Sun Hyper Ground Kit Installed - Page 3 - Ford Focus Forum, Ford Focus ST Forum
Go Back   Ford Focus Forum, Ford Focus ST Forum > Ford Focus Second Generation > DURATEC Performance (2008-2011)
DURATEC Performance (2008-2011) The place to chat about any Duratec 20 engine performance, tuning and exhaust related upgrades.
Old 06-16-2008, 05:25 AM   #21
theWorst
theWorst's Avatar
Fan#: 55690
What I Drive: 2008 Edge SEL
FF Reputation: 6 theWorst Good Standing Member
add a wire to the ecu bracket that attaches to the engine bay on the right side...
why didn't anyone tell me turning off traction control gave me faster launches and better gas mileage...
theWorst is offline
Old 06-16-2008, 06:48 AM   #22
aTm Beaner
aTm Beaner's Avatar
Fan#: 21542
What I Drive: 2005 Ford Focus ST
FF Reputation: 5 aTm Beaner Good Standing Member
Buy-Sell-Trade Rating: (6)
i made my own kit when I had a spec V. i just bought 4 GA amp wire from circuit city. I didn't do this for the hp gains. Just like everyone says, my car did feel more responsive after I was done with it.
TEAM DURATEC #512 ST CREW #100
2005 Ford Focus ZX4 ST
Focus Sport Cool-Flo v.1, Focus Racing Cat-Back w/ Magnaflow HFC, F2 Header, Focus Sport Tune 93 Octane, Saleen Suspension Kit, Rota Slips 16x7
aTm Beaner is offline
Old 06-16-2008, 09:04 AM   #23
BradWhite
Head Hurt
BradWhite's Avatar
Fan#: 54975
What I Drive: 08 Sedan SE Vista Blue
FF Reputation: 174 BradWhite Excellent Standing Member BradWhite Excellent Standing Member
Originally Posted by iminhell View Post
Brad, Do me a favor. Go to a run that is about a foot long and measure the resistance in Ohms. Most likely if you test what you have and various other brands they will be fairly close, as in close enough to not register as different on a normal DVOM.
Thank you, exactly what I was hoping to get out of this post, someone with technical knowledge to keep me straight. I'll have my meter out after work today. And will be checking out the sites you linked. Thanks
Best wishes and keep on modding April 2009 SOTM, July 2009 ROTM, 2009 FF ROTY
RIFF CREW, Sedan Revolution #137, TEAM Duratec #181, Bremerton Raceway #658, NW POSSE #6
BradWhite is offline
Old 06-16-2008, 09:05 AM   #24
bdnld4482
Fan#: 46063
What I Drive: 2012 black focus titanium
FF Reputation: 37 bdnld4482 Great Standing Member
ok
Originally Posted by aTm [:)
;2179351]i made my own kit when I had a spec V. i just bought 4 GA amp wire from circuit city. I didn't do this for the hp gains. Just like everyone says, my car did feel more responsive after I was done with it.
im doing this . what can it hurt
bdnld4482 is offline
Old 06-16-2008, 09:06 AM   #25
BradWhite
Head Hurt
BradWhite's Avatar
Fan#: 54975
Will do, I've seen that mentioned somewhere before and forgot about it.
Thanks for the reminder!
FYI, shielding on a ground wire does absolutely nothing, and is a 100% false statement. To "shield" a wire you have to have a way of grounding stray current (in the simplest of terms). Being it is a ground, where would you ground the shield to? Get my point.
I need some clarification on this point. I buy shielded Cat 5E or 6 cable for networks all the time. Those cables are not grounded. It is my understanding that the "shielding" is simply to reduce the amount of stray signals (electromagnetic interference) picked up or radiated by the cable.
From Wiki:
"A shielded cable is an electrical cable of one or more insulated conductors enclosed by a common conductive layer. The shield may be composed of braided strands of copper (or other metal), a non-braided spiral winding of copper tape, or a layer of conducting polymer. Usually, this shield is covered with a jacket. The shield acts as a Faraday cage to reduce electrical noise from affecting the signals, and to reduce electromagnetic radiation that may interfere with other devices. The shield minimizes capacitively coupled noise from other electrical sources."
Isn't this the same type of shielding we're referring to regarding these cables?
I'm not trying to argue with you, believe me my knowledge level of automotive wiring is worse than a two years olds. But shielding, as described above, make sense to me.
