HOW-TO: Changing Manual Transmission Fluid - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 06-06-2008, 08:06 PM   #1
SYZ
FocusFreak
SYZ's Avatar
Fan#: 31122
What I Drive: toxic waste
Points 8,010, Level 60
Points: 8,010, Level: 60 Points: 8,010, Level: 60 Points: 8,010, Level: 60
Level Up 30% Completed
FF Reputation: 106 SYZ Excellent Standing Member SYZ Excellent Standing Member
Buy-Sell-Trade Rating: (14)
This is pretty simple, but I figured since there wasn't already a write-up, I'd take a couple pics of the job.
Items/tools required:
Jack & jack stands
Drain pan
8mm hex key
Funnel w/ tubing (preferred)
2.1 quarts of your favorite, fully synthetic MTX fluid
I bought some BG Synchro Shift II, I swear by it- it'll make your transmission shift like butter. You can get it at Mitsubishi dealerships, or online
1) First off, you'll want to jack up the driver's side of the car (You'll get better results draining the transmission if you just jack up this side, as the drain plug faces the passenger side). USE JACK STANDS!
2) Here's a picture facing the transmission from the front of the car. Using your 8mm hex key, check to make sure you can untighten the fill plug first. Just crack it loose, but don't unscrew it.
3) On the left side of the transmission, just in front of the rear motor mount, the drain plug resides. Use the 8mm hex key and unscrew it.
4) After it has completely drained (approx 5-10 mins), tighten the plug back on. Make sure it's snug and a little extra, but not he-man tight. Now use the funnel and tubing to fill the transmission from the fill hole. Make sure you use 2.1 quarts. Yes, that means having to buy three.
5) Tighten this plug down the same as the drain plug, lower the car, and enjoy your smoother-shifting transmission.
2003 Ford Escape 4x4 Limited
On Order: 2015 Porsche Cayman S
SYZ is offline
Old 06-06-2008, 08:39 PM   #2
Klondike
GreyRice WOoT!
Klondike's Avatar
Fan#: 25991
What I Drive: GI, '07 zx3 LG
Points 33,169, Level 100
Points: 33,169, Level: 100 Points: 33,169, Level: 100 Points: 33,169, Level: 100
Level Up 0% Completed
FF Reputation: 53 Klondike Excellent Standing Member
Buy-Sell-Trade Rating: (26)
excellent write up man, easy to understand, makes it simple, great job man
Focus Nation
Focus Revolution
Chrenron 1 of 3
Velveeta Lover Shell#1
LOTH 00!
Klondike is offline
Old 06-06-2008, 09:39 PM   #3
Woody_in_MN
Fan#: 56278
What I Drive: 2008 Black/Black SE 5 spd
FF Reputation: 1 Woody_in_MN Good Standing Member
SYZ,
Nice write up.
What year car was in the pics?
At what mileage should the fluid first be drained/re-filled?
- w
Woody_in_MN is offline
Old 06-06-2008, 09:43 PM   #4
SYZ
FocusFreak
SYZ's Avatar
Fan#: 31122
The car is a 2005 2.0 Duratec. It's the same motor that's in your 2008.
I believe the owners manual calls for a MTX fluid change every 30K miles. If it doesn't, I'd do it anyway at that time interval.
SYZ is offline
Old 06-06-2008, 09:56 PM   #5
method213
Fan#: 360
What I Drive: 2003 Ford Focus ZX3 Duratec
FF Reputation: 18 method213 Great Standing Member
Great pictures, great write up. Ill for sure do this by my self now!
2003 DURATEC ZX3,FS Intake,Steeda Short Shifter,Speedhut Gauges,Draxas Header, Custom Cat-Back 2.5inch,P51 Shims,FC Strut Tower Bar,CarbonFiber Hood,FS Stress bar,Xcal2FStune,Svtfront,ST170Headlights,Roush Stg.2 Suspension,Svt seats,BSDelete.
method213 is offline
Old 06-06-2008, 11:28 PM   #6
BornAgainFordOwner
Fan#: 9408
What I Drive: 2004 Liquid Grey ZX3 PZEV 5Sp.
FF Reputation: 7 BornAgainFordOwner Good Standing Member
One caution others have noted. Make sure that you can loosen the fill plug BEFORE you remove the drain plug!
Already mentioned. I didn't read closely enough!
BornAgainFordOwner is offline
Old 06-06-2008, 11:54 PM   #7
NemesisEnforcer
Force-Powered Focus
NemesisEnforcer's Avatar
Fan#: 48598
What I Drive: LIQUID GRAY 2005 ST
Points 18,461, Level 86
Points: 18,461, Level: 86 Points: 18,461, Level: 86 Points: 18,461, Level: 86
Level Up 23% Completed
FF Reputation: 352 NemesisEnforcer Outstanding Standing Member NemesisEnforcer Outstanding Standing Member NemesisEnforcer Outstanding Standing Member NemesisEnforcer Outstanding Standing Member
excellent writeup, once again.
same as on the 2.3?
now, i looked at my maint. schedule, and it says not to do this until 100k!! It says 30k if its an automatic....? then at 60k again, and so on...
GIVE DUE REP!! ST Crew #78 /Duratec Crew #91
Go Pats!! Go Green!! Go Sox!! Go B's!
Seeker of Wisdom, LG Crew #1
Resident Sith Lord & Jedi Master, MMA
Thx to those in the military.
NemesisEnforcer is offline
Old 06-07-2008, 02:24 AM   #8
SYZ
FocusFreak
SYZ's Avatar
Fan#: 31122
Yes, same for the 2.3. If the maintenance calls for only once every 100k, I'd imagine the fluid would be in sorry condition once actually changed.
Of course, the harder you beat on your car, the sooner your fluids should be changed anyway. I'd be hard pressed to push any fluids further than 50K miles, unless it's the power steering. It's up to you, really. Some people like to change out their fluids more often and others have no problem running their oil dry.
SYZ is offline
Old 06-07-2008, 02:48 PM   #9
NemesisEnforcer
Force-Powered Focus
Fan#: 48598
yeah, i am about to do a coolant flush, since over 30k now. gonna wait on tranny though. I need an alignment anways, so i will just have that done at the same time.
Old 06-07-2008, 03:45 PM   #10
SALEEN_N2O
SALEEN_N2O's Avatar
Fan#: 51865
What I Drive: MARINES!
FF Reputation: 33 SALEEN_N2O Great Standing Member
Buy-Sell-Trade Rating: (8)
nice write up.
i thought tranny fluid was changed at 60K??
Im at 34,xxx on an MTX and i drive mine preatty hard....should i go ahead and change it??
once again.. nice write up!!
SALEEN_N2O is offline
Similar Threads
ATX to MTX Swap Guide boosted2nr Engine & Transmission Swap 103 08-05-2014 08:49 PM
how do you fill a mtx-75 with fluid?!!!! help please!!!! firemanchev General Technical Chat 26 09-11-2008 07:18 PM
07 ZX3 2.0L Transmission Fluid Capacity? Power Steering Fluid Capacity? INCUBUSRATM General Technical Chat 25 02-04-2008 04:45 PM
SVT Transmission fluid capacity? IcEMage SVT Performance (2002-2004) 3 12-24-2007 04:56 PM
Too much transmission fluid - ATX lduran General Technical Chat 11 11-11-2007 11:22 AM
