Sponsored By: Massive Speed
Old 06-06-2008, 08:31 AM   #1
K Dog
FF Affiliate
K Dog's Avatar
Fan#: 23554
What I Drive: Car
Buy-Sell-Trade Rating: (16)
-Massive PORTWERKS Cylinder Head Packages Available!-
Massive and a team of skilled engineers has invested many hours over the last 1.5 years developing a truly unique and exceptionally superlative cylinder head option for the Ford Focus engines.
We think you will find not only a genuinely higher lever of performance, but also the finest of components, exclusive process', but also competitive pricing.
As of June 6 2008, we are releasing the first of an entire new line of breakthrough performance heads. Machined locally utilizing a Millport CNC 5 Axis Mill with TRT 32-100 Tilt table, profiles are programmed and digitized using MasterCam X2.
Look for our Duratec cylinder head to be ready for presentation within the month. In the pipeline is our series of GM LS-1 and Ford 3V modular offerings.
The Zetec heads (as will most of our other offerings) will be available in 2 distinct flavors - The Ultimate head using enlarged valves and high rate springs, and the Optimized head equipped with OE valves and springs. This will provide less expensive options as well as all out solutions.
Here is the description on our Zetec Ultimate Head:
ZETEC POWER UNLEASHED!
Based on our comparison with other mass produced heads and available data, Massive has created the worlds TOP FLOWING ZETEC CYLINDER HEAD.
5 Axis CNC machined for the best in consistency and flow!
In our quest for power superiority, an OE head was flow tested on a Superflow SF-600 flow bench at 28” of water to determine base line flow numbers. After the initial flow test the heads are ported by hand to develop a working port shape and volume. The head is then reflowed after hand porting to verify the increase in flow. At that point, they are reverse engineered using 5-axis digitizing to acquire the port shape of the finished port. This makes for the greatest possible flow capacity and consistency.
Heads begin as production cores which are fully disassembled and washed. The heads are then glass bead blasted clean to remove any rust or scale. They are then CNC machined using 5-axis simultaneous machining. All ports and chambers are machined then hand finished to blend out any unwanted tool marks. All valve guides are honed to size and a multi-angle valve job is cut into the head. The valve job is cut using Newen single carbide insert style cutters of varying profiles. The valve job is lapped in then blended to the finished port and chamber. The heads are then surfaced to the customers needs and reflowed again to confirm that the finished product performs as expected. Outflows ANY production Zetec head without sacrificing velocity. Substantial chamber modification (most fimrs dont touch the chamber!) for superior flow dynamics and greater resistance towards detonation. Genuine Eibach EVS high rate valve springs (good to .450" Lift). Custom made Undercut SI brand stainless steel valves. This undercutting, in addition to reducing the valve weight (which provides benefits in opening rate and RPM limits), the radius of the head is such that is significantly improves air/fuel flow. Fully swirl polished. Chromed stems and Stellite tips.
Going for big NA horsepower? Massive offers your choice of standard(.005"-.010" for straightness) or HIGH COMPRESSION state(.045" mill)for serious increases in forward thrust!!!
The Ultimate Head is $1348 and the Optimized Head is $1068. They will require a core charge of $300.
These heads are on the shelf and ready to ship!
Find them Here
K Dog is offline
Fan#: 1
Old 06-06-2008, 10:25 PM   #2
MattMatt1182
Fan#: 53441
What I Drive: 2003 Pitch Black ZX5 SVT Build#751
FF Reputation: 1 MattMatt1182 Good Standing Member
What can you do to the SVT Head? Do you have one of those on the shelf?
MattMatt1182 is offline
Old 06-06-2008, 11:30 PM   #3
Focus_3XZ
Fan#: 35439
What I Drive: SVT
FF Reputation: 8 Focus_3XZ Good Standing Member
Yeah there is definetly a need for the SVT head to be done. It will easily outflow the Zetec ultimate head.
