Sun Hyper Ground Kit Installed - Page 6 - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Go Back   Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum > Ford Focus Second Generation > DURATEC Performance (2008-2011)
DURATEC Performance (2008-2011) The place to chat about any Duratec 20 engine performance, tuning and exhaust related upgrades.
Old 06-20-2008, 01:17 PM   #51
threadlock
threadlock's Avatar
Fan#: 55215
What I Drive: 2007 red
FF Reputation: 1 threadlock Good Standing Member
This may be a bad question, but, is it possible to post the insturctions for the routing of the ground locations so I can make my own??
threadlock is offline
Old 06-20-2008, 01:25 PM   #52
kimbo305
kimbo305's Avatar
Fan#: 52390
What I Drive: '00 Zetec ZX3
FF Reputation: 12 kimbo305 Great Standing Member
Originally Posted by BradWhite View Post
"relax", yeah sorry if any of those responses seemed rushed or not so friendly. Certainly was not my intent, I was at home and trying to respond before I had to get ready for work and I was still 15 minutes late doing that.
I should have waited until I had more time, like now when I'm at work and should be doing something else.
Oh no no, I meant you're being way more polite and communicative than is expected for an internet forum. So you're definitely in the clear. "Relax" more in the sense that don't worry, you're not offending anyone, because you're not at all.
check out my Fiesta Movement entry: youtube.com/watch?v=dXY3mi1NWeg&eurl=http://www.focusfanatics.com
I wholeheartedly endorse McNew's for installing and tuning your Focus.
kimbo305 is offline
Old 06-20-2008, 01:37 PM   #53
whitefox
whitefox's Avatar
Fan#: 54401
What I Drive: 2008 Ebony CC 2dr coupe SES 5spd
Points 1,961, Level 26
Points: 1,961, Level: 26 Points: 1,961, Level: 26 Points: 1,961, Level: 26
Level Up 61% Completed
Level up: 61% Level up: 61% Level up: 61%
FF Reputation: 35 whitefox Great Standing Member
Sorry for the delay on getting back on this, Brad, but I had to clear some cobwebs out of a few brain cells for this part of it.
An in circuit test for resistance can give you some numbers and show some difference, but may or may not be true readings. The measurement you need to find is the current between the two points across the different cables. This will give you the best true measurement. The best way to check this is by using Ohms law. Next is a summarization of what you need to measure.
The principle mathematical relationship governing the flow of electric current in a circuit was discovered by Ohm in 1827. Ohm's law states that the amount of current (i) in a circuit is directly related to the potential difference (V) and inversely related to the resistance (r) in the circuit. In other words, i = V/r. What Ohm's law says is that an increase in potential difference or a decrease in resistance produces an increase in current flow. Conversely, a decrease in potential difference or an increase in resistance produces a decrease in current flow.
To get these measurements; V is the measurement in volts across the cable and r is the resistance of the cable by itself. r divided into V will give you the current (i) across the cable. Usually, you would need a meter that will measure down to 1/1000th of a volt to get your best reading. Measurements of 1/100th of a volt will give you a fair reading and 1/10th of a volt might not show any change.
I know this is getting a little technical and probably more technical than anybody here wants to get, but since there are a lot of skeptics out there, they want to know proof that this works and probably some kind of an explanation.
So, basically you need to measure the current across both cable types to determine which is the better path to positive voltage (yes, current runs from negative to positive or from more negative to less negative).
Carl - whitefox -
Team Duratec # 164
Mid-Atlantic Team EXTREME
2008 Focus Ebony Clearcoat 2dr SES 5spd
whitefox is offline
Old 06-20-2008, 04:06 PM   #54
richdeerht
Fan#: 55194
What I Drive: 2013 Silver SE Sedan
Points 132, Level 2
Points: 132, Level: 2 Points: 132, Level: 2 Points: 132, Level: 2
Level Up 64% Completed
FF Reputation: 1 richdeerht Good Standing Member
I added the throttle body ground to my 2008 SE and detect a very slight response improvement. But in the first 2 days, my mileage went up .2 MPG.
I have wire and terminals left over- what do you think I should add a ground to next?
richdeerht is offline
Old 06-20-2008, 04:30 PM   #55
BradWhite
Head Hurt
BradWhite's Avatar
Fan#: 54975
What I Drive: 08 Sedan SE Vista Blue
FF Reputation: 174 BradWhite Excellent Standing Member BradWhite Excellent Standing Member
Getting interesting now, just home for lunch so no time to digest this yet (still working on digesting lunch). But I know I have some great reading for after work.
richderrht - start with the stock grounds to the chassis and lower engine block. There are more locations, but I'm not comfortable recommending them until I get a better handle on all of this myself.
