 79 nov173 Excellent Standing Member
Buy-Sell-Trade Rating: (4)
alternator pulley it sounds like...
SVT header kit, 2.25 MBRP cat-back & flex, r/t high flow cat. aem cai, frpp kit
For Sale: Rear bumper(stock). SVT side skirts FS as well. Buy em!!!!
nov173 is offline
Old 06-26-2008, 04:35 PM   #3
DJslurp1200
DJslurp1200's Avatar
Fan#: 45538
What I Drive: 02' Mustang GT Premium Convertible
FF Reputation: 13 DJslurp1200 Great Standing Member
My car makes that noise too... like if I'm pulling from a light at a stop...
I wondered what it was too...
DJslurp1200 is offline
Old 06-26-2008, 05:07 PM   #4
JASONN23
JASONN23's Avatar
Fan#: 48640
What I Drive: 2005 black zx4 ST
FF Reputation: 1 JASONN23 Good Standing Member
i dont know how it could but maybe the belt is slipping? maybe a bad belt tenisioner?
K&N CAI, custom 2.25" flex back with magnaflow muffler, Focussport SCT II ECU Flasher
MORE TO COME!! Team DURATEC #132
Why is it all for the zetec/hatchbacks?????
JASONN23 is offline
Old 06-26-2008, 05:38 PM   #5
dawnrshng
Fan#: 57205
Is the alternator pulley replaced with the alternator? He didnt replace the idler pully, come to find out. Could it be the idler pulley doing this?
I do apologize for my lack of knowledge with cars.
Old 06-26-2008, 07:14 PM   #6
penguin
Fan#: 21700
What I Drive: 2005 Infrared ZXW
FF Reputation: 109 penguin Excellent Standing Member penguin Excellent Standing Member
I would not think the pulley would cause the squeal... if it was due to the alternator it would most likely be a bad alternator bearing, which is internal to the alternator itself.
That's actually the most likely cause, after a bad belt. I would have though the mechanic would have checked that, after trying a simply belt replacement.
Well, not just the "pulley," but the idler assembly.
Most likely the spring in the assembly is weak and it is not providing enough tension.
If there is not enough tension, the belt slips a little when it is loaded, as in accelerating, and the small bit of slippage causes the squeal.
P.S. I've had bad alternator bearings in the past on other vehicles and, in my case at least, they were noisy at idle and stopped making noise when they were loaded under acceleration -- the opposite of your experience.
penguin is offline
Old 06-28-2008, 09:05 PM   #7
sailor
Elder
sailor's Avatar
Fan#: 57268
Points 13,351, Level 75
Points: 13,351, Level: 75 Points: 13,351, Level: 75 Points: 13,351, Level: 75
Level Up 26% Completed
Forum Activity 99%
nod to penguin - good post!
my own P.S. Slipping belts grab better when they warm up, so the noise goes away...
sailor is offline
Old 06-29-2008, 04:45 AM   #8
HawkeyeFLA
Fan#: 6078
What I Drive: 2002 Ford Focus ZX3 Pitch Black
FF Reputation: 5 HawkeyeFLA Good Standing Member
Typically not. The pulley is taken off with a pulley puller and put onto the new alternator. But I would not think the pulley would cause the squeal... if it was due to the alternator it would most likely be a bad alternator bearing, which is internal to the alternator itself.
Hmmm, is that specific to the Focus alternator? Every alternator I've replaced in the past has been an everything in one deal. Making it a very simple replacement all in all.
HawkeyeFLA is offline
Old 06-29-2008, 10:10 AM   #9
penguin
Fan#: 21700
Your are correct and my original post is in error. Somehow I was thinking of the power steering pump at the time -- apparently a brain fart on my part.
I have corrected the original post to avoid misleading people.
penguin is offline
Old 06-29-2008, 09:13 PM   #10
Blurvfocus
Blurvfocus's Avatar
Fan#: 15299
What I Drive: 03 ZX3 Wine Cooled Eng.
FF Reputation: 54 Blurvfocus Excellent Standing Member
Easiest thing to do is to squirt a little water on each pully in turn with the engine running. If the noise changes that's it. If nothing there, pop the belt off and spin each pully by hand, if you still can't find anything, run the car for a few seconds with the belt off. If the noise is still there, it's under the cover- timimg belt or water pump.
I have seen pullys wear out and refuse to grip a belt properly. And with an older focus maybe in arid, dusty Texas, might be something to think about...
Often wrong but never in doubt.
Blurvfocus is offline
Similar Threads
Big plans for tiny Focus remusrm Ford Focus & General Car Chat 50 08-19-2009 02:51 PM
The Ford Focus Parts List! gthang MK2 Focus 13 01-27-2009 12:05 AM
Need Ford Recall, TSB, or your vehicle history? Click Here! DJ Lukdogg General Technical Chat 368 10-13-2008 06:04 PM
2008 Ford Focus US-Spec part 1 mitchlguzin Ford Focus & General Car Chat 9 01-08-2007 06:57 PM
Interesting Read on Ford Platforms on Wikipedia igor Ford Focus & General Car Chat 2 02-28-2006 03:45 AM
