Fan...blown relay...sensor...overheating - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 06-20-2008, 02:25 PM   #1
hugging corners
Fan#: 56747
What I Drive: bl
FF Reputation: 1 hugging corners Good Standing Member
the car was overheating for some time. today i have decided to pull thermostat out and have discovered this. relay has burned connectors. should i shortcut it to have fans running full power, or is it not recommended?.. what are the next steps. I am working on the car this moment at job parking lot, in order to make back home. I have also discovered that upon turning ac on not always fans kick in high speed...(i think low is working). i was considering radiator temp fan on/off sensor, but looking at this discovery that might not be an issue. please advice. thank you BArtos
hugging corners is offline
Old 06-21-2008, 01:44 AM   #2
ChuckDee
Ehh...
ChuckDee's Avatar
Fan#: 43589
What I Drive: 02 SC SVT
Points 17,687, Level 84
Points: 17,687, Level: 84 Points: 17,687, Level: 84 Points: 17,687, Level: 84
Level Up 68% Completed
FF Reputation: 48 ChuckDee Great Standing Member
Buy-Sell-Trade Rating: (6)
im having the same exact problem as well too. hopefully someone could answer this....
unique(adj): to break off from the crowd and do your own thing
ChuckDee is offline
Old 06-21-2008, 09:45 AM   #3
theindustrialist
Fan#: 56955
What I Drive: 2003 Black 5Door SVT
FF Reputation: 2 theindustrialist Good Standing Member
I'm experiencing similar troubles. My low speed resistor doesn't look nearly as bad as yours though...
Here's the part #s for the resistor & plug. Hope it helps.
Low Speed Fan Resistor
F5RZ-8L603-AC
Wire pigtail for Fan Resistor
4U2Z-14S411-DA
theindustrialist is offline
Old 06-21-2008, 11:38 AM   #4
killer ZETEC
GL1TCH
killer ZETEC's Avatar
Fan#: 44757
What I Drive: advance trac french blue 03 zx3
FF Reputation: 42 killer ZETEC Great Standing Member
guys guys guys. thats a 40 dollar part. just go to ford and replace it. its called the fan assembly resistor pack. its a common trouble part that only lasts a few years.
i didnt need a pig tail. but mine went out after i turned my f0f0 into an amphibious assault vehicle. i still need to replace my horn though
focus owner whos runnin with the hatchet
zc187 focus nation and fvscc's car 343
still getting part and things for this turbo.
will it run soon?? who knows.
killer ZETEC is offline
Old 06-22-2008, 12:30 AM   #5
ChuckDee
Ehh...
ChuckDee's Avatar
Fan#: 43589
^^^haha, no horn sucks.
ChuckDee is offline
Old 07-27-2008, 06:17 PM   #6
jocus
jocus's Avatar
Fan#: 10824
What I Drive: 2k2 pitch-black SVT
Points 1,331, Level 20
Points: 1,331, Level: 20 Points: 1,331, Level: 20 Points: 1,331, Level: 20
Level Up 31% Completed
Level up: 31% Level up: 31% Level up: 31%
FF Reputation: 1 jocus Good Standing Member
Just took a drive up to northern wi from chicago with a lot of traffic jammed.. I had the same issue about four years ago, and I'm pretty sure it was the thermostat that went bad, not ever turning the fans on. Driving;fine.. idling;hot, stop-and-go with mostly stop;extra hot. Gotta get in there and investigate.
jocus is offline
Old 10-28-2008, 10:36 PM   #7
hugging corners
Fan#: 56747
What I Drive: bl
bump. prob. solved
and Screen..
-dont you be calling me a !!@# focus rooke!!
________________________________________ http://www.cardomain.com/ride/3020526
Similar Threads
coolant fan relay BMARTIN03ZX3 General Technical Chat 1 07-06-2007 12:11 AM
DTC Codes (Detailed Descriptions) S2 General Technical Chat 13 12-11-2006 12:06 PM
fan switch or blower relay needin help General Technical Chat 4 08-09-2004 01:07 AM
For Sale: Flex-a-lite 12-in Electric Fan With Controls - 1250 CFM mr.squatch Archive 6 04-01-2004 06:44 PM