Focus_3XZ is offline
Old 06-07-2008, 08:03 AM   #4
killer ZETEC
GL1TCH
killer ZETEC's Avatar
Fan#: 44757
What I Drive: advance trac french blue 03 zx3
FF Reputation: 42 killer ZETEC Great Standing Member
me want so bad... but me need stereo finished first.
btw karl what cams would you suggest for this head.
also would a ported 200 manifold an 65mm throttle body do well for intake. (through an svt box with a zetec upper half, but i'm willing to change that if necessary)
obviously an svt header is needed. but what size exhaust. 2.5?
jsut trying to my ducks in a row for a well built engine so i can spank a few noobs up here.
focus owner whos runnin with the hatchet
zc187 focus nation and fvscc's car 343
still getting part and things for this turbo.
will it run soon?? who knows.
killer ZETEC is offline
Old 06-07-2008, 08:38 PM   #5
Buickboy
br/o/stang
Buickboy's Avatar
Fan#: 28542
What I Drive: 72 Skylark, '12 Mustang
FF Reputation: 39 Buickboy Great Standing Member
Buy-Sell-Trade Rating: (29)
Ill add a set of the duratec ones to my dream 2.3L dura build list once theyre out, looks like good stuff! You guys have quite an improvement in flow over the stock head
==2012 Kona Blue Mustang V6==
==1995 Light Iris Neon Coupe==
==1972 Skylark==
Buickboy is offline
Old 06-09-2008, 12:33 AM   #6
FocusRacingAustrali
FocusRacingAustrali's Avatar
Fan#: 45865
What I Drive: 2003 ZX4 & 2004 ZX5
FF Reputation: 6 FocusRacingAustrali Good Standing Member
Buy-Sell-Trade Rating: (13)
Do you have any dyno proof at all?
I see you have abit more lift over FR at top lift but, need to see WHp dyno proof.
I only worthship the HP gods []
A false Hp god: Foolish are those who always have wild claim and know fear nothing, yet claim to know everything.
FocusRacingAustrali is offline
Old 06-09-2008, 08:34 AM   #7
K Dog
FF Affiliate
K Dog's Avatar
Fan#: 23554
What I Drive: Car
48 more CFM on the intake side and 25 on the exhaust over the FR head is more than what I'd call "little".
That like, oh, 25% more flow intake side...
We will back to back a minor bolt on Zetec shortly.
K Dog is offline
Old 06-09-2008, 08:36 AM   #8
K Dog
FF Affiliate
K Dog's Avatar
Fan#: 23554
What I Drive: Car
We have had a few requests for the SVT head, and even have turned a few out in the past, but the lack of cores is an issue.
I dont know if an SVT head would outflow the Ultimate head. With that heads bigger valves, there is no longer and advantage on the SVT there. It would be interesting though.
K Dog is offline
Old 06-09-2008, 08:42 AM   #9
K Dog
FF Affiliate
K Dog's Avatar
Fan#: 23554
What I Drive: Car
A ported 00'/65mm TB would definitely be a big improvement over stock and would work well with these heads. I will be using a modified FR manifold and 70mm TB on my yellow turbo car with this head.
Your induction setup otherwise seems solid.
I would use the JBA long tube header with a 2.5" exhaust for max HP production.
K Dog is offline
Old 06-09-2008, 11:41 AM   #10
besthaticouldo
i wear no pants
besthaticouldo's Avatar
Fan#: 26970
What I Drive: '11 OBP WRX Sedan
FF Reputation: 104 besthaticouldo Excellent Standing Memberbesthaticouldo Excellent Standing Member
Buy-Sell-Trade Rating: (23)
if i sent you an svt head would you do it?
remember that building a car shouldn’t come from parts it should come from deep inside your soul. let the car speak for all the emotions, memories and experiences youve made and the car will take a life of its own. truth over fame.
besthaticouldo is offline
Similar Threads
Every trouble code defined 03OrangeSVT General Forced Induction 9 05-25-2011 12:53 PM
WTB: Ford Racing cylinder head. Zetec 2 litre melbzetec Want To Buy 2 12-05-2007 12:49 PM
New Cylinder Head? jmltapp General Technical Chat 11 02-05-2004 02:28 PM
valve sizes on head packages mattsstang87 ZETEC Performance (2000-2004) 2 09-04-2003 07:59 PM
