Old 06-22-2008, 07:25 AM   #1
leeflea
Fan#: 57070
What I Drive: 99 focus 2.0 ghia 5 door hatch
FF Reputation: 1 leeflea Good Standing Member
Rear door lock fault
Hi I have a strange door lock problem so I hope I can explain it ok!
If you get out of the rear driver's side door and then lock the car that door will not lock. But if whilst inside you manually push the lock tab on the door in so it is locked, then get out the other side and lock the car it is then ok. It is still ok if you unlock it and open/close the door from the outside and will lock ok if only the outside handle is used but as soon as you open it from the inside the door wont lock unless you go back through the said process??????? Any suggestions greatly appreciated.
leeflea is offline
Fan#: 1
Similar Threads
HOW TO: Reinforce your Rear Lower Control Arms. honhon Wheels, Tires, Brakes & Suspension - Sponsored By Tire Rack 43 08-30-2012 01:36 AM
Rs Replica Help rs-steve Ford Focus & General Car Chat 4 09-15-2007 08:06 PM
Rear suspension . How to....get you in trouble...... mpcv2000 Wheels, Tires, Brakes & Suspension - Sponsored By Tire Rack 32 10-03-2006 07:50 PM
New Volkswagen Rabbit!! nomoreavril Ford Focus & General Car Chat 30 06-29-2006 11:55 AM
Not able to align rear....HELP romano2 General Technical Chat 9 07-23-2005 10:49 PM
