help connecting aftermarket sub/amp to STOCK audiophile 9006 headunit! - Ford Focus Forum, Ford Focus ST Forum
Go Back   Ford Focus Forum, Ford Focus ST Forum > Ford Focus Tech Discussions > Car Audio, SYNC, MyFord Touch & Electronics
Old 06-12-2008, 03:10 PM   #1
barrman
Fan#: 56795
What I Drive: 2003 CD Silver SVT Focus
FF Reputation: 1 barrman Good Standing Member
i'm actually doing the opposite of what most people seem to be doing; instead of installing an aftermarket headunit and hooking it up to the existing audiophile sub/amp, i'm KEEPING the stock headunit, and connecting it to an aftermarket processor (Rockford Fosgate 3sixty.2) then from there, connecting to an aftermarket sub/amp. I'll be completely removing the stock audiophile sub and amp, and just keeping the headunit.
my question is related to how i go about hooking up the audiophile headunit to this aftermarket signal processor. the 3sixty.2 accepts both RCA inputs AND high level (speaker line) inputs. Obviously, ill be connecting the front and rear speakers via the +/- speaker lines coming from the stock audiophile deck.
the only thing i'm confused about is connecting the sub output from the stock audiophile headunit to the 3sixty.2. The 3sixty.2 accepts either a MONO RCA sub input, OR a +/- speaker line input. which should I use? I know that the black/white wire coming from the audiophile harness is the sub positive... is there a sub negative? also, what do I do with the brown/yellow RCA shield wire? Would that even be used? Would that be considered the sub negative?
i've read posts where people used the b/w wire as the positive and spliced it into an rca cable center wire, then connected either the gray/black OR brown/yellow wire to the RCA outer shield... so i'm thinking I could do that, but if the stock headunit is outputting thru high level speaker line outputs, would that even work?
like i mentioned above, I could also try connecting via speaker line inputs instead of using the RCA... but that requires a positive and negative sub connection. I know the positive is the black/white wire, but is there even a negative? would it be the gray/black wire OR the brown/yellow wire? if one of them is actually the sub negative, what would I do with the other one... just leave it disconnected?
anyone who's done this, or anyone who has any advice, chime in!!
barrman is offline
Old 06-13-2008, 10:25 AM   #2
barrman
Fan#: 56795
bump... anyone!?
barrman is offline
Old 06-13-2008, 06:46 PM   #3
FocusedEnergy
FocusedEnergy's Avatar
Fan#: 48574
What I Drive: 2006 Liquid Gray ZX4SE
FF Reputation: 3 FocusedEnergy Good Standing Member
I don't know what wire it is specifically.... but you should have three wires. If I'm not mistaken, one will be positive, one negative, and one the remote wire, for turning the unit on and off with the radio.
I've looked at the processor... you can just skip the original sub wiring and run your RCA's from your processor to your amp.
I may not be 100% correct on this info, someone correct me if I'm wrong. Free bump though.
SEDAN REVOLUTION #51
The tighter the budget, the slower the mod progress. Estimated completion date: September 2057
FocusedEnergy is offline
Old 06-13-2008, 07:39 PM   #4
barrman
Fan#: 56795
thanks for the reply... i was planning on connecting the processor to the amp voa rca's, as i'm pretty sure the only OUTPUT the 3sixty.2 has on it are rca outs.
i was more confused about the connections from the stock headunit to the processor, not the processor to the amp. :)
barrman is offline
Old 06-14-2008, 10:52 PM   #5
barrman
Fan#: 56795
bump!
barrman is offline
Old 06-14-2008, 11:45 PM   #6
mrfatride
mrfatride's Avatar
Fan#: 21759
What I Drive: 2009 Vista Blue SES Coupe
FF Reputation: 42 mrfatride Great Standing Member
just sum the channels the 3sixty.2 should be able to create a sub out from the front and rear high level signal
2009 SES Coupe #036
MECP Certified Installer
mrfatride is offline
Old 06-15-2008, 10:42 AM   #7
barrman
Fan#: 56795
for some reason, i was under the impression that the audiophile spits out a signal after its been processed by its internal crossover, so low frequencies are cut out of the fronts and rears, so if i were to have the 3sixty.2 sum the fronts and rears to make the sub channel, it would still be missing the actual low frequencies... yes? no?
barrman is offline
Old 06-15-2008, 10:49 AM   #8
josejsanchez
MW2 NE1?
josejsanchez's Avatar
Fan#: 45194
What I Drive: 04 cd silver svtf
FF Reputation: 3 josejsanchez Good Standing Member
got my system hooked up to audiophile stock head unit in my svt. really dont know which wires were hooked up to what but i can maybe get the hu out and see what wires were connected to what. i only got a line out converter and also have the amp and 8" sub still connected.
#910 OF #1978
just call me beaver
josejsanchez is offline
Old 06-15-2008, 03:54 PM   #9
mrfatride
mrfatride's Avatar
Fan#: 21759
i wanna say that the front speakers on the audiophile system have the crossover built into the speakers...the rear speakers are just normal 6x8s and the amp for the sub has the crossover built in as well..
2009 SES Coupe #036
Old 07-15-2008, 02:24 PM   #10
barrman
Fan#: 56795
ok i started hooking everything up for this setup... i've tapped into the white/black wire from the 9006 headunit for the sub signal (+) and the brown/yellow wire for sub shield (-), and wired both to the sub (+/-) high level inputs on the but i'm getting EXTREMELY low output signal. any ideas?
barrman is offline
Similar Threads
2003 ZX3 Parts for sale (stock and aftermarket parts...) EMAN44 Archive 29 08-26-2007 03:44 PM
Stock Sub - Low/Crappy output from new aftermarket HU DFv2 Car Audio, SYNC, MyFord Touch & Electronics 0 05-02-2007 05:30 PM
New sub/amp to stock HU jhem02 Car Audio, SYNC, MyFord Touch & Electronics 0 02-27-2007 08:46 AM
mp3 instead of 9006 audiophile jaxzx5 Car Audio, SYNC, MyFord Touch & Electronics 2 07-30-2006 08:24 PM
Connecting your stock/factory head unit to an aftermarket amplifier sa_pyro_ne Car Audio, SYNC, MyFord Touch & Electronics 11 03-18-2006 08:30 PM
