#1 | ||||
A/C Problems
Hello all.
I have a 2001 SE with 90k. I bought it last November, and the A/C has not worked since then. The light on the dashboard switch comes on, but I can't feel/hear the compressor engage. There's a plug with two wires on the compressor, one ground wire and a (if I remember right) green/yellow wire. I tested these with a multimeter and the ground seems good, but the green/yellow wire doesn't show any voltage with the ignition on, engine running, and A/C switch on. Any ideas where I go from here as far as troubleshooting? I didn't check the switch for continuity yet, I'll do that next. There's an A/C relay under the hood, but I'm not sure how to test it. Thanks Andy |
Remove Advertisements |
Fan#: 1
#2 | ||||
I have the EXACT same problem and posted here looking for help, and all i got was "get a haynes manual..."
and well, i ordered one on ebay and am waiting for the sucker to show up in the mail... and its been a while :( but hell, i hope we can get this figured out!!! |
#3 | ||||
There are many conditions that will stop power from reaching the compressor clutch. The most common is a loss of A/C refrigerant, causing the pressure to be so low that the low-pressure cutoff switch blocks power to the compressor clutch. On a vehicle that age, the most likely problem is that the A/C system has a leak and has lost pressure. |
#5 | ||||
> Ahh... I didn't realize there was a low pressure cutoff.
Yes, virtually all auto A/C systems have it so that the compressor doesn't destroy itself if the refrigerant is gone. |
#7 | ||||
> It could also just be a bad A/C relay
Correct. I myself would use a multimeter and a wiring diagram to trace back from the compressor and see where the power is being stopped. |
#8 | ||||
I swapped the low beam and A/C relay, and the relay is good. I don't have a wiring diagram - any suggestions for sources besides buying a chiltons or haynes manual?
| Thread Tools | |
| Display Modes | |
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| A/C and fuel pump problems. | Focus_wrc00 | General Technical Chat | 2 | 06-07-2006 06:47 AM |
| Need help please!! Focus problems | Jebus | ZETEC Performance (2000-2004) | 3 | 02-04-2006 09:46 AM |
| A/C Knob Problems? | Kamui | MK1 Interior Mods & Upgrades | 8 | 12-16-2004 06:39 PM |
| A/C Problems | latindude542002 | SVT Performance (2002-2004) | 11 | 08-31-2004 09:24 AM |
| How to turn A/C of when directing air circulation to windshield? | Bocha | Ford Focus & General Car Chat | 15 | 12-25-2003 04:20 PM |