Best wishes and keep on modding April 2009 SOTM, July 2009 ROTM, 2009 FF ROTY
RIFF CREW, Sedan Revolution #137, TEAM Duratec #181, Bremerton Raceway #658, NW POSSE #6
BradWhite is offline
Old 06-20-2008, 10:58 PM   #56
iminhell
C2H5OH
iminhell's Avatar
Fan#: 36222
Points 18,648, Level 86
Points: 18,648, Level: 86 Points: 18,648, Level: 86 Points: 18,648, Level: 86
Level Up 60% Completed
Forum Activity 19%
Buy-Sell-Trade Rating: (4)
I was already typing my "central block" response before I saw those pics. That looks like a great kit. For 8 bucks, no s$%t, where? I tried googling "dream team motorsports" but just came up with a bunch of forums.
Ebay,
http://cgi.ebay.com/ebaymotors/UNIVE...spagenameZWDVW
I've seen those central blocks elsewhere, but i just can't place where. Was some car audio company maybe, Stinger or Lightning Audio or something. I checked but didn't see them. It will come to me sooner or later.
OH, you're not playing dumb ...
iminhell is offline
Old 06-20-2008, 11:58 PM   #57
NemesisEnforcer
Force-Powered Focus
NemesisEnforcer's Avatar
Fan#: 48598
What I Drive: LIQUID GRAY 2005 ST
Points 18,461, Level 86
Points: 18,461, Level: 86 Points: 18,461, Level: 86 Points: 18,461, Level: 86
Level Up 23% Completed
FF Reputation: 352 NemesisEnforcer Outstanding Standing Member NemesisEnforcer Outstanding Standing Member NemesisEnforcer Outstanding Standing Member NemesisEnforcer Outstanding Standing Member
so what does that central hub do? and what is that terminal piece for? what spots do you ground?? just anything? need specifics!
GIVE DUE REP!! ST Crew #78 /Duratec Crew #91
Go Pats!! Go Green!! Go Sox!! Go B's!
Seeker of Wisdom, LG Crew #1
Resident Sith Lord & Jedi Master, MMA
Thx to those in the military.
NemesisEnforcer is offline
Old 06-21-2008, 12:42 AM   #58
honhon
Fan#: 24778
What I Drive: a better car than a focus.
FF Reputation: 219 honhon Excellent Standing Member honhon Excellent Standing Member honhon Excellent Standing Member
Buy-Sell-Trade Rating: (21)
i plan on running to work and picking up some supplies, and ill be making my ground kit tomorrow... ill take pictures.
http://www.full-race.com/r14-fire-video.html
honhon is offline
Old 06-21-2008, 12:44 AM   #59
BradWhite
Head Hurt
BradWhite's Avatar
Fan#: 54975
Well, we're all going to have come to some agreement on that! My thoughts are:
1. main chassis ground
2. ground to lower engine block
those are actually the only two stock grounds Ford has off the negative battery post on the 08'. I would then add;
3. throttle body
4. engine hanger bolt or a fuel rail bolt
5. opposite side of chassis from main chassis ground - I used the location under the radiator overfull canister where a ground from the wiring harness connects to the chassis
6. ECU case bolt
7. almost forgot, I also tied the three grounds coming from the wiring harness, directly under the main chassis ground, to the main chassis ground.
So, what do you guys think about those locations?
Old 06-21-2008, 01:31 AM   #60
kimbo305
kimbo305's Avatar
Fan#: 52390
On the note of electrical connections, I'd like to ask a new question. Just because all the experts are in here, I'd like to direct them to this thread:
http://www.focusfanatics.com/forum/showthread.php?t=163952
kimbo305 is offline
Similar Threads
Engine Ground Kit Problem RedZx3 ZETEC Performance (2000-2004) 11 07-06-2008 03:07 PM
installed ground wire kit... Spec3VR6 SVT Performance (2002-2004) 8 06-16-2008 12:29 AM
Installed my new dash kit tonight--what do you think? Campbell1971 MK1 Interior Mods & Upgrades 19 05-27-2007 07:28 PM
ground clearance on kaminari lip kit greddyct MK1 Focus 4 11-09-2005 10:07 PM
LiteGlow 7 Color LED underbody kit installed Seashrimp MK1 Focus 4 07-13-2004 11:51 PM
