Dead Battery caused by alternator? - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 06-14-2008, 04:10 PM   #1
fireboy2
Fan#: 56864
What I Drive: 2001 tddi ghia
FF Reputation: 1 fireboy2 Good Standing Member
Hi there all, I tried to start my car after leaving it for a day but the battery was totally dead. I thought it was just time for a new battery but when I fitted a shiny new one it was flat the morning after. I have done some checks with my multimeter and found the following. When running the battery charges up to about 14.4v as it should but when not running the battery voltage slowly drops. It drops a few millivolts every couple of minutes. If you disconnect the large positive cable that runs to the alternator it doesnt drop at all. The cable has a resistance of about 30k ohms to earth. Any ideas. Oh Ps the alternator was changed in December and it's a 2001 tddi ghia. Any help would be really appriciated ta.
fireboy2 is offline
Old 06-14-2008, 05:11 PM   #2
ShamrockSVT
ShamrockSVT's Avatar
Fan#: 47719
What I Drive: 2011 Ford Fiesta SE
FF Reputation: 72 ShamrockSVT Excellent Standing Member
Sounds like you may have a draw somewhere in the system, but its not the Alt, which simply can't consume electricity
ShamrockSVT: Doing my part
ShamrockSVT is offline
Old 06-14-2008, 09:20 PM   #3
oddballish
Fan#: 51285
What I Drive: 2006,Blue,fx4
FF Reputation: 1 oddballish Good Standing Member
Shamrock it is possible to have an Alt short internally and bleed back though it is extremely uncommon. The quickest way to check is to loosen the out-put nut on the stud and in a dark shop (I know where the Alt is located its dark already) wiggle the wire and look for a spark, no spark no bleed back
oddballish is offline
Old 06-14-2008, 09:46 PM   #4
fireboy2
Fan#: 56864
I have already disconnected the cable from the output stud on the alternator and the fault disappers so it does look like the alternator is comsuming electricity but I need to know how the alternator is wired up inside before I can diagnose the fault anymore. Does anyone have a wiring diagram or can anyone explain it to me?
fireboy2 is offline
Old 06-14-2008, 09:53 PM   #5
Blurvfocus
Blurvfocus's Avatar
Fan#: 15299
What I Drive: 03 ZX3 Wine Cooled Eng.
FF Reputation: 54 Blurvfocus Excellent Standing Member
Yeah, if it's a big draw, it probably is the alternator.
Disconnect the fat red wire at the alternator, There should be no sparking at that post whatsoever. Then let this thing sit overnight and see if the battery stays up.
Shamrock- the alternator has diodes in it that allow current to pass in one direction (out). There's three of them in there, but if one goes bad, it'll allow current to flow in either direction. When that happens, the alternator will still function, but when the car isn't running, it'll just sit there and draw current through it's coils.
Often wrong but never in doubt.
Blurvfocus is offline
Old 06-14-2008, 09:54 PM   #6
oddballish
Fan#: 51285
Get an old test light, not an LED, clip to the out put stud and touch the wire you disconnected .If the light comes on you have a short,
Old 06-14-2008, 10:01 PM   #7
Blurvfocus
Blurvfocus's Avatar
Fan#: 15299
Do you want to fix the alternator yourself? I'm not sure about this alternator specifically, but the diodes are usually pressed into a plate. You can replace them if you have a vise and a couple of sockets, or they might be sold as a diode trio assembly, already pressed into a plate.
Don't worry about "how it's wired up inside". When you get apart you'll see that it pretty much goes back together only one way. If in doubt, and if you have a digital camera, take lots of pictures as you take it apart.
Old 06-14-2008, 10:41 PM   #8
fireboy2
Fan#: 56864
Blurvfocus, I think you hit the nail on the head with a blown diode within the alternator. I'll try taking the alt off tomorrow and see if I can find the offending item. Cheers for the assistance everyone.
fireboy2 is offline
Old 06-18-2008, 02:48 PM   #9
fireboy2
Fan#: 56864
just to let you know I changed the alternator yesterday and everything is now fine. I even managed to get the alternatorfor free as it was still under a 12 month warranty from last time it was changed for not charging the battery. Cheers for all the help again guys.
fireboy2 is offline
Similar Threads
Battery or alternator? focusmmuter General Technical Chat 5 05-26-2007 02:55 PM
Dead Alternator, Dead Battery Atlanta800 Car Audio, SYNC, MyFord Touch & Electronics 19 07-02-2006 05:13 AM
Dead Alternator, which to get and where to get it? Portuga General Technical Chat 3 01-20-2006 06:04 AM
alternator to battery cable? pio Ford Focus & General Car Chat 0 11-25-2003 11:10 AM