Brad
Old 06-16-2008, 12:05 PM   #26
kimbo305
kimbo305's Avatar
Fan#: 52390
What I Drive: '00 Zetec ZX3
FF Reputation: 12 kimbo305 Great Standing Member
Yes, that is shielding, but if the wire you're using as the shield is grounded to the car ground, then it's going to experience the same noises as the ground. So if the ground sees a spike, the shield will see the spike too, since they would be at the same potential to each other at all times. Thus, the shield is not truly electrically isolated from the ground wire it's supposed to protect. It would be effective for high frequency noise, but not all types of noise.
In theory, you could wire the ground shield to the earth by dragging a wire on the ground and attaching the ground shield to that. But who would do that? :)
check out my Fiesta Movement entry: youtube.com/watch?v=dXY3mi1NWeg&eurl=http://www.focusfanatics.com
I wholeheartedly endorse McNew's for installing and tuning your Focus.
kimbo305 is offline
Old 06-16-2008, 12:11 PM   #27
iminhell
C2H5OH
iminhell's Avatar
Fan#: 36222
FF Reputation: 48 iminhell Great Standing Member
Buy-Sell-Trade Rating: (4)
It has to do with what direction the electrons are moving. In a positive charge they want to move to the outside of the conductor. With a negative charge they move inward. With things like CAT5 or simple RCA cables you have a positive and negative charge moving down the same multi conductor cable. To keep the signals from interfering they are encased in a shield. This is done to reduce interference from the cable itself. Say you have 100' of CAT5 your are running through the ceiling of a building, you only need 80 for the run, you get to the destination and roll u the remaining cable and tie it in a big loop. If that cable where not shielded that big loop would cause interference in itself, the resistance would go up and the data loss would probably be affected because the server would have to push harder on the data.
Now in an automotive single conductor situation you don't have to be that protective of signals. There really isn't any multi signal wires or long overlapping runs. Yes you will have positive and negative running side by side, but at the low amperage they operate there is no electro magnetic interference created. As a general rule EMI will increase with amperage in the same cable size, increase the cable size and the EMI goes down.
Don't "think outside the box".
There is no box.
Do it correct, or do it twice.
iminhell is offline
Old 06-16-2008, 03:58 PM   #28
BradWhite
Head Hurt
BradWhite's Avatar
Fan#: 54975
Thank you gentlemen, I think I can wrap my pea brain around that info. How about another question. Some instructions for doing this say to daisy-chain the grounds starting at the battery negative post and then off of each ground to terminate on the opposite side of the chassis (hope that made sense). And I've seen instructions that want you to run each individual ground back to a single termination block and run one ground from that block to the battery negative post.
Any thoughts on that one would be appreciated also. Just a note, Sun's directions indicate daisy-chain. If you look at my 1st post here you'll notice that I've actually got a combination of both going on right now.
Old 06-16-2008, 04:36 PM   #29
kimbo305
kimbo305's Avatar
Fan#: 52390
I'm not really a power electronics expert, but I did take an intro course on it in college. I think both techniques have the same goal -- prevent current loops.
When current runs in a loop, the inside of the loop is subject to changing electric fields as current flows and stops. So if you carefully arrange your grounding to avoid these loops, you won't have big fields going through the sensitive electronics. For example, your car audio might sound a little cleaner.
Either technique has the same goal -- take out loops and make tree like structures instead.
kimbo305 is offline
Old 06-16-2008, 04:55 PM   #30
iminhell
C2H5OH
iminhell's Avatar
Fan#: 36222
^^Correct. But the only way daisy chaining grounds will be more effective than just using the body is if the grounds total resistance is lower than the body, which it should be being you are using copper instead of steel.
To me it just seems like a lot of leg work for very minimal gains, though I'm kind of surprised by your mileage increase. That in itself has me really pondering, lol.
There is no box.
iminhell is offline
Similar Threads
Engine Ground Kit Problem RedZx3 ZETEC Performance (2000-2004) 11 07-06-2008 02:07 PM
installed ground wire kit... Spec3VR6 SVT Performance (2002-2004) 8 06-15-2008 11:29 PM
Installed my new dash kit tonight--what do you think? Campbell1971 MK1 Interior Mods & Upgrades 19 05-27-2007 06:28 PM
ground clearance on kaminari lip kit greddyct MK1 Focus 4 11-09-2005 09:07 PM
LiteGlow 7 Color LED underbody kit installed Seashrimp MK1 Focus 4 07-13-2004 10:51 PM
