#1 | ||||
hey everyone, i heard about this technique for painting valuve covers a long time ago and finally tried it so i thought i share. please let me know what you think. thanks.
1) i bought a spare cover from the local junk yard, cleaned it inside and out with a degreaser and sotch brite pad. then masked off all the areas not to be painted. ![]() 2) for paint, i used engine enamel; gray primer, aluminum for the raised areas, red for the entire cover and clear to finish it all off. 3)after priming and painting the raised areas with the aluminum i let it dry for about 30 mins then covered the areas to stay aluminum with vasaline using q-tips to apply. ![]() 4) once the areas were covered with vasaline i painted the cover with the red.then let it dry overnight and then softly wipe the vasaline covered areas with a cloth to remove the red paint, exposing the aluminum again. ![]() 5) the duplicolor said to wait one week to apply any coats that were not applied within one hour of the last. so i waited then clear coated and installed. as you can see i also painted the oil cap to match. ![]() 6) i also added a breather filter to clean up the look vs the old breather hose that went to my intake. and the throtle cable was moved so it dosent sit on top of the cover any more. ![]() *Side Note: Please replace you gasket do not attempt to use an old gasket.* hope you like it. also if any needs more details just pm me and i will be glad to help. if you find this helpful in anyway, rember rep points please. thanks this is Ft_Knox_Focus' Cover after using this how to plus it shows a differant color.
Remove Advertisements |
Fan#: 1
#4 | ||||
i just remebred that im thinking about doing my original cover in reverse aluminum with red letters, and if anyone wants to know the whole project only cost me about 50 bucks
#5 | ||||
good job, nice write up!
FocusFest 11' "Best in class" • Oct'11 HOTM • FITF'12 "Best Show & Shine" OEM+ • Ford of Europe • Cosworth • FSWerks
#6 | ||||
That looks good. Doesn't feel good when you're done and it's all shiney? I used self etching primer though. It holds better to aluminum and fills bad spots. I'v never seen that valve cover before.
#7 | ||||
i wear no pants
good how-to...thats pretty ncieeeeeee
remember that building a car shouldn’t come from parts it should come from deep inside your soul. let the car speak for all the emotions, memories and experiences youve made and the car will take a life of its own. truth over fame. |
#8 | ||||
thanks, and yes it does feel very good open the hood and BAM!!! nice red shiny valuve cover,the valuve cover is to the SPI motor what most of the 00-04 sedans have. and some escorts have them too.
| Thread Tools | |
| Display Modes | |
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| Duratec - Custom Engine Cover for LESS! | fast07st | DURATEC Performance (2003-2011) | 24 | 04-04-2008 01:02 AM |
| WTT - painted battery and fuse box cover for stock. | Black&Tan | Archive | 1 | 03-27-2007 04:28 PM |
| Fixed Oil Leak - Painted Valve Cover | AcIdBuRn02ZTS | General Technical Chat | 3 | 01-14-2007 12:08 AM |
| My newly painted valve cover | dazada | SPI Performance (2000-2004) | 8 | 07-12-2006 07:20 PM |
| I painted my friend's engine cover | malconsSVT | Ford Focus & General Car Chat | 11 | 12-18-2005 05:18 PM |
